Question about Dryers
Dryer will not run - Dryers
  • dinomb
    dinomb May 11, 2010
    Is light on when door is open?
    If so, try leaving door open, push in on door switch(Paperclip), and try starting dryer, if so, switch tab is bent
  • 110 Answers
What kind of dryer do you have? if it is a kenmore just as dinomb say check door switch, you can also check for proper voltage in the back of kenmore dryer you have a white thermal fuse that will keep it from running..
now if you hear your timer ticking you are getting power
Posted on Apr 03, 2008
Maytag performance dryer model PYE2300AYW won't stay running after releasing the start button
Maytag Dryer Won't Start - Testing the Start Button - YouTube
? 1:26
https://www.youtube.com/watch?v=gJwYV8HkTbk
Oct 7, 2013 - Uploaded by Bill Newberry
This video shows you how to test the start button on a MaytagDryer. ... dryer medc200xw0 will not keep running after releasing the start button.
GE Dryer won't stay on after turnin
Dryer won't continue running when start button released ...
forum.appliancepartspros.com > Appliance Repair Help > Dryer Repair
Jul 25, 2014 - 3 posts - ‎2 authors
When I push and hold the start button the dryer motor starts and heats. It will not continue to run when I release the button. All thermostats ... button released. Model Number: PYET344AYW Brand: Maytag Age: 5 - 10 years .... Check for 120vac on the purple wire at motor after releasing start button. If it goes ... GE Dryer will not stay running when start button released ...
Jul 26, 2014
Starts but won't stay running
Sep 12, 2013
Dryer won't stay running
Apr 23, 2011
Jan 11, 2011
More results from forum.appliancepartspros.com
Jan 01, 2016 | Maytag Dryers
Why wont my dryer stay running?
Good Morning Friend,
I understand that your Frigidaire dryer, model# FEQ1442ES, will not stay running. Please check to make sure the door is staying closed. If the door is opening in mid-cycle, then the dryer will stop running. Also, make sure the plug is in the socket tightly. Your dryer could be shaking the plug loose, which could possibly be causing it to stop running. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 17, 2014 | Frigidaire FEQ1442ES Electric Dryer
Dryer does not stay running. Press the start button and sometimes it starts and sometimes not. Won't stay running. Seems to heat ok. Sometimes displays E9E on the display.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Oct 20, 2010 | Frigidaire GLEQ2152ES Electric Dryer
My gas dryer starts and will run. However when you let off the start button the dryer stops. If we hold the start button on it will run through it's entire cycle with no problems.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 06, 2010 | GE DWSR405GBWW / DWSR405GBCC Gas Dryer
The dryer will run for 5 to 7 min then shut off come back in about 3 min it will run then the dryer will do it over and over again untill it will not trurn on
Dryer Repair ? The dryer will not start
heatman101
Aug 27, 2010 | GE DWSR463EGWW Electric Dryer
I replaced the 3 prong cord with a four prong cord. At first the dryer was running and the drum was not spinning, now the dryer is not running at all.
Here is a tip that will help you with changing your dryer plug.
Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} There can be many reasons why your dryer will not start or turn...
heatman101
Aug 15, 2010 | Frigidaire GLWE642AS Electric Commercial...
3 wire plug Maytag dryer, but a 2 wire prung outlet@120 volts.
your dryer can be wired to run on 120 / i would not do / very costley to run . . this is some times done for display on the sales floor . best is to get gas dryer or have 220 wired to dryer .. if in home . **** ..
Dec 07, 2009 | Maytag Atlantis MDE7657BY Electric Dryer
Maytag dryer timer keeps running
Your dryers timer contacts have fused to gether.
The only repair is to replace the timer.
Mar 25, 2009 | Dryers
Eastate gas dryer 4-5 years old.
if burner does not reignite and glow bar is lighting up suspect the black coils on valve bad
Oct 24, 2008 | Estate TGDS740JQ Gas Dryer
Dryer runs for minutes then stops timer keeps going and going and .....
remove the vent on the dryer that goes to the outside start the dryer if it continues to ru n and not cut off you have a venting problem of the house
if it cuts off after 5 mins with the vent off you have a motor that is going bad
Jun 11, 2008 | GE DBXR463EBWW Electric Dryer
Dryers Logo
153 people viewed this question
Top Dryers Experts
