Ms7235 My computer keeps crashing we have taken every thing out that is not needed but still having problems tested memory etc ??? could the mother board be at fault
    Master:
    Sergeant:
  • 482 Answers
Yes
Posted on Apr 03, 2008
I turned on the power but the computer does not start or boot up
With whats going on it sounds like it could be one of three things. Your power supply has fizzled out, one or more sticks of you memory has died off, or your CPU has taken a plunge off the deep end. It could also be the mother board but most of the time its one of the other three things. Best thing to do is first have the power supply tested, then move on from there. If you can't/don't know how to test any of your hardware then its best to take it to a shop.
Best of luck
May 30, 2011 | Computers & Internet
My dell 1501 is crashing constantly with usually a striped screen. I updated the bios and the problem is not OS related because I did the PSA test which the computer passed and while doing the extended...
i would center your fault finding around the gpu as that is a classic symptom of a graphics malfunction, if it was the lead or screen the computer would still respond , the fact its not suggests, to me , that your gpu is overheating or has a short
Mar 27, 2011 | Dell Inspiron 1501 Notebook
When I turn on my packard bell ixtreme 6052 nothing appears yet it does see computer but does not even go to bios and harddrive read light remains on and harddrive is constantly ticking like it's...
This could be lots of things (bad HD, bad Mother board, bad RAM,etc...) first you need to narrow down the possible cause, open the computer, take out every thing that can be unplugged (I MEAN EVERYTHING) RAM, PCI cards, VIDEO cards, all storages HD, CD ROM, etc... just leave the CPU and power supply plugged in, than power up the computer and listen for BEEP's if you hear a series of BEEP's this means the CPU, power supply and mother board are GOOD, than (with power OFF each time) re-install the components you taken out (ONE at a time) to see which device causes the system crash... I've seen a modem card causing a system mall function once rediculous but true...
Feb 20, 2011 | Packard Bell Computers & Internet
Blue screen of death
Thanks for the info. I would say a software driver error but seeing as you've already re-formatted I reckon it's probably a RAM error. Irql_not_less_or_equal is a bad pointer in memory. 2 things you can do to check.
1. Use microsofts memory tester which needs burning to a cd
http://oca.microsoft.com/en/windiag.asp#top
2. If you have 2 memory modules, take one out. If it crashes, replce with the one you've taken out. If it still crashes try the same proccess in the other memory slot. If it STILL crashes then it's most likely a motherboard fault, in which case I'd recommend you take it somewhere to get tested out.
Dec 13, 2009 | Computers & Internet
Comp does not turn on. green light off but goes on when mobo disconnected
Test the power supply in another computer.
If that works, the next thing is to check the mother board. Remove all daughter boards from the slots. Remove all memory, disconnect all hard drives, cdroms, etc.
Make sure there is nothing plugged into the mother board except the video cable (if it is on-board video), if not, then make sure you have a good video card plugged in.
Again with no memory, no boards except a video card, if needed, and the power plugged into the board.
Turn on the power, and watch the screen. If it works, then you should get a notice that there is no memory, no hard drive, and so on.
If that is the case, then proceed to install one item at a time to isolate the problem. If it is not the case, the the mother board is probably bad. One other thing to check would be the CPU.
If you get no notice with the above, then the cpu could be bad. Check it in another computer, if possible. This should tell you what the problems are or is.
In the above cases, either the cpu or the mother board can be isolated to see what is bad, if any.
Oct 07, 2009 | HP Computers & Internet
Emachine will not power up
By nothing else, from a technical standpoint this would mean literally nothing, the CPU fan, power supply fan, aux fan, disk drive not spinning up, etc. My experience with EMachines is their motherboards aint the best, have been known to take out hard drives and other peripherals to the mother board. If you are technically inclined the first thing to do is to bare out the system, Power Supply attached to the Mother Board w/ Cpu Monitor and Keyboard no Hard Drive and no Non esential boards installed, very carefully remove the memory and start it up all should be fine except it should give you a long beep from the PC Speaker indicating the Mother Board is aware there is no memory installed if it will not do this most basic of tests this is not good. If it does give you a health beep continue to install one item at a time, first the memory, the display should, if working, tell you there is a boot failure, of course, the hard drive is not connected, do so and keep on testing. Without knowing what type of mother board you have, most likely an AT with integrated peripherials the process to determine exactly what the problem is would take hands on trouble shooting. If you dont get the beep indicating the mother board cant determine if memory is installed and truley nothing else is on it is more likely the mother board. There are several good ones online that will fit your case if you want to go this route. Or is it time to upgrade ?
Jun 04, 2009 | E-Machines eMachines Desktop PC
Motherboard
Sounds like you tried everything except reseating any other hardware that may or may not be placed in another socket such as PCI, AGP, etc... Like a Modem, Network adapter, Sound/Graphics card, Wireless card, etc... This is probably a wasted post as if you knew to check each stick of memory seperatly then you've probably already reseated all socketed hardware. Though, you could remove all non essential hardware such as I mentioned above and try installing Windows again?
Good luck and keep us posted.
Sep 06, 2008 | Dell Dimension 8400 PC Desktop
No signal to monitor when booting.
(1) Remove memory from mother board and start the system if you happen to listen long beep then RAM is not working properly.
(2) Clean RAM conducting area on mother board with clean cotton cloth, put one peice of RAM and test and check the othe peice also, if working you could any sign display . Before doing all these check mother board any LED is glowing if so your SMPS is working after you turn on UPS.
(3) Check for all proper connection for all cables. Have you connected video cable of monitor to mother board VGA (it will not work because it is disabled as soon as you installed XFX GeForce 8800 GT), your viedo output only will come through XFX GeForce 8800 GT VGA port.
(4) If propelm persits Deassmble complete the system and reassmble & do n't connect HDD, DVD, floppy. Cehck with bare mother baord, processor, RAM (put one picese at a time) by connecting viedo cable of monitor
Apr 19, 2008 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Toshiba A105-S2101 keeps crashing!
Sounds like a memory 'leak'. Just because it's the 'correct' memory, doesn't mean it's not faulty. I would have them exchanged.
You can run a Microsoft memory diagnostic program to determine is they are faulty.
The software is free from Microsoft from here:
Also, always try to stick with a 'known' brand (kingston, samsung, etc).
Jan 20, 2008 | HP Pavilion dv1000 Notebook
Corupt harddrive
I am sorry if I don't understand, "the disk to crash my p.c."? Do you mean that you don't have the disk to get p.c. fixed that crashed? Your p.c. crash and you can't get going? 1) What kind of p.c. do you have?[Dell,IBM,Compaq, etc.] 2)How much memory?[RAM that turns on the p.c.] When the memory chip goes bad,or in moving the pc, the chip can be phycically disconnected from mother board.Will provent pc from turn on. Win 98, win_me, Win_xp:: What o/s[operating system] do you have? dmsr3@juno.com
Sep 26, 2007 | Lenovo IdeaCentre K210 Intel Desktop...
Computers & Internet Logo
David Payne
David Payne
