Monitor is flickering
Monitor screen is flickering and or rolling wavelike
  • tweeko_44 Apr 02, 2009
    at 60hrtz the wave lines shows on my acer lcd even on my television when conected my acer monitor isn't 1 year old when i put it on 75 hrtz witch it sets itself after instaling thedriver the screen flickers .. acer is junk its like 7 months old lcd !! i think its my gforce 7600 and their sly technoligy it sux we got ripped off cuz why in god's name would my tv do it too !
    Sergeant:
  • 349 Answers
Make sure you do not have your speakers close to the monitor as the magnets can cause this problem ,also power boards will do the same thing.
if these are not the problem, it maybe that the monitor is on its way out.
good luck
Terry
Posted on Apr 03, 2008
My screen keeps flickering and its only two weeks old
Step 1 Change the refresh rate to match the capabilities of your monitor. The refresh rate is a measurement of how many times the screen redraws each second. Although this setting is related to older, desktop monitors, it can affect the quality of the Liquid Crystal Displays found in laptops. Right-click the desktop and choose "Screen Resolution," then click "Advanced Settings" and "Monitor." If enabled, place a check beside "Hide Modes That This Monitor Cannot Display" and choose a higher refresh rate from the list.
Step 2
Update your graphics card drivers. This is the most likely cause if you've always had a problem with flicker. Look for "Hardware and Sound" in the Control Panel and click "Device Manager." Under "Display Adapters," you'll see the exact brand and model of your video card. Go to the manufacturer's driver Web page and search for this model to download the appropriate drivers. Alternatively, you can revert to an older driver if the flicker began immediately after an update. In this case, return to the Device Manager, right-click your adapter and then "Driver." Click "Roll Back Driver" and "Yes" to confirm.
Step 3 Turn on Vertical Sync if the flicker occurs when DirectX or OpenGL is in use, for example, while playing a PC game. Vertical Sync, or VSync, locks the refresh rate of the application to the refresh rate of the monitor. Horizontal flicker is reduced, which improves image quality. For Nvidia cards, VSync is found in "Manage 3D Settings." For Intel, look for "3D Settings" or "Asynchronous Flip." On ATI/AMD cards, turn on "Wait for Vertical Refresh."
Step 4
Lower and raise the laptop screen repeatedly to determine if the flicker is related to movement. Hardware failure is the likely cause when flicker occurs only when the laptop moves. Most likely, the screen cable is loose or damaged, but the inverter and backlight can also cause this problem. The laptop needs to be opened in order to confirm the problem, but do not attempt this unless you are familiar with PC repair and do not mind voiding the warranty. For the best results, take the laptop to a licensed technician or send it back to the manufacturer.
Apr 20, 2015 | Computers & Internet
Monitor screen rolls and flickers periodically for several seconds to a few minutes
Check if the System is installing updates or any other hidden program this might lead to screen flickering
Dec 17, 2013 | HP Pavilion dv9820US PC Notebook
Screen crashed to flickering gray screen
Try a roll back of the Graphics driver. Have you done any Graphic Updates? Install the driver from the DELL or Windows Update website. Does it work with a external monitor? When you boot in safe mode your machine uses the Basis graphics driver. Is the monitor OK when you boot in safe mode?
Jan 07, 2013 | Dell Inspiron 1764 Laptop
My monitor is flickering
Flickering on the screen can be caused by defective hardware in the computer or by improperly installed software monitor may flicker and goes into rolling state due to dust, overheating after a long continuous usage,loose circuitry or due to some electromagnetic interference with other like tv , UPS, large speaker systems etc.
FIX :
1.Try Re-installing your Video driver
2 If it is possible, connect a different monitor to the computer. If the flickering disappears, it is a fair indication that the monitor is defective, otherwise go to the next step.
3. Set up the computer and the monitor on a different place in your house. If the flickering disappears now, it is most likely an interference caused by something in the original location. Check for devices which can cause interference.
4. If the flickering persists, check the setup of your system. If available in the setup, make sure that the option Monitor Type is configured as Colour Non-Interlaced.
If you don't think any above possible reasons for the rolling or flickering state of your monitor then we recommend you to get your monitor checked by the monitor company at their respective service cente
Sep 01, 2011 | LG Studioworks 700S 17" CRT Monitor
Monitor flickers with lines across screen
screen is going bad which is why its flickering and has the lines across the screen. Theres a board behind the lcd and when that doesn't process the voltage properly it can cause the screen to flicker. White lines across the screen means the screen is going bad. At this point unless your monitor is under warranty, go ahead and replace it.
May 28, 2011 | Norcent Technologies LM-965WA Monitor
Toshiba Satellite M300 screen problem
Hi, I can't guaranty this will help the problem, but for a quick try I say its worth it. On the Desktop, right click to open Personalize, select Display Settings; by adjusting the resolution it helps with the "Flicker effect" aswell, by selecting different settings, you can "view" the best Monitor Display. "If the solution helped, rating it is appreciated, thanks."
Mar 28, 2010 | Computers & Internet
Monitor flickering and rolling
Thanks for the git back: #1 I hooked up a second monitor (depressed fn+f5) and was able to view everything fine. No problem in any area. Ran Some security checks (malwarebytes,checked windows updates,Secunia PSI,and a virus scan. #2 I opened up the monitor and checked for possible loose connections. #3 brought up the graphics display and checked that 60 hrz was set and correct. #4 ran a backup of all my data from my other monitor,and I made the assumption that it was a bad monitor and I might save some money if I just bought a new laptop.Would like to here your comments. Sincerely : dandee4u3
Mar 22, 2009 | Acer Aspire 3690-2196 Notebook
External monitor
you will have to take it in to get fixed , because there is a problem in the monitor
Oct 21, 2008 | ViewSonic VX922 19" Monitor Flat Panel
Screen rolls
I'm writing to you on a screen that is rolling and sometimes flickering right now. I've tried 3 different screens on the same outlet, and they all have the same problem.
1. If you have any speakers near your monitor, try moving them away, this might help because they might not be shielded enough.
2. Try another screen, if the problem persists, it may be your power outlet.
3. If you don't want to spend money on a new screen, spend some time looking for a 3-prong grounding adapter.
I used the 3-prong grounding adapter, those little adapters that plug into the wall using 2 prongs, and then you can plug a 3 prong appliance into them on the other site, and it helped make the rolls not appear as often, and not as dark.
I think it is something with my power or the plug I am using.
Hope this may have helped a tiny bit
Oct 25, 2007 | Acer AL1916W 19" LCD Monitor
Computers & Internet Logo
211 people viewed this question
David Payne
David Payne
