Question about Sony MEX-BT2500 CD Player
Sony mex 2600.
How do I switch the unit off completely so that the panel is not illuminated when I leave the car. I've connected the red and yellow wires to have power with the ignition key out.
The red wire needs to be conneted to an ekectrical system that is only on when the car is on. Try running a wire from the head unit into the fuse of a system that only works when the ignition is on. like the horn, turn signals, or cigarette lighter.
Posted on Jun 04, 2008
SOURCE:
Toyota Camry 2003 V6 radio
2006 Toyota Camry Car Audio Wire Diagram
Car Radio Battery Constant 12v+ Wire: Blue/Yellow
Car Radio Accessory Switched 12v+ Wire: Gray
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: Green
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: Pink/Blue
Car Stereo Amplifier Location: Located to the right of the glovebox behind the passenger side of the dash.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Violet
Left Front Tweeter: Powered by the same wires as the left front speaker.
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Blue
Right Front Tweeter: Powered by the same wires as the right front speaker.
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Black
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Red
Right Rear Speaker Negative Wire (-): White
Jun 16, 2016 | Toyota Cars & Trucks
Memory
u probably didnt connect the wires right or got them mixed up...the red wire should be connected to the switch wich means there should onle b power when the key is turned on and ur yellow to constant if u got both yellow and red to a switch power the memorry wnt store and thats why everytime u turn it off it goes back to factory settings ....
Jan 04, 2014 | Sony MEX-BT3100P - radio / CD / MP3 player
Im not sure about power wire red black ground and yellow not sure?
Connect black to earth or battery negative.
Connect red to battery positive or the acc lead from your ignition switch. If connected to acc the unit will power down when the vehicle is switched off. If connected to battery positive it will remain on irrespective of ignition switch position.
Connect yellow to battery positive for memory power. The moment this lead loses power all the settings/memory on the unit will be lost.
Leave a comment if you require further assistance
Dec 29, 2010 | Sony XPLOD CDX-GT200 CD Player
Sony car radio model no mex-bt2500 fitted to my renault laguna keeps looseing its memory when you switch of car and comes on when car is switched on without touching on off switch on radio is ther a...
Hi , I assume your installaton to be an aftermarket installation - ie not factory installed. if so then it sounds like the installer has connected the red and yellow wires together and connected them to a switched feed off your ignition.
this is an easy fix - the radio needs a permanent 12 volt supply to the yellow wire - leave the red wire where it is
Apr 17, 2010 | Sony Car Audio & Video
MEX-BT5700U, no sound in speakers in CD source, tuner source OK.
What many people do on this model is connect the remotes wires improperly. Use the solid blue wire for the amp and the blue with white stripe for the connection to the car.
Dec 06, 2009 | Car Audio & Video
Memory hold on CDX-CA400 CD Player
The correct wiring is constant power on the yellow wire, switched power on the red wire. I'm not certain why you weren't able to get it to work in this configuration; the unit needs power on both wires before it will turn on, but if you lose power on the yellow wire the settings will be lost.
Jul 31, 2007 | Sony CDX-CA400 CD Player
Cdx-mp40
You are correct, the unit powers entirely from the red and yellow leads. Your symptoms sound like a unit that isn't getting power on the red (switched) lead. The most likely cause is a blown fuse in your vehicle's fuse box.
Mar 13, 2007 | Sony CDX-MP40 CD Player
Sony MEX-BT2500 CD Player Logo
215 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Mike Duncan
Mike Duncan
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
