Question about Sony Cyber-Shot DSC-S40 Digital Camera
Camera turns on but has a white screen
I have changed batteries, taken out memory card and swapped it. It just has a white screen on all settings . Nothing else.
Please Help. Is it the cold weather. Has been about 6 degrees at night here lately.
Thanks
  • sambo24687 May 19, 2010
    Thanks for the advice. Just tapping it at the Sony logo on the bottom of the screen worked. Thanks again
SOURCE:
  • 36 Answers
SOURCE: LCD screen is white
Good Day, try taking pictures despite no display or LCD is white, connect to PC and observe, if the picture you took can be seen on PC, then your LCD display is defective, hope this will help, thanks
Posted on Sep 04, 2007
SOURCE: sony cybershot 4.1 DSC-P43
Hi
I bought a new 1MB memory card for this camera and was dismayed to find that the screen went completely blank - I couldn't do anything!!!! It was my sons graduation so had to buy another camera!
But, have just resolved this issue by pressing the bottom right-hand side of the screen with a rubber topped pencil - it works!!!!
This camera may be old and chunky but it still takes amazing pictures.
Hope it works for you too.
Posted on Jul 11, 2008
SOURCE: E:61:10
It seems to be a mechanical problem that can be fixed by placing a bit of pressure on key points. Here is the fix that I did that seems to have worked fine...
open the battery cover
take the battery out
take the memory stick out (inside the battery case)
leave the battery cover open
carefully remove the 7 small silver screws (put them in a cup so you don't lose them!!)
slightly pry the front cover away from the camera starting at the bottom
wedge something in the side to 'pop' out the top retaining tabs towards the top
the front cover should now pop off the camra
Make small paper spacer #1:
Cut the adhesive strip off of a post it note.
Fold it over again about 5 times so that it has some thickness to it.
Approx final dimensions are 1/8in x 1/4in x 1/32in(??) thick
Stick it in the upper right corner of the black plastic lense housing.
See photos attached.
(There is a nice flat rectangle at that spot about the same dims.
This spacer should fit neatly right over that space.)
Make small paper spacer #2:
Approx final dimensions are 1/4in x 1/4in x 1/32in(??) thick
Stick it in the bottom left corner of the black plastic lense housing.
(There is a nice flat rectangle at that spot, but you want the spacer
to be a bit bigger so that it covers the vertical line in the plastic.)
Put the front cover back on the camera.
Make sure it is mechanically secure, but don't install the screws yet.
Put in the battery and memory stick.
Try it. You may have to play with the spacer thickness to get it to work.
Once it is working well again, then put the screws permanently back in.
Posted on Aug 26, 2008
SOURCE: Sony DSC T7 'Access' freeze when switch on camera
try getting a new memory card
Posted on Mar 15, 2009
SOURCE: Nikon D40X quit working - memory card access lamp flashing??
As per the Samsung digimax range, internal memory seems to be faulty. Insert an external memory card and try to power up the camera.....
Posted on Jun 12, 2009
Yellow black and white lines streaking across the screen
tyr to factory reset device on advance settings
with out the memory card
Apr 29, 2010 | Casio Exilim EXZ75 Digital Camera
Digital camera R717 - display screen
May i please know the model and the make of the product in details so that it can help me resolving the issue is a more prompt manner
Apr 20, 2008 | HP Photosmart R717 Digital Camera
New camera ,not working.
lol, ok...The memory card will only go in one way. But check the little white switch on the side of the memory card and make sure it is NOT in the locked position. Once this is taken care of reinstall the memory card. Now in you options/menu screen you can select on there where you want your pictures to be stored...Device / Memory / Auto. You can either put it on Memory or Auto (if you have this). In addition, you may need to format your new memory card. This is also in your menu screen to Format Memory Card. Go ahead and do this. But be forwarned...if you do this when you have pictures on your card, it will erase all of your pictures completely. If you do those things, everything should work fine. You don't need a full charge for your camera to work, but if you have rechargable batteries, it is recommended to fully charge your camera before use. If you are using standard AA batteries this isn't necessary. Oh, and when your memory card is in the camera you should see a little icon on your LCD screen that looks like a mini memory card. This is an indicator that the camera recognizes you have the memory card in the camera and along with that will be a counter...ie 4/1200. The first number is the amount of pictures taken on the card currently and the second number is the total possible pictures you can take on the card before it is full.
Any further questions
extreme7528@yahoo.com
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/matthew_d24b835e574ef6ca
Oct 13, 2009 | Cameras
When I take pictures they are white washed.
Here are the steps:
1.Remove the battery/batteries and the memory card from
your camera
2.Reinstall the battery/batteries into your camera
3.Without the memory card,turn on your camera.
4.Set the camera to Auto Mode and the flash is set to Auto.
5.Try to take a picture.
If issue persists, call 1.800.235.6325 for repair.
Thanks.
Regards,
Neerak21
Sep 23, 2009 | Kodak EasyShare C713 Digital Camera
Sony cyber shot
If you cannot find a solution to your problem you may want to email fixityourself@gmail.com. He has good advice and good used parts at a fair price.
May 21, 2008 | Sony Cyber-Shot DSC-S40 Digital Camera
Diplay turning white on mju 700...
Hi
Sounds like your camera was dropped and the LCD was damaged. The white screen you see is typical for a defective LCD screen. The only way to repair the camera is to replace the bad part with a known good one.
One solution would be to buy a defective camera online that has a good LCD screen and swap them out.
Good luck from Darntoothysam com
Thomas
May 01, 2008 | Olympus Stylus 700 / 700 Digital Camera
Problem with display being white...but!
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Mar 13, 2008 | Canon PowerShot A60 Digital Camera
White Screen
  1. Upon startup lens emerges but when screen appears it is white whereas it normally displays whatever the lens sees. When the shutter button is pressed the camera will focus and take a white picture which can be deleted. The camera does not flash although flash is set to automatic and photo taken in a dark room. Camera flashes (weakly) with flash set to manual on. Lens is unobstructed and appears to be perfectly normal. Camera was not dropped. Batteries have been changed.
Jan 19, 2008 | Pentax Optio E10 Digital Camera
Error #45
Error message appears on EVF/LCD screen
  • Turn the camera off, then on again.
  • Remove memory card from the camera.
  • Remove the battery and wipe the contacts with a clean, dry cloth ( Battery life).
  • Insert a new or charged battery ( Loading the batteries).
  • If all else fails, get customer support help
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
Jan 04, 2008 | Kodak EasyShare Z740 Digital Camera
Samsung Digimax S500
Whit screen means A. connector has come adrift from the main board. or B. Component failure on the main board. If A. try to restore by gently tapping and squeezing the casing around the base of the screen this may get it back. Do get on to the Samsung Tech Support team - in case this is a known issue. An out of warranty repair is not a likely scenario however.
Jul 09, 2007 | Samsung Digimax S500 Digital Camera
Sony Cyber-Shot DSC-S40 Digital Camera Logo
21 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Dan Dangel
Dan Dangel
Level 1 Expert
Are you a Sony Camera Expert? Answer questions, earn points and help others
