Question about Samsung HCL4715W 47" Rear Projection Television
Problem with Samsung HLN4385WX
I have a Samsung HLN4365W that is acting up. After about 45 minutes of being on the screen starts to flicker and then the picture eventually gets discolored and difficut to see the picture. It also makes a squeaking noise when it flickers. Any ideas as to what could this be?
  • 206 Answers
These sets have a color wheel in them that has been know to cause this, Many times the customer heres the color wheel bearings failing and think it's a fan failing. The part BP96-00250a is only about $95.00 and since I have changed well over a hundred would call this a easy repair but for the newbie this might be a challenge
Posted on Apr 02, 2008
Samsung LCD S27B350H blinks during 45 minutes after power on
The backlight is failing, or you have some other power supply problem
Sep 21, 2012 | Samsung S27B350H - SyncMaster S27B350H -...
how extended is that warranty, and what does it cover? Sounds to me like a classic video controller board about to fail.
Mar 24, 2008 | Samsung DLP HL-P5663W 56" TV
Good afternoon. I have an LCD . When I turn it
Sometimes LCD screens can flicker if kept in cold environments. Make sure that it's not too cold in the area of the LCD. Also, make sure the cable to the monitor is connected properly, as a loose cable can also cause the screen to flicker.
Mar 05, 2011 | Samsung Computers & Internet
Samsung HLN4365W picture not centered
turn the tv off, hit mute 1 8 2 power, the tv will come on in the service menue, look in that menue for vertival and horizontal adjust, after you adjust it, just turn the tv back off, it will save your changes
Jan 07, 2009 | Samsung HLN4365W 43" Rear Projection...
Hdtv but has no inlet for the cord.
That set has 2 DVI connectors in the back. Either one will work if you have a cable that matches.
The manual is available online too
Jan 05, 2009 | Samsung HLN4365W 43" Rear Projection...
HLN4365W Start-up Issue
the main power supply may be getting weak. if so it will delay the time it takes it to come on and eventually it wont come on at all
Jun 27, 2008 | Samsung HLN4365W 43" Rear Projection...
Samsung hln4365w - no pic. or sound. it whistles a few times when powered on
We have the same DLP set and had the same problem. The Color Wheel, P/N BP96-00250A, a $200 part needs replacement to eliminate your problem.
May 24, 2008 | Samsung HLN4365W 43" Rear Projection...
Picture loses color on samsung HLN4365W
if the picture is still visible but lacking color, it is not the lamp. check the color wheel and make sure it is working. replacing the color wheel is a pretty easy task and can be performed by yourself without many problems. as a sidenote, older samsung dlp tvs seem to experience this problem quite often, although they usually sound like someone strangling a cat before the bearings go out.. should carry your replacement for 100 USD or so, the part number is BP96-00250A.
before replacing it, make sure your old one isn't just stuck or not spinning at full rpm, if this is the case, you can usually remove it and clean the motor using electronic or contact cleaner that is safe for plastics.
to check everything out, you will need to remove the back panel of your tv, then power it up (keep kids, small animals, hands and such away from the back while powered up), take a look in front of the projection lamp and see if the wheel is turning. if not, a very good writeup is available here, this is the writeup i send my own customers to if they feel like attempting the repair themselves.
replacing the color wheel is actually not very hard at all, if you have ever worked on your own desktop pc (installed a new drive or upgraded it yourself) then you should be able to do this with limited difficulty.
hope this helps,
Nov 16, 2007 | Samsung HLN4365W 43" Rear Projection...
Samsung hln617wx/xxa: color starts to blink or flicker after about ten minutes
8/25/07 Coincidentally, I have just run into the same problem. I spoke with Technical Service at Samsung yesterday and after 15 minutes on the phone they couldn't tell me what was causing it. I then did numerous web searches and came across a sight where technical experts discuss problems. Turns out it may be a problem with the Digital board, the A/V Board or the DMD board. Cost for repair (depending on which board it is) will run $400 - $1,000 or more. Repair man is coming out Monday to diagnose the set.
Jul 31, 2007 | Samsung HLN617W 61" Rear Projection HDTV
Samsung HCL4715W 47" Rear Projection Television Logo
63 people viewed this question
Jerry Greenberg
Jerry Greenberg
