When I type on my keyboard different letters make diffrent shortcuts pop up. I can get online but when trying to search its immpossible because different keys make things pop up. Example The letter R make the run box pop up. The letter D minimizes every tab I have opened. The letter Y make yahoo messenger pop up? How do I get the keyboard to function normal?
SOURCE: Letters missing from the keys
Stop typing those letters and problem is solved or tipex/paint them back.
SOURCE: Keyboard Reset?
try To download the latest drivers for the keyboard that you are using, visit the following Microsoft hardware Web site:
http://www.microsoft.com/hardware/download/download.aspx?category=MK
If the issue occurs again, connect the keyboard to a different computer. If the keyboard functions correctly on a different computer, the port to which the keyboard was connected on the original computer may be damaged. If this is the case, contact your computer manufacturer to inquire about how to repair or replace the damaged port.
If the keyboard does not function correctly on another computer, the keyboard may be defective. If this is the case, and the warranty on the keyboard is still valid, you can exchange the defective keyboard for a new keyboard.
good luck :)
SOURCE: keyboard is not responding to every letter I type
see if your keyboard have powder, do you need to clean it, if is not resolved this, see the keyboard in the control panel.
SOURCE: My keyboard double types each letter, i.e.
Hey,
Goto Start-> Settings-> Controlpanel-> Key board settings
In the keyboard properties, drag the repeat delay slider towards long. Now test the keyboard and try again until the problem in fixed.
Thank you
SOURCE: Doubled accent with single keystroke (using Language Bar)
It's just a glitch that may happen from time to time. The first thing is to reboot, and more likely than not it will be gone.
