Question about HP TFT5600 RKM (Black) 15" LCD Monitor
Password reset for HP TFT5600 RKM 221546-09 KVM
I have a HP TFT5600 RKM 221546-09 KVM monitor and keyboard. I lost power to the device briefly and it now is asking for a password to log on to OSCAR. If there ever was a password, it was set by my predecessor who did not pass it on. I have been told there is a way to reset the password.
  • thompsont01 Jan 05, 2009
    I have a HP TFT5600 RKM 221546-09 KVM monitor and keyboard. I lost power to the device briefly and it now is asking for a password to log on to OSCAR. I have been told there is a way to reset the password.
SOURCE:
  • 128 Answers
SOURCE: power on password
did you set the password from the bios settings? if so, reset your bios by opening your pc casing (be sure that its unplugged) locate the bios reset jumper (mostly found near the battery cell in the motherboard) take out the plastic jumper from pins 1 and 2 and set it to pins 2 and 3 and wait for about 10 seconds then put it back to its original settings ( 1 and 2 ). close your casing and start your pc
Posted on Oct 17, 2008
SOURCE: password on Hp protect tools... help me plz!
I have a compaq 6720s and I cannot remember my power on password to get into my system. Please help me. I do no know what to do.
Thanks Cherry
Posted on Oct 19, 2008
donovanm
  • 177 Answers
SOURCE: how do you reset the bios on an hp elitebook
Pull the battery, cmos battery, and power cord for 10-20 minutes
Posted on Sep 27, 2009
LaptopExpert
  • 458 Answers
SOURCE: need to know how to reset power on password for hp
If this is a BIOS Lockout Password, then you would need to Pull the CMOS battery From the laptop... Which most likely means Complete Disassembly of the laptop just to get to the battery... You would have to unplug the battery... Make sure the Laptops Charging Battery is also Removed and the AC Adapter is NOT plugged in...
Once the CMOS battery is removed, Hold the power button down for 30 seconds... then replace the battery and see if it is bypassed/removed..
There is a good chance that the BIOS password is on a security chip on the motherboard and if this is the case, then pulling the CMOS battery will do you no good... You will need to replace the motherboard if this is the case...
Posted on Nov 16, 2009
conradodav
  • 3 Answers
SOURCE: How can i remove the password in the HP MINI 1000
Hi all!!!
I just reset the bios password of my HP Mini 110, i tried to remove the cmos battery but it didnt worked it just reset the clock and the system date.
I search over a week in youtube / google and founf this link
http://www.youtube.com/watch?v=RwIqdUF2K2U
I unlock my netbook using the hash code generated after 3 wrong password attempts.
I think this may be interesting for everybody......
Posted on Jun 12, 2010
Dell deminsion 4700 when i moved it,monitor,mouse,keyboard quit.monitor briefly displays power safe mode.pressing any key don't help
When you moved your pc you probably knocked the graphics card loose. You can open it up and try re-seating it. Make sure you unplug the pc first and then press the on button for 10 seconds to clear out all the power from the power supply before opening the computer up.
Also, If you are using a KVM... Unplug the KVM's power cord for 30 seconds and plug it back in. That will reset it.
May 14, 2012 | Dell Dimension 4700 PC Desktop
How to connect my lcd kvm and make it display on sreen
You question is unclear. Please specify the makes and model of all devices. I typically use Rackmount Monitor Keyboard combos with integrated KVM Switches for larger server applications. I have used quiet a few units from KVMSwitchTech and they work pretty well.
Jan 18, 2012 | HP TFT7600 Rackmount KVM Switch
HPTFT5600 RKM Tracker Ball Connector colurs goto PS2 connector
Sorry to say but there is no standard on the color of the wrie used in any brand of the mouse or key board, I GOOGLE the PS2 PIN OUT and these are what I found: http://www.burtonsys.com/PS2_keyboard_and_mouse_mini-DIN-6_connector_pinouts.html
http://www.bbdsoft.com/keyboard.html
http://www.allpinouts.org/index.php/Mouse/Keyboard_(PS/2)
http://en.wikipedia.org/wiki/PS/2_connector
You need to find out about the wiring of your track ball. Brand and model? Hope this will help.
