Router When I type in my routers web address to change settings,it takes me to different sites, instead of the routers setup page the add is 192.168.0.1 Can anyone help?
    Genius:
  • 1,027 Answers
  1. go to start
  2. run
  3. type in cmd
  4. type in at command prompt ipconfig
  5. the default gateway is your router's ip address.
  6. type those # in
Posted on Apr 02, 2008
How to change admin username & password on cisco 2911 router
agree that turn off your modem first before trying to open the router's setup page. By default, there's no username and the password is admin on Cisco 2911
http://www.3anetwork.com/cisco-cisco2911/k9-price_p238.html
Nov 04, 2011 | Cisco 2911 Router
Dir-615 router wants a username and password to access webpage. I do not have that. I tried reset button 10 seconds on back of router. I tried admin. no luck!
Step 1:
Open a web browser such as Internet Explorer.
Step 2:
Go to the Address bar and enter your router's IP Address ("192.168.1.1" is the default IP of most Linksys routers) then press [Enter].
3714-015.pngNOTE: If the IP address of the router has been changed, type the router's IP address in the "Address" bar instead.
The router's IP address can be changed by:
  • Running the router's setup CD.
  • Changing it on the router's web-based setup page.
If you forgot the router's IP address you can:
  • Check the router's IP address.
  • Press the Reset button at the back of the router for 30 seconds.
    NOTE: This procedure will reset your router to factory defaults. Any settings on the router will be erased. The router's IP address will be "192.168.1.1" and the password will be "admin".
Step 3:
A new window will prompt for a User name and Password. Leave the User name space blank, type in your router's password ("admin" is the default password), then click OK.
3695-005.png NOTE: If the password of the router has been changed, type the router's new password in the Password field instead.
The router's password can be changed by:
Step 4:
When the router's web-based setup page appears, click the Wireless tab and select the Wireless Security tab.
Step 5:
For the Security Mode, select WEP.
Step 6:
For Encryption select 104 / 128-bit (26 hex digits).
Step 7:
For the Passphrase, type a wireless network password of your choice such as "MySecretKey," then click Generate.
NOTE: Your password should be unique and can be a combination of numbers and letters of up to 16 characters.
Step 8:
For the TX Key, select any number. This will determine which key you'll be using. In this example we selected number 1.
Step 9:
Copy Key 1 as this will be the key to your wireless network
Now try , this should work..
thanks for rating good luck
Jan 15, 2011 | Computers & Internet
Hi, i have already installed and all is running fine however i didn't secure the network and now need to add a password how would i do this ?
Step 1:
Step 2:
Step 3:
Step 4:
Step 5:
Step 6:
Step 7:
Step 8:
Step 9:
Copy Key 1 as this will be the key to your wireless network.
Step 10:
Click 4058-005.jpg.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 19, 2010 | D-Link DIR-615 Wireless Router
How can I configure my router so all of my laptops can connect to the internet? Also, do I need to make any changes to my laptops configuration?
All Linksys routers have a built-in web-based setup page that allows the user to customize settings and set up advanced properties.
NOTE: Before accessing the router's web-based setup page, make sure the router is powered on and the computer is wired to one of the Ethernet ports on the router (1, 2, 3 or 4 ).
3676-001.png 3676-002.png Accessing the Router's Web-Based Setup Page
NOTE:To access the router's web-based setup page using Mac, click here.
Step 1:
Step 2:
Go to the Address bar and enter your router's IP address ("192.168.1.1" is the default IP of most Linksys routers) then press [Enter].
NOTE : For WRP400, the default IP address would be "192.168.15.1" and if you place the router behind a primary router with the IP address of "192.168.15.1", then the router will automatically assume a new default IP address, "192.168.16.1".
NOTE: If the IP address of the router has been changed, type the router's IP address in the Address bar instead.
1. Running the router's setup CD.
2. Changing it on the router's web-based setup page.
1. Check the router's IP address. For instructions, click here.
2. Press the Reset button at the back of the router for 30 seconds.
NOTE
Step 3:
A new window will prompt for a User name and Password. Leave the User name field blank then enter your router's password ("admin" is the default password), then click OK.
If you forgot the router's password you need to reset the router. For instructions, click here.
Windows XP
Windows 7
NOTE:
i. Running the router's setup CD. Click here to learn how to download firmware.
ii. Changing it on the router's web-based setup page. Click here to learn how to change password on the web-based setup page.
