Question about Oster 76076-010 Hair Trimmer
Blade installation i cannot figure out how to install the blades in my oster turbo a5 pet clippers
  • 2 more comments
  • Anonymous May 04, 2008
    I can't the blades back on the trimmer so they stay on.
  • devilboi Jun 03, 2008
    i cant get the blade to stay on
  • Anonymous Aug 10, 2008
    I have the same problem, unable to get the blade back on my Oster clipper any which way. Was able to get it on the first time I used it two weeks ago. Help.
  • Anonymous Nov 23, 2008
    It seemed easy in the store. Now I can't do it.
  • 4 Answers
I had the same problem and i fixed mine ( it is not broken) ... the tongue is the thing that is silver and has grooves that face upward, the tongue should be up compared to pressed against the shave, take a small screw driver or a kitchen knife and get under the tongue and lift it up, once this is done you need to slide it on the blades and snap it down, i found that i did not need to have the clippers on to put it back on.... at first i got confused in thinking that the tongue was the red thing at the top, and in actuality this is the thing that moves the blades to clip.... i hope this helps, once you get the tongue up the blades are on in 10 seconds...
Posted on Aug 14, 2008
6ya staff
SOURCE:
How do I change the blade?
There is a small button at the bottom edge of the blade, push it in and at the same time push the blade teeth away from the clipper. The blade will hinge away from the clipper, you then lift the blade up off the tongue. When fitting another blade pop it onto the tongue, turn the clipper on and snap the blade shut.
Mar 31, 2015 | Oster Turbo A5 2-speed Dog Pet Clipper...
The brand new gear lever on my oster a5 isnt moving the clipper blade
make sure the blade is clicked into place fully, secondly check to see if the blade is sitting further away from the clipper than usual, it could also be a stripped gear inside the clipper does the lever move when the blade is engaged?
Jun 21, 2014 | Oster Turbo A5 2-speed Dog Pet Clipper...
Oster clippers
it could be metal fatigue from the blade. Try a different blade and see if it does the same. If it is still rattling it could be your blade drive needs to be replaced. Sometimes the screws that hold the blade drive in place come lose or striped so you may need to check them.
Apr 23, 2013 | Oster Turbo A5 Two Speed Clipper - Blue
Does someone know which # blade to use with the Oster, universal comb set for use with the Oster A5 turbo clipper?
Hi, as far as I know you're suppose to use a size 10 or 30 blade with any combs. I prefer to buy a longer blade like a size 4 rather than using the combs as I find the coat finish not great with the combs.
Feb 06, 2013 | Oster A5 Turbo Clipper Kit-10,40 Blades&5...
Oster A5 clippers work briefly then "pull" hair
Lever arm worn, blade blunt, or loss of movement inside the gearbox. It is possible to have a 'bad' sharpen.
Aug 03, 2012 | Oster Golden A5 Single-Speed Clippers
Run but will not cut
Are you sure you have Andis A5 or did you mean Oster A5 Clipper, if this clipper is A5 Clipper, You need to check the Lever for wear, The front of the Lever show wear on both side, Like white color and is not squad this Lever is worn. Need to replace. This Lever moves the blade side to side fully. if the Lever is worn the blade will not move fully side to side and the cutter blade the smaller blade will stay in the middle with hardly no travel to side to side and will not cut the hair even if you purchase new blades. Also I would like to mention if the Oster Locking Hinge is worn out and don't have the require tension to hold the blade in place the blade will not cut. How do you test the Oster Hinge on a Oster A5 Clipper,
(1) first close the hinge, in close potion with your finger nail try to open the Hinge, if the hinge slightly open or opens loose the Hinge is worn. if the Hinge is good it will not open or move and your nail may just brake your nail.
Many of my customers run into this type of problem, and the problem can be solve easily by checking these parts first.
One more item I would mention here if replace the A5 Hinge make sure you get the A5 Hinge not the Oster 76 Hinge they are driferrent, The A5 Hinge has on the back two wire's sticking out that fit on the Oster Latch for the A5 Hinge, the Oster 76 Hinge would not have these wire's on the back. I recommend replacing the Latch when you replace the Hinge. I hope this helps any body that have a A5 Oster clipper or A Oster 76 Clipper.
I have over 20 years in the repair business of Sharpening & Clipper repair. Mannys Sharpening 323 263-4697
b61c252.jpgOster Hinge
Jun 10, 2009 | Andis Outliner II Hair Trimmer
Blade change problem & no info in enclosed instructions
Hi A5 blades are not made to be unscrewed. They are snap on blades. You can call 800-830-3678 which is Oster Direct consumer service. They will walk you though the process or you can send them back to Oster and they will put them back together and realign them for you. Hope that helps.
Mar 31, 2009 | Oster Golden A5 2-Speed Universal Motor...
Oster 76076-010 Hair Trimmer Logo
351 people viewed this question
Top Oster Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Falling star
Ross Keen
Are you an Oster Health and Beauty Expert? Answer questions, earn points and help others
