I have a Sirius Sporster 4 with the cigarette lighter as the power source. I would much prefer to wire to a hot wire from the vehicle so that it comes on when the ignition is turned on Please Can You Help me? it is being installed in a 2004 GMC Sonoma 4 door pickup.
  • retcop75 Apr 04, 2008
    May I get a second opinion some pretty good auto electrical types could not fix it. Thank you very much
  • 758 Answers
You can connect the ground cable somewhere in front of the car and the second one you can can connect it in on of the fuse in front of the car..find one that has power when you start your engine and doesnt power when you remove the keys...
Thank you
Computerrep
Posted on Apr 02, 2008
  • Jean Sintulaire Apr 02, 2008
    You will need a tester to find which fuse has power when your turn on your ignition...
How can I start using this?
1. Mount GPS in the vehicle using included hardware
2. Connect GPS to the vehicle's power source using included hardware (cigarette lighter)
3. Power on the GPS and Program personal preferences into the GPS unit
4. Demonstrate GPS functionality including how to find a point of interest, get directions, set-up a home location and save a destination
5. chose a suitable spot on the windscreen and Vacuum work area
to affix.
The basic GPS skills I suggest you first learn are:
1) how to set a waypoint of your current location;
2) how to enter the coordinates of a different location from a map or other reference source;
3) how to determine directions from your current location to another waypoint;
4) how to use the built in compass and altimeter;
Mar 27, 2016 | GPS
Cigarette lighter
check the fuse box inside the truck and under the hood 1 should be marked for cigarette lighter or Power Point or accessory if you did not out you need to pull the cigarette lighter from the dash so you can get to the wires in the back of the lighter and then test the wires with a test light to see if it's getting power probably just a piece that's what generally goes wrong
Jul 04, 2013 | Vehicle Parts & Accessories
Cigarett lighter power
The power wire for your socket is connected to the ignition switch. For the socket to operate without the key, the power wire must be relocated to a direct power source or directly to the battery. You can locate a "hot" source by using a 12Volt tester on the terminals of the fuse box. Just touch the tester to the terminals until one lights up without the key on. That terminal is "hot" and will allow your socket to have power at anytime. You should use a power source with a fuse for safety. You can hook directly to the battery but you should add a fuse inline to be safe.
Feb 23, 2010 | 2003 Toyota Tacoma
I purchased a used Cobra 19 DXIV cb radio that has a black & red wire with a fuse. I was told that the wires can be wired into the fuse box under my dash. How do I do this?
You may need a test light to do this.
1. Decide if you want the power to the radio to be full time or only when the key is on.
2. If you want part time the easiest power source to access is the cigarette lighter. You can either splice into the power wire going to the cigarette lighter (center lead) or you can get a cigarette lighter plug and install it on the end of your two power wires. Center is the positive. The plug costs about $4 and takes about 10 minutes to install.
3. If you want full time you will need to find a circuit that is hot at all times and splice into it.
Use a noise filter on the power as just about all circuits in the vehicle are liable to be noisy power circuits and this will show up in form of excessive static noise during radio operation.
The red with the fuse is your positive lead. Do not hook these up backwards as this will certainly ruin the radio.
Jan 17, 2010 | Radio Communications
My cigarette lighter doesn't work. I've checked all the fuses and they are fine. I have tried plugging in my cell phone and sirius power sources but they still do not work
Then the problem isn't the lighter element but the power source, are you sure you are replacing the correct fuse?
Check that power is reaching the end of the wire just before the lighter plug and trace back from there with a power tester.
Jan 09, 2010 | 2006 Volkswagen Jetta
94 Toyota Tercel DX. 4 door
it is fuse # 1 in the fuse box under the dash on the drivers side it is a blue 15 amp fuse
May 29, 2009 | 1994 Toyota Tercel
Laser alert
This is caused by electrical noise in your car's electrical system. Specifically, the problem is excessive alternator whine. This can be exacerbated by somewhat corroded contacts in your car's cigarette lighter socket or by a somewhat corroded vehicle wiring connection to the back side of the cigarette lighter socket.
One potential solution is to try a snap-on RF filter which is available at your local Radio Shack. You would snap this filter around the positive 12V wire leading to your car's cigarette lighter socket. Preferably, if there is enough free slack in the 12V wire leading to the cigarette lighter socket, you would wrap this wire through the RF filter twice before snapping the RF filter closed around the wire.
Dec 14, 2008 | ESD 7000 Radar Detector
Power supply to Sirius Radio
yes, some sirius radios work on 5 volts, and some work on 12 volts. Your sportster replay is a 5 volt unit. If you trace that wire back, you will find a cigarette lighter plug with a transformer built into it, with either wires soldered to the terminals, or a female cig plug wired up behind the dash. Whatever sirius unit you plan on hooking up, I strongly reccommend using the transformer that it came with......however if you're willing to take a chance, it's most likely 5 volts.
Aug 18, 2007 | JVC KT-SR1000 SIRIUS Radio Receiver
"buzz" when Sirius receiver is plugged into AUX input of new Camry
Did you have the unit installed at a shop that would have hardwired the power source? It sounds like either your power wire to the sirius unit is connected to a noisy power source (which is why you are picking up the alternator whine), or you have a poor ground connection to the unit. If it was installed at a shop, take it back and have them move the power source to the same wires that the radio gets power from. If you are using your cigarette lighter for power, unfortunately it sounds like your outlet doesn't give you the best source for powering an audio component. You might try stopping by a car audio shop and ask how much it would cost to hardwire the sirius' power to the back of your radio.
Nov 07, 2006 | Sirius Satellite Radio Sirius Starbase...
22 people viewed this question
 Grubhead
Grubhead
