Question about Refrigerators
Ge profile refrigerator mod# tcx18paaarbb
Evaporator drainage freezes drain pipe, ice builds up and jams fan blades. bottom freezer. takes about a week ??????????
  • Anonymous Mar 17, 2014
    model HTH17CPTZRWW, had ice-build up in freezer w/freezer back wall hot. Disconnected and emptied ice build up on wall & in vents. Now cooling but blade hitting wall on one side, so can't go fully around. Okay to bend blades?
    Problem Solver:
  • 5 Answers
Drain tube is blocked need to thaw it and after thawing clear drain tube all the way to condenser water tray in back
Posted on Apr 02, 2008
Water Pooling & Freezing
Assuming your fridge has a defrost cycle ( I.e. is a frost free model), you are probably suffering a blocked drain hole or pipe, leading to the top of the condenser or a tray nearby, where the frost water can evaporate.
The pipe can block with food or a mould plug, leading to water retention that freezes and further blocks the drain. the water is produced when a heater switches on in defrost mode and thaws the internal or external ice build up and, with nowhere for it to go it will pool on the bottom and may, when in defrost mode, run out onto the floor.
With frost free fridges/freezers, there is a drain outlet, usually hidden behind a removable panel inside the fridge/freezer compartment or, a drain hole near the bottom. If there is a drain pipe as well, access is usually from the rear base of the machine. The pipe is usually removable and can be cleaned out but prepare for some water to escape. An ice block in the drainage hole can be thawed using a hair dryer BUT GENTLY, so as not to warp the plastic inners of the fridge.
Jan 20, 2014 | Refrigerators
Frigidaire upright fridge freezer.The drainage hole at back of fridge part of item keeps freezing over blocking drainage from fridge
Yrur model number is missing the last three digits.... I will use FRT21H8CB1 as the example model number.
You need to do a total manual defrost with a catch basin and comprtment drain cleaning.
- Unplug the unit
- Remove fgreezer contents
- Direct an exteranl fan into the freezer compartment for just over 2 hours to ensure the compartment drain tube has defrosted.
- During the defrost period... open the fiberboard panel on the lower back of the refrigerator and clean out everything, Condensor coils, catch / drip pan (Called pan-defrost for parts), and the END of the compartment drain tube.
Model reference:
Defrost pan Item 26 of above link needs to be cleaned.
Coils Item 1 need to be cleaned
Fan blade Item 61 needs to be cleaned.
The evaporator trough, drain item 17 also should be clear. Here is what you can do without tearing everything in the back of the freezer apart. Once your sure the comprtment drain tube (no item number / bulk hose) is clean on the end. Use the exhaust of a Vacuum cleaner and the hose to force air UP through the drain hose and float out any debris from the trough drain. Have a 2nd person listen for air flow into the freezer compartment if possible. The biggest problems with freezer compartment drains is the END of the hose at the defrost pan underneath the unit clogs up and then the compartment drain hose just loads up with scum. Then the freezer stops draining and you have the symtom your describing.
After the manual defrost and cleaning return the unit to normal service.
Having said all of that... if the refrigerator then freezer starts warming up in 3 - 4 days... you may have an automatic defrost problem causing the icing. I.e it is not defrosting so the evaporator eventually ices over and forms an ice block in the back and bottom of the freezer compartment. Usually if there is an ice block that forms you wil hear the evaporator fan striking the ice build up.
If this is happening... for sure there is an automatic defrosting problem and your stuck doing a manual defrost ever 3 - 4 days until repairs are complete.
One more note.. if there is NOT any compartment drain tubing visible... your unit may port evaporator tray water down the back of the fresh food compartment to the defrost pan under the unit... just clean everything that serves as a drain function best you can during the manual defrost and cleaning process.
Thanks for choosing FixYa,
May 23, 2011 | Frigidaire FRT21H8 Top Freezer...
Hello I have a GE Profile with Brita refrigerator bottom freezer and it suddenly stopped cooling in the refrigerator portion. The freezer works but very weakly. Ive unplugged it, let it go for one hour,...
