Question about Philips 55PP9352 55" Projection Television
Philips HD 55PP935217
When the TV is on there is a white halo/shadow effect on the picture.  I've adjusted the colors and brightness and every other setting I could think of that might make a difference but nothing got rid of it.  I've even reset back to factory settings and nothing.  Has anyone else had or seen this before.
  • Cloudy in SJ Apr 02, 2008
    Thank you!  Can you recommend a reputable place to do the work?
  • Cloudy in SJ Apr 07, 2008
    Hi Mike,
    Where is your repair shop located? I would like the coolant to be replaced by someone who knows what they're doing.
  • 206 Answers
Afraid this is a common problem with Phillips, what happens is the coolant in the CRTs becomes contaminated, this is most common in the Blue and green, So what you have to do is have the coolant changed. Here at our shop we charge $250.00 for this. For most TV newbies this is money well spent. We have see coolant changes go horrible wrong, Anything from a coolant leak, broken CRTs, relay bad convergence after the repair, to the relay bad of a small leak that will destroy or burn your TV set down. Best bet is to get a repair shop that has the tools and expertize to do this for you
Posted on Apr 02, 2008
Colors on my TV seem to be washed out. Convergence is adjusted OK, brightness/color/tint settings don't seem to make a difference. I seem to have bright halos around all light colored images.
The fluid in the picture tubes needs replaced. It is a job for a professional. It usually costs about $250.00 for the job. You might say it's like giving your set an oil change.
Apr 09, 2011 | Philips 50P8341 50" Rear Projection...
Faded and bright
Dull Video...
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
* Screen Looks 3D, Warped, Distorted, etc
* Colors do not line up
* TV may shut off - and make a chirping sound.
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya
May 17, 2010 | Philips 60PP9352 60" Rear Projection...
51'' Philips rear projection TV with color issues
Philips has had a big problem with there coolant fluid becoming cloudy. The only way to clear it up is to have the fluid changed. With every projection crt tv there is a layer of cooling fluid between the face of the crt and the lens. This coolant cools the face of the crt. Over time the coolant breaks down and the light coming through gets distorted. The crt's have to be removed from the set to do this.
Oct 13, 2009 | Televison & Video
I have a Philips 55pw936317f 55 inch tv that has pic problems.
Same problem here, wish I knew how to fix it... I noticed it can be helped a little if you adjust the convergence from the menu using the remote though.
Aug 29, 2009 | Philips Sport Personal CD/MP3 Player
Phillips hd tv
convergence i.c.s change both of them even if only one color is out. if one is bad the other is usually going to give out soon. the part # should be. stk 392-120. also check resistors around i.c.s if the open you wont be able to adjust convergence.
Mar 20, 2009 | Philips 55PP9352 55" Projection Television
White halo around lettering
Do not adjust any knobs as instucted in the previous thread if you TV have a convergence problem. Doing so will only make things worse. The blog does however show you how to fix other common problems with these sets.
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Feb 24, 2009 | Philips 55PW9363 55" Rear Projection...
Picture is multi color, double shadows, curved
This is failure of convergence out ICs in TV. Qualified TV tech will replace convergence out ICs or board.
Feb 14, 2009 | Philips Televison & Video
Dull picture, whites have halos, need to watch tv thru dvd player
the picture color problem is the coolant in the CRTs. You can get the coolant replacemnt Kit at the following link. The other problem with the Input through DVD sounds like the signal board. You can get the replacement board and the Phillips CRT coolant kit at the following link.
Sep 14, 2008 | Philips 60PP9202 60" Rear Projection...
Philips 55 inch hdtv rear projector
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from that includes replacement coolant, photos. instructions, etc.
May 21, 2008 | Philips 60PP9363 60" Rear Projection...
51 projection tv dark colors
Nov 20, 2007 | Philips Magnavox 51MP392H Rear Projection...
Philips 55PP9352 55" Projection Television Logo
170 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
