Question about Philips 27PS55S 27" TV
Philips tv with autolock
Cant get the autolock off??? tv is a philips model number is 27ps55
  • 476 Answers
Check out page 14 of the manual.
If you don't have the manual click here to download:
https://www.p4c.philips.com/files/2/27ps55s/27ps55s_dfu_aen.pdf
Posted on Apr 03, 2008
Anyone know what the code is to get my tv unlocked?
Philips sets use a four digit code to control the v-chip. The override code for Philip sets is 0711, although it may say "Incorrect code" the first time to trick you. If "Incorrect code" is displayed, simply enter 0711 again. To use it hit the MENU key to get to the menus. Go up or down until you reach AUTOLOCK or SMARTLOCK, depending on the model, and push the "right arrow" key on the remote. Enter the override code, and enter it a second time if it says it is incorrect.
Once in the AUTOLOCK or SMARTLOCK menu, go to BLOCK, and push the "right arrow" key. Go to BLOCKING OPTIONS and press the "right arrow" key. Go to MASTER DISABLE and press the "right arrow" key so that it says "MASTER DISABLE ON". The v-chip is now reset.
Jul 05, 2012 | Philips Magnavox 27MS343S 27" TV
Cant unlock tv because the code 319753 mute is no longer working
Hello
OK.
Aug 01, 2011 | Philips 20PT6441 20" TV
Hi my TV has a picture of a padlock and i cant unlock it tried to use remote it wont work it is a magnavox 29inch
hi,
For unlocking you tv you have to reset its v-chip. Do the following for the same.
ok
Apr 11, 2011 | Philips Magnavox 20MT133S 20" TV
What is the code for auto lock?
Hello
If your Philips TV is locked, just try this.
Philips sets use a four digit code to control the v-chip. The override code for Philips sets is 0711, although it may say "Incorrect code" the first time to trick you. If "Incorrect code" is displayed, simply enter 0711 again. To use it hit the MENU key to get to the menus. Go up or down until you reach AUTOLOCK or SMARTLOCK, depending on the model, and push the "right arrow" key on the remote. Enter the override code, and enter it a second time if it says it is incorrect.
Ok.
Dec 11, 2010 | Philips 25PS40S 25" TV
El tv dice blocked by autolock channel blocking access code
Hello
Your TV is locked I thinks.
Read this well before you proceed
although it may say "Incorrect code" the first time to trick you. If "Incorrect code" is displayed, simply enter 0711 again. To use it hit the MENU key to get to the menus. Go up or down until you reach AUTOLOCK or SMARTLOCK, depending on the model, and push the "right arrow" key on the remote. Enter the override code , and enter a second time it it says it is incorrect.
Once in the AUTOLOCK or SMARTLOCK menu, goto BLOCK, and push the "right arrow" key. Go to Blocking Options and press "right arrow" key. Goto master disable and press the right arrow key so that it says "MASTER DISABLE ON". The v-chip is now reset.
OK.
Dec 04, 2010 | Philips Magnavox 27MS343S 27" TV
I have a philips magnavox ms2730 c tv 27 inch , my parental lock is enable but i didnt enable it and i cant get it turned off, i was hopping i couldnt find a default password .
I found this info at a tech website, but I haven't tried it myself (never have used parental lock on any set).
Philips sets use 0711 as the override code to defeat parent lock. You may need to enter the code twice if it says "invalid code" the first time.
Using the remote control:
Press the MENU key. Scroll up or down until you reach AUTOLOCK or SMARTLOCK. Press the "right arrow" key. Enter code 0711. Enter it again if it says invalid code.
Once in the AUTOLOCK or SMARTLOCK menu:
Scroll to BLOCK. Press the "right arrow" key. Scroll to BLOCKING OPTIONS. Press the "right arrow" key. Scroll to MASTER DISABLE. Press the "right arrow" key. This should unlock the parental control.
Hope this works for you. Thanks for using Fixya!
Mar 05, 2010 | Philips MS2730C 27" TV
Philips 27ps55 s321 tv remote problem
bought a new universal remote control of phillips
Jul 05, 2009 | Philips 27PS55S 27" TV
The tv is blocked by autolock
I faced this same issue......the override code for Philip sets is 0711, although it may say "Incorrect code" the first time to trick you. If "Incorrect code" is displayed, simply enter 0711 again. To use it hit the MENU key to get to the menus. Go up or down until you reach AUTOLOCK or SMARTLOCK, depending on the model, and push the "right arrow" key on the remote. Enter the override code, and enter it a second time if it says it is incorrect. Once in the AUTOLOCK or SMARTLOCK menu, go to BLOCK, and push the "right arrow" key. Go to BLOCKING OPTIONS and press the "right arrow" key. Go to MASTER DISABLE and press the "right arrow" key so that it says "MASTER DISABLE ON". The v-chip is now reset. Good Luck
Apr 27, 2009 | Philips Magnavox 27MS343S 27" TV
Magnavox mpf 68
Hi its easy, just press and hold av/tv button and then press the on off button on the remote, my kids turn it on all the time . Regards Paul
Jan 08, 2008 | Philips Magnavox 27MS343S 27" TV
New Used tv
Yes there is my friend! Follow these instructions and it will work for you! Philips and Magnavox: Philips sets use a four digit code to control the v-chip. The override code for Philip sets is 0711, although it may say "Incorrect code" the first time to trick you. If "Incorrect code" is displayed, simply enter 0711 again. To use it hit the MENU key to get to the menus. Go up or down until you reach AUTOLOCK or SMARTLOCK, depending on the model, and push the "right arrow" key on the remote. Enter the override code, and enter it a second time if it says it is incorrect. Once in the AUTOLOCK or SMARTLOCK menu, go to BLOCK, and push the "right arrow" key. Go to BLOCKING OPTIONS and press the "right arrow" key. Go to MASTER DISABLE and press the "right arrow" key so that it says "MASTER DISABLE ON". The v-chip is now reset.
Jun 21, 2007 | Philips Magnavox 27MS343S 27" TV
Philips 27PS55S 27" TV Logo
561 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Brian Sullivan
Brian Sullivan
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