Unable to Access the Router's Web-Based Setup Page
Reset your router for 30 seconds. Try accessing again using the default IP address "192.168.1.1". If you are encountering problems accessing the router's web-based setup page, click here.
Nov 19, 2010 | Linksys Wireless-G Broadband Router
Unable to access setup for my linksys by entering 192.168.1.1, not sure whats wrong
For information on how to change your router's password, click here. All Linksys routers have built-in web-based setup pages that allow the user to customize settings and set up advanced properties.
NOTE: To learn how to reset your device to factory default, click here.
Step 1:
3714-015.png Step 2:
NOTE: This procedure will reset your router to factory defaults. Any settings on the router will be erased. The router's IP address will be "192.168.1.1" and the username and password will be "admin" after resetting.
Step 3:
A new window will prompt for a User name and Password, type "admin" (this is the default user name and password), then click OK.
4525-003.png NOTE: If the user name and password of the router has been changed, type the router's new user name and password on both fields instead. In case the router login is forgotten, you will to reset the router.
NOTE: This procedure will reset your router to factory defaults. Any settings on the router will be erased. The router's IP address will be "192.168.1.1" and the username and password will be "admin" after resetting. To reconfigure the router, refer to the links below:
  • To configure the router with DSL ISP, click here.
  • To configure the router with Cable ISP, click here.
Nov 13, 2010 | Linksys Wireless-G WRT54G Router
I need to get into my nat settings
NOTE: Before accessing the router's web-based setup page, make sure the router is powered on and the computer is wired to one of the Ethernet ports on the router (1, 2, 3 or4 ).
Step 1:
Step 2:
NOTE
Step 3:
Windows XP
Windows 7
NOTE:
Related Articles:
Setting-Up WPA Wireless Security on a Linksys Router
Changing the Wireless Network's Name (SSID) on a Linksys Router
Setting-Up a Router with DSL Internet Service
Downloading at Linksys by Cisco Support Site
Nov 09, 2010 | Linksys Wireless-N WRT150N Router
Linksys no longer appears on my laptop for some reason. how do i restore it. i can't go on line without it?
Step 1:
Step 2:
NOTE
Step 3:
Windows XP
Windows 7
NOTE:
Related Articles:
Nov 08, 2010 | Linksys WRT160N Wireless Router
How do I find Key# for a new PC. The PC with the actual LInksys Admin Program was on PC that crashed and couldn't be fixed
Step 1:
Step 2:
NOTE
Step 3:
Windows XP
Windows 7
NOTE:
Related Articles:
Nov 07, 2010 | Linksys Wireless-G WRT54G Router
Forgot user name and password
Step 1:
Step 2:
NOTE
Step 3:
Windows XP
Windows 7
NOTE:
Related Articles:
Nov 06, 2010 | Linksys Wireless-G WRT54G Router
How do I make my connection secure to the internet? I have linksys wireless-G 2.4 GHz broadband router. The router is all hooked up but I believe the current connection is unsecured.
When you connected, did it ask you for a password? If not then it's obviously unsecured. Here's how to fix that... i have the same router.
On XP... open internet explorer... in the address bar, type in: 192.168.1.1
On vista.... click start menu...click on network...right click on router and select properties. Next, click on the "Network Device" tab at top of the new window. You will then see "Device Webpage"... click on the ip address to the right of that underlined in blue. It should ask you for a password... if you haven't set one manually the user is admin and the password is also admin. I recommend changing that to a manual password ASAP. Ok, after logging in, now you have the router's set up page in your web browser.
To make it secure:
On the set up page you now have open... you have a few selections that act like tabs: Setup, Wireless, Security, Access Restrictions, etc... Click on Wireless. After clicking on that, you have some tabs underneath wireless you can click on now.
Those selections should be: Basic wireless settings, Wireless security, Wireless MAC Filter, etc... Click on Wireless Security. There you should see disabled on the first drop down. Pick a WEP, WPA or whatever you prefer. I personnally use WEP with 64bit 10 hex and for the password, i use a 10 digit number.
After you have set up your password and security, click save settings at the bottom. After it's done processing the save, you can close the web browser. You are good to go now.
By the way, I recommended changing your password to access the router's set up page. Make absolutely sure you save that username/password in a safe location. If you forget it, there is nothing linksys can do to help you. I know from experience unfortunately.
Hope all this helped... Good Luck
Jul 02, 2009 | Linksys Wireless-G WRT54G Router
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
