Question about Bose LifeStyle 5 Series-III CD Shelf System
No sound I purchased my system in 2001. Have never moved it since purchase. I have never had a problem with it until today. I inserted a disc but got no sound. Checked radio, tape, etc. and also got no sound. Disc is turning, so it is not the motor. I appreciate any insight you can give.
  • 5 more comments
  • kegsy May 11, 2008
    Yes same problem and there is sound when using the headphone socket. Keen to know how to get the sub to switch on.
  • fcrobinson3 Jul 07, 2008
    My CD turns, however no sound. Is there a fuse to the power unit.
    I have unplugged all power sources. Some times when switching on power unit, I get a POP, than that is all.
  • Anonymous Aug 28, 2008
    We have had the sound problem for some time now. It is intermittent, It pops and has a loud crackling noise and the sound goes out. We have check for loose wires.It seems to happen when the TV is on.Haven't notice it with cd player.
  • jack383 Sep 07, 2008
    I have the same problem along with the display is black will the C-19 fix both of these problems I did find the C-19 on the left side of the board mine is a 50v if I change this will it fix both problems Thanks Jack
  • register91 Feb 01, 2009
    Hi David,
    Yes it is a sound from the headphone outlet.. But not in my Sub. speaker. How could I fix it.!!! Thanks..
  • passion4JC Feb 17, 2009
    David_77, I do have sound form my headphones, would the fix be the R428 replacement?
  • BurnedPancak May 11, 2010
    What is your fix for this problem?
  • 12 Answers
Do you have sound from the headphone outlet? If yes, then it could be a known problem on the model 5 where it will not switch on the sub.. I have a fix for this, just let me know.
Posted on Apr 29, 2008
  • CreChur May 06, 2013
    What is your fix for the Bose lifesytle 5 with no sound?
No sound and keeps skipping
Does this happen with any disc or a disc? Playing a contaminated disc can cause heads to get dirty causing above results. Make sure discs are clean when inserted. (Young children can handle discs improperly and get fingerprints and other stuff on discs, resulting in dirty DVD heads) Purchase and use a DVD head cleaning disc. May have to use it a few times initially. Then make sure disc is clean before inserting. Wiping gently with paper towel dampened with water or vodka generally works to remove contaminants. Wipe only the bottom, not the top until it appears shiny.
Feb 16, 2016 | Sony BDP-S300 Blu-Ray Disc Player
I need reset my laptop back to factory setting, so i need to know who to format the HHD. how can i do this.
I eally depends on the make of laptop.
Toshiba use F8 for restore, HP F11
Have a look in your manual, it will let you know where the rescue partition is, indeed if it is still intact.
Feb 14, 2011 | Computers & Internet
ERROR CODE C 13 71 ON SONY HOME THEATRE SYSTEM, DAV-F200, SON PUT MORE THAN ONE DISC IN AND THEY GOT STUCK!!
I have a home theater system - Sony DAV - IS 50, I purchased in the U.S. about one month ago, which works at 110 V and has a power 130 W
I use it in Bulgaria, where the voltage is 230 V electrical networks linking it with a transformer 220 VAC - 110 VAC - Power 200
The
brand of the transformer is THG-200 S Goldsourco.
In DVD mode when inserting a disc - DVD-R disc is ejected and the display code C: 13:71 and the inscription "The disc is dirty". I use brand new discs, but all over again. I do not know what the problem - please help me.
Jan 29, 2011 | Televison & Video
WON'T PLAY CD'S READS "NO DISC"
  • Check the disc you're using for scratches and dirt. If the disc is damaged it won't play properly, regardless of the CD player's ability to function. You can use a CD repair device like the "Disc Doctor" to repair the CD or purchase a new CD.
  • Clean the laser lens with a CD laser lens cleaning disc. CD laser lens cleaning discs can be purchased at most electronics retailers or online. Insert the laser lens cleaning disc and follow the instructions.
  • Insert a correctly-formatted, undamaged disc into your player. Listen to see if it begins to read the disc. If it continues to make no sound and gives you the same message, then the problem is probably that your disc is not spinning in the device.
  • Clean the lens while the DVD player is open. A dirty lens is most likely the cause of your no-disc error. The lens should be cleaned with isopropyl alcohol and a cotton swab.
  • Dec 11, 2010 | Sony CMT-EP505 CD Shelf System
    Pci device drivers are not installed on my system i dnt know how to install. due to this my audio device is not working
    Installing Sound/Audio Cards and Drivers Sound or audio cards, whether it is a stand-alone device inserted into an expansion slot or embedded sound controllers in the motherboard, require specific device drivers in order to function and produce sound. This low-level program is responsible for processing the data between the sound card hardware and the operating system.
    Most sound cards are bundled with the appropriate installation CD when purchased. This disc contains a database of the manufacturer’s available sound device drivers at the time of purchase and includes the specific driver intended for the card purchased. Most discs have an autorun installation program that prompts users to start installation. Some only provide a database of drivers and let the Device Manager or Add Hardware applications in the operation system perform the task of installation.
    If you dont know the type of driver that you have, please check the following link to help you:
    http://www.drivershq.com/driver-update/audio-and-sound/
    I hope this is helpful.
    Mar 17, 2010 | Computers & Internet
    Ghost disc
    its going bad, get your data off it soon as you can. FLASH in not forever and it can and will eventually fail.
    you may have some luck with recovery software.
    most sandisk flash drives ect have a 2 year warranty from purchase date. they do not require proof of purchase.
    Jun 20, 2009 | SanDisk 2GB microSD Memory Card
    Kenwood DVD player 5 speaker system
    There is nothing wrong with it, it is set to only play in the region it was purchased from. That is how all DVD players are made, with regional settings. No repair is going to help, you just need a DVD player from the proper region to play those disc's.
    Nov 05, 2008 | Audio Players & Recorders
    System not recognising disc
    Is it only happening for this one disk? If so, I'd say it's probably a bad disk. I've ran into a couple of those before. Probably an error in production, I'd suggest taking it back and exchanging it for another copy.
    If it's happening to most or all of your games, then it's probably a sign that the laser is going out. You could try cleaning it - get any CD or DVD cleaning kit and follow the instructions. If that doesn't work, you may need to replace the laser. That's a bit more involved, and more expensive, but I can help you with it if it comes to that.
    -John
    Feb 12, 2008 | Sony PlayStation 2 (PS2) Console
    Bose LifeStyle 5 Series-III CD Shelf System Logo
    168 people viewed this question
    Top Bose Audio Players & Recorders Experts
    jjcicala
    Level 1 Expert
    Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
