Question about Tomtom GO 700 GPS Receiver
Tomtom not switching on
The green charging light comes on when the Tomtom is plugged in but the Tomtom refuses to activate when I press the start button. As soon as I disconnect the power the green light goes off (and still won't start) even after charging overnight.
  • 7 more comments
  • Anonymous Apr 11, 2008
    tried to recharge with wall plug in for several hours then pushed reset button and held for about 30 seconds, din't work also tried to hold power button on for 30 seconds didn't work. when unpluged from power goes dead instintly.now what ? thx don
  • mabhouston1 Apr 12, 2008
    I have the same problem. Hope someone has a solution
  • Anonymous Apr 15, 2008
    Same problem, no solutions?
  • bbutler100 Apr 29, 2008
    same problem!
  • bliven May 03, 2008
    when i plug the charger into my tom tom go 700,the green light comes on and i can turn it on and use it,as soon as its unplugged the light goes out and the tom tom wont switch on,same when using the car chager.
  • Anonymous May 08, 2008
    Green charge light comes on when the pluged in the tomtom, but when i press the start button its not working. Please help.
  • vicky006 May 11, 2008
    I have the exact problem with my Tomtom GO 700, resetting the unit didn't help. It started up once when I hooked it my computer but the green light did light up and it did not work again
  • Anonymous May 16, 2008
    tomtom go 700 wont switch on i have tried all the tips
  • Anonymous Mar 26, 2014
    orange instead of green when charging?
I had this problem. had it plugged in charging and then pressed the the reset and the power button at the same time for about 30-50 seconds and then after that pressed the power button and so far so good
Posted on Aug 14, 2008
Yes pressing the reset button and start while its connected on the computer will sort this problem....
Posted on Jun 11, 2010
My tomtom charges the green light comes on I press the on button but nothing happens
I have managed to fix my TomTom one.
The problem was two fold. First the diode D8 was blown and also the power supply chip was blown.
It is a tricky job, using surface mounted components so should not be attempted by a novice but I managed it.
I have a full set of photos etc if anyone cares to try it. I figured - NOTHING to loose!! so what the heck and just went for it. Taking it apart was fun! The surface mounted IC was easy to obtain and the total cost was about £10 plus 4 hours panic labour. If anyone wants the info just let me know and I will send the photos - but no promises - it worked for me.
I figured out this ongoing problem. I purchased my TomTom One second edition 1/20/07 for $395. I was 30 days past my warranty and had the problem of unit not turning on. Green light came on when charged.
I opened my unit up and found the sw2 micro switch broken. If you press too hard on the on/off button, this will eventually happen.
I couldn't find a replacement switch so I wired my own switch and it works now.
Oct 26, 2010 | Tomtom ONE XL GPS
Green light in bottom left on when device plugged in the mains, but cannot be switched off and no display
The green light indicates the unit is plugged into a active power supply and is charging.
Dec 03, 2009 | Tomtom GO 700 GPS Receiver
My tomtom won't turn on when I've charged it for several hours in the car and now at my computer. The green light is on but I still can't get it to turn on.
try the usb cable to your. this is the recommended method to charge a tomtom2.gif when it wont power on. for reasons unexplained by tomtom they do not recommend the car or house charges.
plug it in via the usb cable to your computer for a few hours(make sure the green light is on and nice and bright) then press and hold the power button(this could take up to 20 seconds)
bill
Oct 15, 2009 | Tomtom GO 700 GPS Receiver
TomTom Go 910 comes on, then goes off
Sounds like a dying battery. There is not enough charge being maintained in the battery to complete the loading of the data. ChaNGE THE BATTERY
Jul 20, 2009 | Tomtom GO 910 GPS Receiver
Won't switch on
Connect it to the computer, then try to switch it on by pressing the button for 1-2 seconds. If it switches on, connect to tomtom home, update, and then switch off. Disconnect, then switch on again. You may have to reset it again by pressing the button for 10-15 seconds. I onl had this problem once, after my first download from tomtom home - I think I crammed too much info into its memory!
May 18, 2009 | Tomtom ONE XL GPS
Sat nav
STEP 1
Connect your TomTom to your computer via USB and open up your Windows Explorer and go to the drive. (It will be listed as TOMTOM (E) or some other drive letter).
Copy the Yellow Folders one by one to your PC. Ideally, save all the folders under a new folder that you name.
You may find that the folder ttntools and gns may not be copied. This is o.k. if they aren't.
STEP 2
Format your Tomtom via MY Computer.
STEP 3
Copy the Yellow Folders from the backup you made in STEP 1 back to the TomTom.
STEP 4
Open TomTom Home
Click on Upate Now.
Install the latest update onto your TomTom.
Once installed, switch your TomTom off, then disconnect if from the PC.
Thats it. From now on, make a full backup using TomTom Home prior to any updates.
Also note, that copying all the files will take some time.
Jan 12, 2008 | Tomtom GO 700 GPS Receiver
Tom tom not working
  1. First , try a re-set through the 'reset' hole underneath the tomtom. 1 quick short press is all thats required. Unlike others suggest , you do not need to hold it in for anything longer than half a second. You should feel the switch 'click' as its a tactile switch. Don't press too hard as you can damage the switch and cause it to lock ON. Once pressed , try turning the tomtom on as normal. Sometimes a tomtom battery can drop below its normal "shelf" voltage ( normal is about 3.8 volts ). A tomtom charger has a protection circuit inside to stop or slow the current it gives out if there is a short. If your battery HAS dropped volts TOO MUCH ( less than 3 volts ) the charger can "see" the tomtom battery as a "short" and the charger therefore shuts down and doesnt charge the battery. You could leave the charger connected and HOPE that the very small amount of current it's putting out will eventualy bring the battery up over 3 volts. Once it is up near its "shelf" voltage ( called shelf voltage as that is the voltage the battery is at 'on the shelf' ie . when its not powering anything ) the charger will begin to charge as normal....... OR ... you can gain access to the battery and charge it from a bench power supply that has voltage and current meters. Once again , once the battery voltage gets something near 3.8 volts the normal tomtom charger can be used to charge it. You caould connect another normal battery to the tomtom battery just for a few seconds ( not recommended and can be a bit dangerous ) if the normal battery is such as a PP3 9v type it should bring up the tomtom battery to over 3.8 volts in a few seconds. The tomtom can then be charged as normal. .............. It is also possible that some internal IC's ( chips ) have blown inside the tomtom and unfortunatly this would require a specialist repair centre to replace them as they are really very very small and are not a normal soldering job. Good luck. ... if this post has helped you or interested you please rate the author.
Jan 12, 2008 | Tomtom ONE GPS Receiver
Will not take a charge
I have just the same problem. Initially the battery was flashing to say that it was low on charge even when it was plugged in, then it flashed that the battery was empty and switched itself off. When plugged in the green light comes on, but still cannot turn TomTom 710 on. Also it will not connect to the computer.
Nov 14, 2007 | Tomtom GO 510 GPS Receiver
Tomtom GO 700 GPS Receiver Logo
1,104 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
