Question about Yamaha RX-V800 Receiver
Yamaha RX-V800 Zone 2 Operation
Has any had any success getting this receiver's Zone 2 feature to work? The manual provides no direction, but says it's available. I have it connected properly, but can't find anything in the menus to turn it on.
Please Help!!!
Thanks,
BigSoxFan
  • Anonymous Apr 29, 2008
    how to operate zone two amplifier
Is there a way to work both zones simultaneously?
Posted on Jul 23, 2008
There is no zone B only speaker A/B. I have speakers assigned to A and B and also want to use Zone2 for a separate set of speakers but no luck either.
Posted on Jun 18, 2008
    Sergeant:
  • 243 Answers
Yes it works great. hook them up to zone B. then below the power button is a A/B button. select button B and then zone B will work.
heres the manual if it helps
Posted on Jun 14, 2008
SOURCE:
Yamaha receiver RX-V663
Make sure you have an analog RCA audio cable from the source to the receiver. Digital coaxial or optical will not work for zone 2 or zone 3. By adding an analog cable it will not affect your main zone, it will always go to digital first. Hope this helps
Dec 29, 2009 | Yamaha RX-V663 Receiver
Rx-v800, have a problem when i swtich the input mode, it will turn off. after leave it for few months, now no problem but not sound.
Test an audio source like "DVD" connected to the "Direct" input with left,center,right,rear,andsub input. put the receiver in "Direct mode" if you get audio, the main DSP chip is bad, get an estimate first since it can only be verified by bench testing the unit. It's not a cheap repair 400-500 range. Most new Yamaha receiver's in the modest range run 500-800- new. Hope this helps
Nov 08, 2009 | Yamaha RX-V800 Receiver
No picture from wii
The RX-V800 switches the various video signal types separately.
Since you are feeding S-Video to the TV the composite (yellow) input from your Wii is not going anywhere.
If you cant get S-Video output from the Wii then I'd suggest a simple Composite to S-video adaptor plug ($5 say). It worked for me with a Game Cube.
Cheers
BJ
Mar 19, 2009 | Yamaha RX-V800 Receiver
Yamaha RX-V663 Multi-zone question.
i just got the same receiver like few days ago im still leaning it too,it is a very nice receiver though. here is some settings to help you.
check this to make sure zone 2 is showing in the menu,
on remote
menu,basic setup, speaker set,extra should show zone 2 it might show zone b...presence...or none needs set on zone 2 hit the left a-e/cat button it is weird the right doesnt circle all around? i had to call crutchfield tech for that one(GREAT COMPANY!)so that is for the setting to make sure zone 2 is set up now some to adjust the volume.
menu, manual,options,zone 2 set. here you can set 2 features
max volume( the loudest it will play) inti vol(the volume that it will play at when it is turned on) the yamaha has alot of quirks to it but has a very nice sound. for second zone features and a easier receiver to set up i have onkyo and they are very easy to set up zone 2 olume and everything on the front panel. hope you dont have to try to program a universal remote to work it seems yamaha uses discrete codes that are impossible to find i tried one universal and can only get very basic features to work.
hope this helps you out,
jeff
Jul 29, 2008 | Yamaha RX-V661 Receiver
Yamaha RX-V 800
give me more details of trouble... let me give you advise if it can be done. 800 does not have industry standard parts mostly by yamaha only or made to order by yamaha. I have the same unit before, i have the manual too.
i use to work with yamaha service saudi arabia 6 years
Feb 24, 2008 | Yamaha RX-V800 Receiver
Yamaha RX-V800 Composite Video Signal Problem
Hey there fontdude, I will begin assuming you are running your a/v cable into your receiver and then out to the TV or Monitor. If this is the case, I suggest you run the video cable direct from DVD or VCR device to Tv/monitor. You can still run the audio through your receiver. The nature of your problem was probably related to video signal strength being weakened as it ran through your receiver. Good Luck! Let me know how it works for you.
Feb 09, 2008 | Yamaha RX-V800 Receiver
Yamaha rx-v800 remote control's damaged
it can be accessed via the main unit controls but you need to go through your manuals. Maybe you can get your remote repaired still... maybe not badly damaged caused by corrosion.
[email protected]
Feb 04, 2008 | Yamaha RX-V800 Receiver
Problem in yamaha rx v800
Hello!!! Are you electronic technician? You should see the transistors Q22A, Q22C, Q19C e Q19A and its drivers on Main Board. All the best, Rasgador
Aug 03, 2007 | Yamaha RX-V800 Receiver
Yamaha RX-V800 Receiver Logo
211 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