The drain is frozen up. The fan what provides the cooling air for the fridge is stuck in the ice. Remove the vegie crisper and pop the bottom under the crisper s out. Also remove the Styrofoam plate. You will see the problem right in front of you. Use a hairdryer to get rid of the ice build up. Good luck
Dec 07, 2010 | GE GDS18LBR Bottom Freezer Refrigerator
Freezer fan is making noise so I took all food out used a hair dryier to try and melt some of the frost/ice behind the back panel. Before this all the food had frost on them. This is the second time I did...
you need to have someone check the defrost circuit. if the unit does not defrost properly , ice will accumulate on the back panel where the evaporator is, blocking the evaporator fans completely, and the circulation fan will eventually stop working because the ice buildup contacts the blades all the fan motor, and eventually the refrigerator compartment will start to get warmer and warmer because there is no circulation of cool air.
Mar 16, 2010 | LG LFX25960ST Stainless Steel French Door...
There is a horrible humming sound coming from the freezer. It seems to be the fan that is behind the piece of plastic in the middle of the back wall of freezer. The sticker in the freezer says MODELS...
Hard to diagnose without being there and taking it apart. Based on my experiences, I suspect the defrost drain could be restricted. The defrost water freezes in place around the fans shrould and the fan blade hits the ice buildup. If the ice builds up enough the fan blade will be stopped and possible damage the fan motor. Access fan area to inspect and defrost (hot water, hair dryer or let it stand overnight off. DC evaporator fan motor WR60X10228 est $85
Mar 09, 2010 | GE Profile Arctica Stainless Steel Top...
Very thick ice collects in bottom of freezer
the drain pipe you cleaned out has a p-trap that holds water. after awhile this trap will build up sludge and possibly freeze up. i recomend defrosting the drain pan again and try some way to forcfully flush hot water thru the drain. I use a turkey baster filled with water to do this. if the drain continues to freeze you may need to install a heat trap to keep drain from freezing.
a heat trap is just a piece of 10-12 guage solid copper wire with about 3 inches in the drain and the other end wrapped around the defrost heater which is the BLACK rod attached to the bottom of the evaporator coil in the freezer compartment. if you need any further assistance just let me know Peyton
Jan 27, 2009 | Bosch Freezers
GE Refrigerator forms and Ice dam which stops the evaporator fan from turning.
is it defrosting theres a glass tube which is the defroster bar,there known to have these fail
Jul 07, 2008 | GE GDS20SBS Stainless Steel Bottom Freezer...
Evaporator fan blade jams in ice buildup
check the defrost bimatal or defrost thermanstat it will be located on the evaperator suction line (large line) it should read continuity with the ref cold if it showes continuity then the defrost timer is the problem
Apr 13, 2008 | Refrigerators
Evaporator fan jams with ice buildup from drain
Could be that, or it could be the temperature sensor on the evaporator - if that goes, then as soon as the freezer starts a defrost cycle, it will think it's got the evaporator hot enough and will start cooling again.
Suggest you let the freezer thaw out then, with a voltmeter connected across the terminals on the board which connect to the sensor, turn the freezer on and see if the sensor reacts sensibly to the evaporator cooling down. It's usually done with a thermistor, but just for the moment, I can't remember whether it's usually a PTC or an NTC.
That way, if it is the sensor, you'll be spared the expense of replacing a serviceable pcb.
Water pooling and freezing inside bottom freezer
I had the same problem with my LRFC25750 and have finally figured out what's happening! The water that is pooling and freezing on the bottom of the freezer is definitely coming from the defrost cycle. It is pooling inside the freezer compartment because the drain inside the back of the freezer intended to carry the defrost water down to the external evaporator tray underneath is blocked with ice. As a result, the defrost water from the coils overflows the collector under the coils and runs down the inside back of the freezer, pools on the bottom, and re-freezes when the cycle is over. this continues until there's so much ice on the bottom that the water from next defrost cycle runs out on the floor. The "easy" solution is to unplug the unit and let it completely melt out (this could take 24-36 hours). I couldn't wait, so I removed the freezer drawers and their tracks and pulled out the back panel inside the freezer -- saw the ice in the collector and blocking the drain and I melted it away with hot water and verified that water could now flow down to the external evaporator tray. Unless you want to do this, I'd say give it a good 24-36 hours for all the ice to melt away. I think it all started when we left the freezer door ajar for a whole day and probably had a lot of frost build-up on the coils. The next defrost cycle was not enough to clear all the frost and things began to build up from there. Once the drain is frozen, though, you're finished -- the defrost heater doesn;t reach down that far and you have to melt it down completely or it will continue to leak forever. I've heard that you can get a drain heater to ensure that the drain never freezes over or at least so that it is sure to clear with each defrost cycle. I'll post an update if I locate one.
May 21, 2007 | LG LFC25760 French Door Refrigerator
Refrigerators Logo
533 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
