Question about Refrigerators
Frigidaire Freezer Buzzing
The freezer started making an intermittent buzzing sound at the same time the freezer either defrosted or stopped operating. I turned the freezer setting to 0 overnight and then back to 5 the next morning. Things went well until the evening, at which time the same thing (buzzing, defrosting) happened again. I believe the fridge wasn’t cooling as well either, but didn’t measure the temperature.
Thanks for any help you may be able to provide.
  • 2 more comments
  • jlewishome Apr 02, 2008
    This is a Frigidaire side-by-side (P/N 240508016).
  • jlewishome Apr 05, 2008
    The model Number is FRS26HF7BWO.
    Thanks!
  • jlewishome Apr 12, 2008
    Thanks for your help...it is definitely the compressor. Do you have a recommendation for a replacement--good-value, white, side-by-side?
    The serial # is LA21500369. I'm pretty sure it's about 6 years old, so we've conceded we need a new one. We were thinking Whirlpool, so you're note on they're leaking is good to know, We certainly don't care about auto- and other features, just a good replacement.
    Thanks!
    President:
  • 1,314 Answers
Thats not a valid model number open the fridge door and look up at the top by the light bulb on a white sticker and ill try to help ok
Posted on Apr 04, 2008
  • 2 more comments
  • robert samples Apr 06, 2008
    if its a buzzing and clicking sound look ans see if the compressor has an Indian on it if its a techmshich compressor then it probably has to be changed
  • robert samples Apr 12, 2008
    whirlpool .Frigidare has a promblem wth leaky systems and keep it simple get manuel controls prime rule more features more to tear up
    also the Frigidaire has a five year sealed system warranty the compressor will be covered but you have to pay labor and use a frigidaire authorized tech now if its over five years old and you didn't send in your warranty card they don't know when you bought if you send me your serial number i can tell you when it was made
  • robert samples Apr 13, 2008
    whirlpool dont leak frigidaire does
The freezer side if frosted over.
Sounds like a fan caught. Empty and defrost fully, then restart and check all working
Apr 18, 2012 | Frigidaire Freezers
Buzzing in a full freezer with icemaker model no. 253.44133802
try cleaning vents/drain holes in whole unit this should allow more air to flow.also when did you last manually defrost whole unit.....
Feb 03, 2010 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Frigidaire FRS26R4AW5 buzzing sound not cooling
Something has stopped your compressor. The part could be the start relay, start capacitor, overload or the defrost control board. where are the buzzing sounds coming from ? Sea Breeze
Dec 20, 2009 | Frigidaire FRS26R4A Side by Side...
Model 596.73502203 Making intermittant buzzing sound. Moisture on inside of fridge and freezer. Food in freezer is thawing out.
I believe that your refrigerator may need a new 12002495 or 1184282 Adaptive Defrost Control You can find it inside the fresh food section and behind the controls for temperature. Not sure about the buzzing sound yet but the moisture and thawing of the frozen food points to a defrost problem. Need you to unplug and have a look at the adaptive defrost control. Would not hurt to open the back panel in the rear of freezer and defrost if needed and need someone to check the defrost heater and defrost thermostat. Sea Breeze
Aug 21, 2009 | Kenmore Refrigerators
Frigidaire side-by-side model # FRS26H5ASB4 making humming or buzzing noise
I had the same problem. I found the buzzing noise was caused by ice build up around the fan motor inside the freezer. I believe water must have leaked down around the fan during a defrost cycle. I removed the ice maker, the ice cube bin and ice dispenser auger motor. It sounds complicated, but it isn't too bad. The ice maker and auger are connected with quick connect plugs. So just unplug, remove the screws and remove them from the freezer. You will need to remove several other screws as well, I believe 11 in total as well as the top freezer rack. This will give you access to the white aluminum panel that runs from the top of the freezer to about halfway down the back of the freezer. After you remove the aluminum panel you will see the fan about half way down the freezer. I found a lot of ice around my fan. The fan blades were hitting the ice causing the buzz. Remove the ice and the buzzing is gone. It took me an hour to complete this repair. I hope this helps.
Nov 08, 2008 | Frigidaire FRS26H5AS Side by Side...
Candy fridge freezer
it should come back after about 20 mins only and should cool back after about 10 mins.
i'm afraid the buzzing sound could be coming from your compressor which can not start. the over current relay is tripping off after 20 seconds to prevent the compressor from burning up.
i suggest to unplug the ref, let it cool for 1 day, re plug it after a day and observe the compressor if would run.
if the buzzing sound is still there and the unit is no longer cooling, then the compressor is not running.
check the relay of the compressor. it could just be the relay.
tnx 4 using fixya,
drcool
Oct 14, 2008 | Candy CPCA240FFK Bottom Freezer...
Frigidaire gallery model plhs267Za
It sure sounds like a compressor problem to me. The buzzing sound is the compressor trying to start followed by a click which would be the overload protector tripping.
May 30, 2008 | Refrigerators
I have a frigidaire gallery model plhs267Za side by side fridge, I came home today and everything in the freezer has defrosted, it is making a strange buzzing sound on and off.. can anyone help? thank you
I THINK THE BUZZING IS THE COMPRESSOR TRYING TO START,ALSO LOOK ON THE BACK OF FREEZER AND SEE IF THE WALL HAS FROST ON IT,IF IT DOES YOU HAVE A BAD DEFROST HEATER OR TERMINATOR OR IT IS STUCK IN DEFROST,LET ME KNOW WHAT YOU KIND,ALSO YOU SHOULD UNPLUG IF YOU FIND THE COMPRESSOR IS TRYING TO START BUT WILL NOT,PULL OUT FRIG. AND SEE IF YOU HEAR THE CLICKING SOUND,ALSO PUT HAND ON COMP. TO FEEL IF RUNNING,BECAREFUL MIGHT BE HOT
May 30, 2008 | Frigidaire Refrigerators
Refrigerator consisently buzzing...freezer defrosted overnight
Not enough information to correctly offer , a diagnosis but, a buzzing sound could mean the compressor is attempting to start but can't. or it is running without freon. You will need a diagnosis from a certified technician for this issue.
Oct 18, 2017 | Refrigerators
Refrigerators Logo
684 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
