Question about Refrigerators
Whirlpool EHT 141JK 'fridge
Fan is running, but unit is not cooling. Thought defrost timer was bad.....so replaced it with new one today......now the fan won't even run. Nothing is running. Only thing working is interior light. New defrost timer has pin wich can be used on diferent lacations depending on your wiring diagram. I can't find schematics anywhere on unit. Have tried this black pin on # 2, and #1 terminals. Nothing happens at all. I even put the old defrost timer back on, and fan (only) runs. Please help..........ERIC
  • CHRISCROSBY May 02, 2008
    THE RELAY WAS ARCHING REALLY BAD AND THEN FAILED. MAYTAG SAYS THAT IT IS NOT SERVICABLE, HOWEVER I GOT TO THE RELAY AND IT IS BURNED. IT IS A SMALL RELAY BUT I NEED TO KNOW WHERE TO PURCHACE A REPLACEMENT. IT HAS NUMBERS ON IT BUT NONE PULL UP AS A PART NUMBER. ONE OF THE NUMBERS IS 3012-5A THE OTHER IS 307015 CRPS
    DO YOU KNOW WHERE TO GET REPLACEMENT RELAY?
  • Anonymous Mar 15, 2014
    It quite cooling, so I pulled cover off back by comp and condenser fan runs but nothing else except lights inside refrig. Its like it is stuck in defrost mode. The wiring diagram is so small it is hard to read.
    Problem Solver:
  • 5 Answers
Failedcompressor start relay or bad commpessor
Posted on Apr 02, 2008
SOURCE:
Whirlpool ffw400wh cools nicely for 3 days then form ice on the freezer & does not cool at the fridge compartment
Sounds like your defrost timer is not functioning , it will need to be replaced. Some times the frost free fan can also cause this but I think it will be the defrost timer.
Located under the fridge usually on one of the rear corners.
Pit has like I white round dial on it .
Jan 09, 2014 | Whirlpool Refrigerators
RF266 refrigerator fan not working, Freezer fine. Ref temp at 60 degrees F
Hi mrmac273,
The fan is often a part of the refrigerator that can break down - there are a number of moving parts, and this helps circulate the chilled air. Since fan is not running, cold air from the freezer can't be blown into the fresh food section.
The most common fridge "not cooling" problem is a frost free failure. Remove the access panel in the freezer section to expose the evaporator coils. If the coils in the freezer section get plugged up with frost, this frost will block the evaporator fan motor from blowing the cold air around. The fan blade can also hit this frost and either become noisy or stop altogether. Locating the defrost timer can be tricky....they are often hidden behind the back bottom corners of the fridge at the bottom, in the last few years the timers have been located in the ceiling of the fresh food section, and some behind the cold control cover. Once you locate the defrost timer, slowly turn the screw like wheel in the middle of the defrost timer with a straight screwdriver until the fridge shuts off. You are now in defrost. If the defrost heater(s) comes on now, replace the defrost timer and defrost thermostat. If the heater(s) does not come on, you can ohm test the defrost heater for continuity or volt test for 120 volts to the heater(s). If you have no power to the defrost heater(s) you can also bypass the defrost thermostat to see if the defrost heater will come on, join the 2 wires together to bypass the defrost thermostat. If the heater now comes on, replace the defrost timer and defrost thermostat. If the heater itself is bad, defrost the fridge with a hair dryer, replace the defrost heater* and defrost thermostat. If the defrost timer seems "hot" to the touch or is noisy ( like a ticking or screeching noise )...replace it.
Hope this helps.
Thank you for using FixYa.
Sep 04, 2011 | Samsung Refrigerators
The freezer retains frost and obstructes the fan.
Defrost cycling is poor.
Locating the defrost timer hiddenbehind the back bottom corners of the fridge at the bottom, in some units it's located in the ceiling of the fresh food section,and some behind the cold control cover. Once you locate the defrost timer,slowly turn the screw like wheel in the middle of the defrost timer with astraight screwdriver until the fridge shuts off. You are now in defrost. If thedefrost heater(s) comes on now, replace the defrost timer and defrostthermostat. If the heater(s) does not come on, you can ohm test the defrostheater for continuity or volt test for 120 volts to the heater(s). If you haveno power to the defrost heater(s) you can also bypass the defrost thermostat tosee if the defrost heater will come on, join the 2 wires together to bypass thedefrost thermostat. If the heater now comes on, replace the defrost timer anddefrost thermostat. If the heater itself is bad, defrost the fridge with a hairdryer, replace the defrost heater* and defrost thermostat. If the defrost timerseems "hot" to the touch or is noisy ( like a ticking or screechingnoise )...replace it. Once defrost cycling is cleared, you will get better cooling in fridge compartment also. Thanks.
