Question about Kitchen Ranges
Kenmore Range clock issue
I have a Kenmore range model #911.95969790. The clock is in 24 hour (military format) and I would like to change it to 12 hour format. I have contacted Sears and they were not able to help. I'm assuming because it is not in there manual. I know it is not in my manual either. I even took the range apart and found the manufacture of the circuit board (Robertshaw Control Company) They were not able to help either. They said it was designed by Sears and I would have to keep trying with them. So I'm stuck if you can help that would be great if you need more info please let me know.
That works, to change from military 24 hour to 12 hour format press and hold the clock button until it beeps and changes the displayed time, e.g. from 20:01 to 8:01. This worked on my Kenmore Elite Range. If you get the dreaded F1 error, you'll likely have to replace your clock timer board.
Posted on Mar 11, 2009
    President:
  • Kitchen Ranges Master
  • 2,651 Answers
I looke this up and found to be a roper range, although im unable to find anything out in any manual ( roper tath is a bout a 24 hr clock feature) all are listed as 12 hr clock not showing am or pm.
jus for giggles did you try holding the clock button in for 3-5 secs. that usually toggles the clock display on/off. but you neverknow. and withouth knowing exactly what model roper range it actually is no way to look up that particular user guide. approx how old is it?? im sure you did but did you try disconnecting ppower to unit for a fdew momnets to perhaps reset the control??
Posted on Apr 03, 2008
How do I convert clock from 24 hr display to 12 hr display on my GE profile gas oven with digital display?
Here are the instructions for changing the clock from 12 to 24 hour and back.
12-Hour, 24-Hour or Clock Black-Out
Your control is set to use a 12-hour clock.
If you would prefer to have a 24-hour
military time clock or black out the clock
display, follow the steps below.
Press the BAKE and BROIL HI/LO
pads (on models, use
the upper oven controls) at the same
time for 3 seconds, until the display
shows SF.
Press the CLOCK pad once. The
display will show 12 hr. If this is
the choice you want, press the
START pad.
Press the CLOCK pad again to
change to the 24-hour military time
clock. The display will show 24 hr.
If this is the choice you want, press
the START pad.
Press the CLOCK pad again to black
out the clock display. The display
will show OFF. If this is the choice
you want, press the START pad.
NOTE: If the clock is in the black-out mode, you
will not be able to use the Delay Start function.
Oct 04, 2017 | GE Kitchen Ranges
Cant change clock from military to 12 hour
I don't know which brand or model your were talking about, but usually if you press and hold the clock button down, it will change from 12 hour to 24 hour (and back).
Nov 08, 2016 | Kitchen Ranges
Change 24 hour clock non military time
You could select the 12 Hour clock mode instead of 24 hour as it may be set at now.
Also it needs to be confirmed if the audio system fitted to your vehicle supports 12 hour clock. Please check the two documents below after turning to the section on Clock setting. The menus to set this could vary depending on which audio system you have.
http://www.landrover.com/imagery/market/us/en/pdfs/range-rover-quick-start-guide
http://www.landrover.com/imagery/market/us/en/pdfs/range-rover-sport-quick-start-guide
Aug 29, 2014 | 2007 Land Rover Range Rover Supercharged
I want to change the time from military to regular, but my bose does not have clock set just and arrow to the right and left for time
The manual is available at Bose.com and page 17-18 shows the detail.
To set AM/PM (12 hour) or Military (24 hour) time - Press the On/Off button once to turn your Wave radio off.
Press and hold Clock Set, and then press On/Off to switch between AM/PM (12 HR) or military (24 HR) formats
May 02, 2011 | Bose Wave Radio
I want to change from military time to regular time on my Bose wave radio. I already tried holding down the alarm set button and on/off button but it didn't work
Page 18
http://www.retrevo.com/support/Bose-Wave-radio-Radios-manual/id/525bh044/t/2/
Jan 27, 2011 | Bose Audio Players & Recorders
Time is on military time how do i switch it back
Hi, from page 6 in the owners manual it says:
"Setting the CLOCK
1. Press CLOCK pad. Indicator word TIME
will flash in the display.
2. Press the appropriate number pads for
the current time. (Time is in a 12-hour
format.)
After a power interruption, the last clock time
before the interruption will flash."
The timer goes up to 99 hours and 59 minutes, maybe that is what your seeing.
Jan 22, 2010 | Maytag MER6772 Gemini Electric Kitchen...
How do i change the time back to regular rather then military time
This is for the Bose Wave Radio. If you have a different model just let me know. I also included a link to the manual just in case you don't have one
Hope this helps.
To set AM/PM (12 hour) or Military (24 hour) time - With the system off, hold down Alarm Setup and press On/Off to switch between AM/PM (12 hour) and Military (24 hour) time formats.
http://www.bose.co.uk/GB/en/images/Wave%20Radio%20CD_tcm6-4104.pdf
Nov 23, 2009 | Bose Audio Players & Recorders
Clock is stuck in military time & I can not get it to go back
The newer Dacor ER36D can by switched from standard 12 hour to 24 hour military time mode and back by holding the CLOCK SET button for 6 seconds. That may work on older models as well.
Feb 28, 2009 | Dacor Epicure ERD36 Dual Fuel (Electric...
The digital clock seems to be set to 24 hr insted of 12 hr time
No Problem here ya go
To change the clock to 24-hour format:
1. Press and hold the CANCEL and Delay
pads for three seconds.
2. Press the More+ or Less - pad to select
12 or 24 hour.
Jan 14, 2009 | Maytag MER5552BAW / MER5552BAQ /...
Bose Clock
Feb 18, 2008 | Bose Wave Radio
Kitchen Ranges Logo
515 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
