Question about Koss Audio Players & Recorders
Koss Model HH957 3 disc changer
Disc door will not open when I press the open button, but I can hear the changer turning. What can I do to get it to open?Thanks
SOURCE:
SOURCE: rca compact stereo rs2657 cd door won't open
Mine was doing the same thing so I unplugged it and took the left side panel off to see what was wrong with it. I did this by removing the 2 screws on the left and the 3 on the back left side also.There was a cd stuck in it. It took some fenangling but I got it out and it works fine now. I know, I know. We as lay people are not supposed to do these things but it was out of warranty and would have cost me as much to have it repaired as to buy a new one. Good luck!
Posted on Dec 26, 2007
SOURCE: Err 0305
I know this is no help, but I am haveing the exact same problem and I searched and cant find anything about how to fix the problem..I wish I knew what caused it at least
Posted on Feb 01, 2008
SOURCE: Drive belt for a HH957 CD player
Found a belt at a local dealer.
Posted on Aug 03, 2008
freetek
  • 5569 Answers
SOURCE: CD CHANGER EJECT BUTTON
Inspect the tray or door to see if there is a very small hole in it. If so, this is an 'emergency' ejection hole and a standard paper clip, unfolded, can be inserted there to manually eject the tray. This is a real common problem caused by the slippage of a clutch mechanism that is supposed to protect the tray mechanics from being damaged if the tray is somehow impeded during its travel.  It must be tougher than rocket science to properly design this feature -
Posted on Oct 28, 2008
  • 201 Answers
SOURCE: CD changer won't open
There may be a jammed disc in the mechanism - if there is no manual release near the door (there isn't usually on these systems), you may have to open the case and look to make sure there's not a disc jammed somewhere in there.
Posted on Mar 13, 2009
Stuck CD in JBL 4 disc CD Changer / Navigation
before you press the cd on button keep holding the eject button while you press power on, I know this works for computers etc.
Feb 13, 2016 | 2013 Toyota Highlander
It is a 5 disc changer. The drawer will not open and it now has 4 cd's stuck inside the changer. It also will not play any of those "stuck" cd's.
THis happens when the drawer is jammed. Turn off the unit and turn it on and then use the disc skip from the remote so that the cds inside will change and then press the Open button.
Aug 21, 2010 | RCA Audio Players & Recorders
Our Sony 400 disc changer won't open. I can hear
If ure an expert, then open up the set, check for alignment balancing for the gears and see if the belting has worn out. Pioneer till today uses belt for ejecting. Belt usually the issue.
Jan 16, 2010 | Sony MegaStorage CDP-CX455 400-Disc CD...
How do I instert a CD into my pioneer deh-p6200 car radio?
Slide the door open (1/2 gray 1/2 silver door) on the disc changer, inside is a push button that ejects the 6 disc cartridge. Load and unload cd's into it.
Oct 05, 2009 | Pioneer CDX-P1280 12-Disc CD Changer
I have a jeep liberty that just had a new battery put in and now the cd changer won't work. any suggestions
Alternately, try opening the CD changer door, ejecting the CD carrier and look for a small reset button below the opening. Press this with the tip of a pen and hold it for 10 seconds, then turn the radio/CD on again.
May 19, 2009 | Jeep 2003 Liberty RBQ AM/FM Radio w/...
Door to load cd's wont open or close without help.
hello i have had the same problem with my 5 cd changer,i way i solved this was to turn the player top slide down then do this care fully ,shake it gently and see if a cd came out of it, groove sit in the player.if you hear a rattle than there is a stray cd in the device. you have got to shake the cd to the front of the cd dawer to take it out with a thin ruler or a butter knife but be care ful with the knife preess on the open button wale trying to slide the butter knife between the stuck cd and the inside of the cd sit cation be care.
Apr 25, 2009 | Audio Players & Recorders
Mar 13, 2009 | JVC UX-S57 CD Shelf System
Dvd player will not open
the problem is internal and the only way is to bring it back to the store you just bought it. because it is still under warranty, since it is just newly bought.
Good luck
Jan 20, 2009 | Koss KD365 DVD Player
166 people viewed this question
Top Koss Audio Players & Recorders Experts
Steve Allison
Steve Allison
Steven Wander
Steven Wander
Ekse
Are you a Koss Audio Player and Recorder Expert? Answer questions, earn points and help others
