Question about Nikon D80 Digital Camera with 18-200mm Lens
Nikon d80 won't turn on
When I turn on my camera, the control panel flashes the word "off." The settings and fact that the battery is full the are displayed but not flashing. This was an intermittant problem but isn't any more!
  • 1 more comment
  • Anonymous Sep 17, 2008
    I just bought new Nikon D80. When I on the camera, the display control panel does not give any indication. My viewfiinder is working fine and I can take picture, but the control panel does not give any detail info just like the viewfinder.
    Please help!
  • Anonymous Nov 07, 2008
    I have the same Problem
  • Pcog3 Dec 01, 2008
    Half the time I turn on my 1-year old Nikon D80, the LCD flashes "OFF" and the camera will not function. After turning it off and on a few time, either it flashes "ERR" or works normally.
    Novelist:
  • 121 Answers
Pcog3 & Guests,
Check to make sure (before you turn aon the camera) that the SD card is seated and lens is completely in the right position, if it's not the camera will malfunction and stay or turn off. The last guest that doesn't have info on the LCD can turn the menu items back on in the settings preferences.
randy320sgi
Posted on Jan 07, 2009
SOURCE:
Everything on control panel is flashing. Can't operate camera.
Hi Shirley,
It sounds like your camera's CPU is stuck in a loop. First, I'd remove and transfer any pictures on the SD card in a card reader connected to your computer, followed by formatting the card. Leave the SD card out of the D80. Set the power switch on the D80 to "off" and install a freshly charged battery. If it is still flashing, a "Full Reset" may help.
Nikon recommends that a full reset be done only under direction of Nikon staff. The procedure is outlined along with graphics on this page under "Full reset". I suggest calling Nikon support to see if they think this procedure (or maybe another that they have) will solve the problem.
Nikon Technical Support
8AM - 12AM (Eastern)
7 days a week
1-800-Nikon-US
1-800-645-6687
Jan 09, 2013 | Nikon D80 Body Only Digital Camera
Tv is not responding to the remote
Look on the side/back of the set for the control buttons. Try them. If they work, then you can do a quick check of the remote by;
Get a digital camera (turn on) and point the remote at the lenses.
If you see a flash on the lcd display, the remote is giving a signal and the problem is probably in the remote sensor on the set.
If you do not see a flash the remote may need new batteries.
No camera? check the batteries anyway.
Feb 13, 2011 | Sanyo DP26648-R 26 in. LCD TV
Canon A720 IS camera will not take a picture when flash is turned on but will if flash is turned off. I see a flashing flash symbol in the LCD panel (as if it is waiting for the flash to charge) when...
Dear sir,
It seems  ur battery is weak , since it  use  AA battery put new alkaline batteries  & then try .. I beleive it will take pictures  with snap .
Regards
[email protected]
Feb 12, 2011 | Canon PowerShot A720 IS Digital Camera
How can I turn down the power on the FL50 to get more flashes. Can you turn down the power on the camera E510 with hte FL50 attatched?
the user manual is here http://www.olympus.co.jp/en/support/imsg/digicamera/download/manual/accessories/man_fl50_e.pdf
Have a look at page 46 TTL Auto mode - you can adjust the variable between power setting - + or - 3 stops Page 48 gives full details on adjusting this setting
Light intensity adjustment
  • The flash light intensity can be adjusted between +3 and –3.
  • The light intensity adjustment must be set to ON in the custom setup operation (page 61). • The indicator appears in the control panel.
  1. Turn dial B to select a light intensity adjustment value in the following steps. (This selection is also possible with dial A.)
  • 0 → +0.3 → +0.7→ +1.0 ... +3.0
  • 0 → –0.3 → –0.7→ –1.0 ... –3.0
  1. The display shows the light intensity adjustment value except when the value is 0, in which case the display does not show the light control range.
  2. If the camera’s flash adjustment mode is selected, the actual flash light intensity will be the total of the light intensity adjustment value set on the FL-50 and that set on the camera. The light intensity adjustment value displayed is that of the FL-50 only.
Apr 11, 2010 | Olympus FL-50 TTL Flash
No flash and screen flashes "E:91:01"
Hi!
The error E:91 indicates a hardware malfunction in the Camera. In this case, you may try resetting the Camera to the original factory settings.
Follow the steps given below to reset the Camera to the original factory settings:
(a) Press the Menu button to display the menu screen.
(b) After pressing the right arrow on the control button, go to the (setup) setting, then press the right arrow again.
(c) Next, press the left/right/up/down arrow on the control button to select "Setup 1" option.
(d) Then, select the "Initialize" option OK, OK.
(e) Set the clock if date and time screen appear.
(f) Next, turn off the Camera and remove the Battery pack and press and hold the power button for 30 seconds.
(g) Then, reinsert the Battery pack and turn the Camera ON.
Performing all the above steps will reset the Camera to the original factory settings. After resetting the Camera to the original factory settings, please check the operation of the Camera.
If the Camera continues to display the error E:91 then service will be required.
Regards,
Pacific.
Aug 23, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Why is display flashing OFF while camera turned on?
the camera is in the wrong mode
check the user manual for the correct camera settings.
Mar 26, 2009 | IBM ThinkCentre A50p PC Desktop
Canon A 630 no flashing
Right now Canon's support section for their website is down.
What I'm looking for is to see if the flash was turned off by the control panel accidently. Most digital have a setting to turn it off.
Typically if the camera needs a flash and can't give you one you will get a warning message on the screen. If thats whats happening, then the sensor is working.
Sometimes weak batteries will cause the flash not to work because there may be enought current to run the screen and the shutter but not enough to run the flash at the same time. If you say the batteries are fine then that probably isn't the case.
If you have the book handy you might want to check the control panel settings and find the flash controls.
Jun 14, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
Camera not taking pictures
The camera may be trying to tell you that your flash is turned off in Auto mode, but to get a proper exposure you will need the flash turned on. Try turning the flash on and see if that works.
Hope this helps!
May 20, 2008 | Canon PowerShot A540 Digital Camera
Flashing 254 on camera display
Try replacing the media card - may be corrupted
Jul 12, 2017 | Agfa ePhoto 307 Digital Camera
Flash pops up but does not flash
Turning the Flash Off and On: 1. With the camera in any user set, repeatedly press the Flash/ISO button on the lens barrel until the flash cancel icon (a lightning bolt in a circle with a slash through it) is displayed on the control panel and screen. 2. When finished, to return to the default setting, press the Flash/ISO button until AUTO and the lightning bolt icon are displayed on the control panel and no flash icon is displayed on the screen. If it still doesnt help: 1. Check that batteries are fresh. 2. Check that camera hasn't been set for no-flash mode. 3. Give the flash time to charge before pressing shutter.
Sep 07, 2005 | Nikon Coolpix 5700 Digital Camera
Nikon D80 Digital Camera with 18-200mm Lens Logo
2,286 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Ekse
pictureman4u
Are you a Nikon Camera Expert? Answer questions, earn points and help others
