FixYa.com
Tags:
Whirlpool Duet GHW9150P Front Load Washer
Sencing light on the dryer (by 3 users)
posted by jlah on Apr 02, 2008
No matter what setting I put the dryer on the sencing light goes on and the dryer does nothing.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by chadsixt, posted on Jun 10, 2008
Whirlpool GGW9868KQ3, Sensing light goes on when start is pressed and nothing happens. Timer counts down but no heat and the drum does not spin. I replaced the control board and that did not fix the problem, the same technician who told me the board was bad also said the belt switch was not working, so I have little faith this will fix it either. I wish the technician would have just told me he did not know as opposed to lying to me. A & E in San Diego, don't call them, they will take the service call money and tell you to buy a new appliance...
Comment by Guest, posted on Apr 04, 2008
you need to have the thermal swith replace one of the causes is if the air duck or vent is restricted or block.
Solution #1
posted on Jun 15, 2008
Not Rated (0)
Lumpy816
Rank:Guru Guru
Rating: 93%, 84 votes
The thermal fuse is the most common problem that can cause this. If you remove your bottom panel (2 1/4 inch screws) and then your lint duct (the area where your lint screen sits) you will see a white peice of plastic with 2 blue wires going to it behind the lint duct. That is your thermal fuse. A continuity meter can quickly be used to check to see if it is bad. If it is bad, replace it and re-install your lint duct then run you dryer on air dry (if you run it with heat, you could burn your replacment fuse out). Then go to the vent on the outside of your house. You should be able to feel a good deal of air pressure on your hand. If not, check the hose behind your dryer for kinks or being crushed (not uncommon even on "professional" instalations. If that is ok, you will need a cleaning for the house part of your vent.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Washing Machines problems?
F-02
My washer displays F02 and is... Answer This...
washing machine
whirlpool awo/d 4305 light on... Answer This...
error code
flashing F 06 code how do i... Answer This...
tiny dark spots on clothes- and...
see question above Answer This...
Whirlpool replacement door...
whirlpool front loader. How... Answer This...
Repair Service
Find Washing Machine Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