Jan 31, 2011 | Whirlpool Refrigerators
My refrigerator side is not cooling well. I see ice behind the fan unit when I take out the veggie drawers at bottom. Also fan on fridge side is making lots of noise. Noise stops when I open the door and...
.When you open the door freezer door will get stopped and so, no sound. It will work only when door is closed. Fan sound comes due to malfunction of defrost. If defrost does in right time it won't happens. Unplug and let fridge get defrost all icing. After 3 to 4 hrs,start run again, and set temp @ 5degree freezer. It will start cooling fridge compartment also. But, this is a temerory solution. To solve permanently, find out why defrost not functioned properly?
Follow this steps.
Check defrost timer working which is back of the refrigerator down corner. By with small tip screw driver in some models located in the ceiling of the fresh foodsection or behind the cold control cover. In the defrost timer,slowly turn the screw like wheel in the middle of the defrost timer withstraight screwdriver until the fridge shuts off. Now it's in defrost. If thedefrost heater(s) starts, replace the defrost timer and defrost thermostat. Ifthe heater(s) does not start, unplug wire cord to check ohm test for continuityof heater. If continuity is there, plug cord wire which gives power 120volts(check specification) to heater. If heater no starts, bypass defrost thermostatby join the 2 wires in the defrost thermostat. If the heater now comes on,replace the defrost timer and defrost thermostat. If the heater itself is bad,replace it. Thanks and hope helpful.
Jan 28, 2011 | Samsung RS2630SH Side by Side Refrigerator
The self defrost seems to not be working. I just replaced the blower fan in the freezer. Is there a switch or something that could go bad???
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 16, 2011 | Whirlpool 25.2 cu. ft. Side-by-Side...
Stopped cooling. fan still runs. after several hours started cooling good again.next morning stopped cooling again
Your defroster timer switch may be at faught. The defrost timer turns on a heating coil to defrost your frige. This is only a guess since I don't have the model and year. Do this: feel the walls if they are hard and they have no give to them, then your fridge is frozen up solid and no air can circulate. Unplug you fridge for 24 to 36 hours. Put towels on the floor to catch the water. If the defrost timer is bad it will defrost naturally with room temp. Plug back in after 24 to 36 hrs and see if bottom is now getting cold. If it is the defrost timer, the solution is not cheap. It's up to you to repair or invest in new. Good luck Google burdfrenzy
Nov 26, 2010 | Whirlpool Refrigerators
Whirlpool Gold fridge not working at all even at maximum coldness adjustment, while freezer is fine. Red light on, indicating bad filter, but frdge not connected to water supply, so changing that wont fix...
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Sep 16, 2010 | Refrigerators
Fan in freezer pqrt of fridg Model #ET18NKXDW serail # EF0722540 making noise on and off
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There could be ice built up and hitting the fan or the bearings in the fan could be going bad...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Sep 12, 2010 | Whirlpool Refrigerators
Icemaker not completly filling. Freezer not defrosting, coil icing. New this AM fridge section not cool running 50 degrees. Fan in freezer running. Defrost unit replaced at some time in past.
heatman101
Aug 31, 2010 | GE Refrigerators
Whirlpool Side by Side Fridge Not Cooling
Here's the sequence: First, the unit must be ice free. This happens after power down for about 2 days. If the compressor is clicking, power off for 15 minutes. While waiting....
Clean the condenser coils.
If a mechanical thermostat, does it click when you turn it from off?
Locate compressor in back of unit. Find largest pipe. Power on.
Pipe should frost over for about a minute and then either dry out or form ice on it. If frost stays, you need refrigerant.
If compressor is not running, it could be thermostat, defrost timer (find this little gem in the back of the refrigerator and turn the stub shaft about 1/3 way around...does this change anything?) If the timer is bad...replace it.
Compressors generally don't fail from long run cycles.
hope all this gets you somewhere.
Nov 18, 2007 | Whirlpool GS6NBEXR Side by Side...
Refrigerators Logo
1,149 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
