Question about Refrigerators
Soda can busted in frost free freezer....need tips on how to clean frozen soda up
  • 109 Answers
Defrost freezer by turning off fridge. open freezer door, use a hair dryer on freezer compartment to thaw it out,(first remove all good frozen food to a cooler), then simply wipe up the mess. turn fridge back on and reinstall frozen food from cooler.(
Posted on Apr 03, 2008
Model EEV-163F Whirlpool Upright Freezer. Defrosted this week, already seeing ice buildup. Freezer is cold and appears to run fine, but frost buildup seems excessive this quickly. Frost throughout
This freezer is not frost free. Being an upright limiting the amount and frequency of opening the door will reduce the build up of ice. Ice is expected and depending on humidity and quality of seal around door affects the amount of ice.
Using a thin ribbon check the seal integrity around the door. Confirm nothing is prohibiting the full closure of the door.
Adjust door if necessary. Replace seal if defective. Freeze open unsealed items in a frost free freezer before locating frozen food in this unit.
These units are likely located in the garage where the humidity is high. If used only as needed planning transfer between this and the kitchen unit frost can be minimized.
Being a conventional freezer not frost free freezer burn is less likely and frozen food will not dry out as quickly. Confirm that the freezer maintains about 0 degree F.
This unit is likely more efficient and will maintain the food frozen longer in the event of power outage.
Hope this helps?
Jun 24, 2017 | Whirlpool Refrigerators
Tip
Defrosting Tips for Your Fridge & Freezer
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Defrosting fridge/freezers is much easier with a two-control model. That way, you can use the fridge to keep foodstuffs frozen while you deal with the freezer.
Are you thinking of defrosting method for your freezer or fridge? Then check this out.
Always switch off and unplug the freezer before cleaning or defrosting.
Load the contents of your freezer into large dustbin bags and cover the bags with a duvet or blanket. The food should stay frozen for several hours. But use a cool box for ice cream or soup which melts quickly.
After defrosting, wash fridges and freezers with a solution of two teaspoons of bicarbonate of soda to 1 liter (2 pints) of warm water-it removes lingering smells.
Rub the inside of your freezer with glycerine, available from chemists, after it has defrosted. When you next have to defrost it, the ice will come away from the sides more easily.
Use a wet/dry vacuum cleaner to **** up any water left on the floor.
If you do not like defrosting, you can always pay more for a frost-free freezer which never needs it. www.victorwod1234.blogspot.com
on Apr 05, 2010 | Refrigerators
IHave a ge side by side refrigerator not cold enough and freezer has frost on back wall and some items are not frozen
your GE self defrost is not working. 1. clean the ice and look for the heater element and your lemi switch. If you have a GE profile, they have a motherboard at the back of the ref. if all i the part i mentioned are working, just replaced the motherboard. at searspartdirect.com
Apr 06, 2013 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Freezer runs but won't keep most foods frozen even on coldest setting
Check condenser clean and fan working. Check it's not frozen solid because you've been running it full pelt; if it is, fully defrost it then set it at a mid range setting.
May 13, 2012 | Kenmore Freezer 20.6 cu. ft. Frost Free...
My freezer is a frost free upright, there is a pool of frozen water on bottom shelf. The 2 glass shelves and back have a layer of frost. Some food is unthawed. I thought maybe door was left partially open,...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 31, 2010 | Refrigerators
Food not totally frozen, icecream melted
if it a frost free freezer then chances are it is a defrost hearter, fan motor or defrost timer
if it is not frost free then it will either be the compressor or a gas leak ( which should be under warranty)
Apr 29, 2009 | Frigidaire 16.8 cu. ft. Upright Freezer...
Freezer alarm is going off and water is coming out below our frost free freezer
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Dec 23, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
SMELLY FRIDGE
I would move the fridge and check what is under it.
Dec 07, 2008 | Kelvinator 12 cu. ft. / 340 liter Chest...
Frigidaire Frost Free Commercial Freezer
The drain has most likely frozen over. It is at the bottom behind the back panel inside the freezer. You will need to remove all of the ice and run hot water down the drain until it is clear.
Nov 16, 2007 | Freezers
Refrigerators Logo
109 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