Mar 05, 2010 | HP TFT5600 RKM (Black) 15" LCD Monitor
HAVE 2 DESKTOPS IS THERE FITTING TO RUN BOTH OFF 1 MONITOR
yes. Its called a KVM (Keyboard video and Mouse) switch. it will allow you to use a single keyboard, mouse, monitor for multiple computers.
They can be found at most any major electronics store/website and, depending on how many machine you want to connect, can be very cheap or fairly expensive.
Jun 03, 2009 | HP Pavilion dv6000z Notebook
Compaq TFT5600 very dim display
shine a torch onto the screen. if you can see the images with light then it is a backlight issue.
Feb 25, 2009 | Compaq Rackmount TFT5600 15 LCD Monitor...
No vga by pushing port buttons
In order to fully answer your question, a number of needful things must be inspected, reinstalled, confirmed, & tested:
  1. Reset. Try the reset button. You could use a paper clip to reach the reset button through the pin hole in the lower front left of the Zonet KVM unit.
  2. Inspect connectors. Each data/input/power connector/port requires all of its pins to be present & straight for full functionality.
    1. Inspect the entire length of each cable & cord to ensure that each has no damaged area.
    2. Seat each connector in the appropriate port of a computer that will be accessed via the KVM unit.
  3. Electricity. Inspect all affected devices & confirm that each has sufficient, uninterrupted electricity.
    1. It is possible for a Zonet KVM unit to display channel lights without direct power to the unit, but you should confirm that the unit is getting sufficient, uninterrupted electricity-directly through its own power cord. Unplug the KVM power cord & every connector & reseat each one (this performs a power reset on the KVM unit)-making sure that each connector is in the correct location (not just where it originally was). Thus, make sure that the keyboard, video display (monitor), & mouse are on the output side.
    2. Press the power button on your monitor. If it does not turn off the monitor's power status light (Off/On/Standby), then remove the power cord from the monitor & reseat it-to reset the monitor's hardware. If it does not turn on the monitor's power status light, then the monitor is either not getting enough electricity or it has a malfunction which requires troubleshooting & fixing (possibly through a fixya.com thread for that monitor model).
    3. Unlike USB devices, PS/2 devices usually require device connection prior to turning on that device. With that said, connect the keyboard & mouse KVM channel cable connectors to the computers & then turn on those computers that you intend to display through the KVM-connected monitor & then turn on these computers.
    4. Any computer that does not turn on has an issue that requires resolving (just like a monitor that would not turn on).
    5. Sometimes a keyboard/mouse interface issue can be resolved by replacing that interface device.
  4. The KVM Unit. When all else properly connects & performs, what does not properly connect & perform has the issue &, hopefully, that can be repaired without having to replace it.
Nov 09, 2008 | Zonet Computers & Internet
KVM hotkey
Hold down the Scroll Lock key for several seconds. The switch should beep briefly and blink. Hit either the "1" or "2" key on your keyboard to switch to the corresponding computer connection.
Jun 23, 2008 | LinxCel PS-121D 2 Port PS2 KVM Switch
Lost login Username and Password
How do I use the reset the password on my DES-3226?
Nov 14, 2006 | D-Link DES 3226 (DES-3226) 24x10/100 Mbps...
Password Override
The switch must be reset. Disconnect all the devices cables from the switch, power off the KVM switch, wait 10 seconds, then reconnect the cables to power up the switch.
Sep 30, 2005 | HP Console Switch KVM Switch
Open Questions:
See all HP TFT5600 RKM (Black) 15" LCD Monitor Questions
Computers & Internet Logo
753 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
