Question about Sony Handycam CCD-TRV608 Camcorder
Error C1:22 on my Sony CCD-TRV608 camcorder
I've tried airing out my camcorder and am still getting the error. I didn't spill anything on my camera or put it in an environment that was moist. Do you know what causes this and how I might fix it? Thanks so much in advance for any help you can give me.
I dont know
Posted on Jan 25, 2009
SOURCE:
Video Camcorder Error Message
Per SONY; To service the C:31 code, Sony recommends you do the following: Turn off the camcorder. Remove the battery or disconnect the AC power adapter for 60 seconds. Insert the battery or reconnect the AC adapter. Turn on the camcorder. If the error message appears, service may be required.
Sep 15, 2007 | Sony Handycam CCD-TRV608 Camcorder
SIR, MY WINDOWS 7 NOT DETECTING MY SONY CCD-TVR608 HANDYCAM.
only WIndows XP drivers are available for this device :
http://esupport.sony.com/US/perl/swu-list.pl?mdl=CCDTRV608&SelectOS=7#div_pos_18
try to install the drivers in compatibility mode
right click on setup
go to properties
go to compatibility
set it to win xp sp2
hit ok
run setup as administrator
ignore any error and hit continue anyway during installation
restart pc
if the above trick doesn't work then use the device in VIRTUAL XP MACHINE
us XP MODE or VMWARE..
Mar 05, 2011 | Sony Handycam CCD-TRV608 Camcorder
C:31:23 error code
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C79466
Jan 01, 2011 | Sony Handycam CCD-TRV608 Camcorder
I try to connect my sony CCD-TRV608 camcorder to my pc but nothing happens. Please help?
Hello, well you will find if you use Windows Vista/Win 7 no drivers for Sony cameras are loaded, none as far as I am aware are made.
But if you use Firewire cable as I do you wont need drivers, BUT make sure your camera is connected to PC via Fire Wire before you turn PC on, as it wont work if you get this wrong.
Bye
David
Jun 19, 2010 | Sony Handycam CCD-TRV608 Camcorder
Sony CCD TRV608 I may need the flex wire replaced on the LCD. Where can I get this? Thanks! Peter
Your required wire for CCD-TRV608 camera part number is as follows..
1-961-433-21 HARNESS (PD-115)
Available in Part Store.
Thanks.
Oct 01, 2009 | Sony Handycam CCD-TRV608 Camcorder
NEED TO GET A USB CABLE FOR MY CCD-TRV608
CCD-TRV608 is analog camcorder and it does not have any USB port to plug that cable.
May 17, 2009 | Sony Handycam CCD-TRV608 Camcorder
In the Camera mode there is no image just a blank screen
I presume you have checked to see that the lens cap is off? You could also make sure you don't have the "Fade-in" function turned on. Do you see anything at all? Text? If you see text, it indicates that the LCD monitor is working and that you are in some mode that is not letting light get into the camera. Make sure you are ion the all-automatic mode. If you see nothing at all, I'll bet there is something wrong with the screen or the wires connecting to the screen. Do you get an image in the viewfinder?
Nov 08, 2008 | Sony Handycam CCD-TRV608 Camcorder
Sony Handycam CCD-TRV608 Camcorder Logo
67 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Al Rush
Ekse
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
