Cannot get computer to read my printer model no. Z 645 my address aztec5@comporium.net
    Problem Solver:
  • 16 Answers
You probably need to install drivers for this printer before your computer can detect it
Posted on Apr 02, 2008
I am trying to find my IP Address on my HP Deskjet D1420
this printer is non net work model.. U can't install direct in network, but U can install as a local printer in one computer there u can share it to n number of systems..
Apr 09, 2014 | HP Deskjet D1420 InkJet Photo Printer
Attach printer to computer wireless printer
try to make your wireless printer set to static ip address. may i know the model?
thanks
Apr 08, 2014 | Computers & Internet
Ink pad is at the end of its service life workforce 645
is there a cheat to reset the counter for the workforce 645? similar to the r320 you listed above?
Feb 05, 2013 | Epson Workforce 645 4x Ink MFC
I have gestetner 645 i installed in windows xp machine with network.now inside the computer priner is on ready condition and i am able to ping printer. but when i print some document so its not display any...
check you have the correct port set up in the printer properties.. the default is usually parrallel or usb if connected with network cable open the printers faxes page on your computer and right click on your printer open the ports tab and check if it is set to TCIP you will have to enter the ip address here. you can get this by going to the copier press the 123 button at top left then press for printer and print the config page..hope this helps A
May 29, 2010 | Gestetner DSm645 Digital Imaging System
When trying to install gets message cant find internet trying to hookup to embarq 660
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hi there! This are some steps on how to setup your modem/router
New DSL Modem Available
Embarq is now shipping an updated version of the DSL Modem called the "660". It is smaller than the older model (645) and is much easier to setup.
A few years ago, Sprint/Embarq changed the way their servers communicate with the DSL modems. The new method is called DHCP, which is how the 660 modem works. The older 645 Modem used "PPPoE". So it's best to have the new 660 DSL modem.
The older 645 modem also had the same default IP address as the Linksys Router (192.168.1.1) - so you had to change one of the addresses to make them work together.
The new 660 DSL modem uses 192.168.2.1 as the default IP address. This does not conflict with the default IP address of the Linksys Router (192.168.1.1). Note that if you had changed the Linksys Router IP address to 192.168.2.1, then you will first need to reset it back to the default address 192.168.1.1.
If you call Embarq and request the new 660 DSL modem they will sent it to you at no cost. When you install the 660 DSL modem, you need to be sure that you power down the old 645 modem amd leave it off at least 1 hour before you plug in the 660 DSL modem. The Embarq server needs to "forget" the old 645 modem. After an hour, all you should have to do is plug in the new 660 modem and everything should start up properly.
Call Embarq Tech Support 1-877-646-3282 if you have problems setting up the modem. If the Internet Lights does not come on after a few moments - then call Embarq Tech Support.
Aug 15, 2009 | Belkin Wireless Pre-N (F5D8230-4) Router...
What buttons do i press on an 20.0 IR remote to program a proscan tv?
Hi, Cheri Torres with DISH Network Customer Service here. I came across your post and wanted to see if I could help. We have a few different codes for each of our different models of remotes. You will be able to locate the model of your remote on the back of the remote at the top usually a two to three digit number with a decimal point. I will list here for you the best codes for our more popular models of remotes. I hope you find these codes and instructions useful and if you have any further questions or concerns feel free to email me at Cheri.Torres@Dishnetwork.com.
Codes for remotes
3.0, 3.1, 3.2 and 3.4 IR remotes - 627, 646, 645, 650, 056, 773, 725 and 857
5.0, 5.2, 5.3 and 5.4 IR remotes - 650, 627, 691, 645, 646, 503 and 857
4.0, 4.4, 6.0, 6.2, 6.3 and 6.4 IR/UHF remotes - 505, 691, 627, 857, 645, 671,742 and 505
20.0 IR remote and 21.0 IR/UHF remote - 627, 645, 615 and 650
Instructions for addressing your remote to your TV
  1. Turn the Television On
  2. Press and Hold the TV Mode button until all other mode buttons light up red
  3. Enter the three-digit code using the buttons on the number pad.
  4. Press the pound (#) button once
    Note: The LED will flash three times.
  5. Test functionality with the TV
  6. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Jul 09, 2009 | DISH Network IR Remote Control
Manual motherboard msi (ms-6547) ver 2
There are 5 versions of this model
http://global.msi.com.tw/index.php?...
They have either 5 or 6 PCI slots.
Find the version number - beside the model number
Note the SiS main chipset numbers (one may be under a heatsink)
MS-6547 Ver 1.0 a.k.a. 645 Ultra - ATX, 5 PCI slots
SIS® 645 Open Architecture DDR333 Chipset
SIS® 961 MuTIOL® Media I/O Chipset
MS-6547 Ver 2.1 a.k.a. 645 Ultra-C - ATX, 6 PCI slots
SIS® 961B MuTIOL® Media I/O Chipset
MS-6547 Ver 2.0 a.k.a. 645E Max - ATX, 6 PCI slots
SIS® 645DX Chipset (under heatsink)
SIS® 961B Chipset
MS-6547E Ver 1.0 a.k.a. 645E Max-C - ATX, 5 PCI slots
SIS® 645DX Chipset
SIS® 961B Chipset
MS-6547 Ver 2.2 (2.1) a.k.a. 645E Max-U - ATX, 6 PCI slots
SIS® 962L Chipset
Jun 27, 2009 | MSI MS-6547 Motherboard
Unlocking a HoneyWell T7300B1003 Thermostat
Set keyboard lock out DIP switch 1 to off. Pg. 16 in the isstructions
Jan 05, 2009 | Honeywell Programmable Thermostat Heater
Sceptre x9g nagaV
you cannot connect your vga monitor to your rca vcr its not compatible unless you have a vga to rca converter
Nov 03, 2008 | Sceptre X9G-NagaIV 19" LCD Monitor
Memory stick / card slot not reading
hi your card reader conect to laptop & reset ..........then laptop start your card ok.
Jan 21, 2008 | HP Compaq Presario V2000 Notebook
29 people viewed this question
jasbo
jasbo
