Question about Adobe Acrobat 7.0 for PC
Pdf printing i'd like to setup two pdf printers, one for 8.5" x 11" letter documents (so no matter what size pdf file i send to it, it prints 8.5" x 11"). the second would be for 11 x17 paper (same thing, no matter what pdf file i send to it, it will print to 11 x 17 paper). scaling of corse is important, documents smaller than the paper size need to be up scaled, and documents larger than the paper size need to be down scaled. once i have that working, i'll have some batch printing software monitoring the directory with the pdf files in them, and print according to the size they were saved as. no sizing would have to be done at that point becuase the first step sized the document. thank you, bob carlo rcarlo@vossmfg.com
  • 108 Answers
You need to check for any 3rd party xtension that would support the baove mentioned feature. you can try to search the same on google or can call their tech support to check if they have any information on the same
Posted on Jul 01, 2008
My HP C7180 says mismatch when trying to print DL envelopes. It has worked in the past.
CHECK THE PRINT SETTINGS FOR THE DOCUMENT YOU ARE SENDING TO THE PRINTER YOU MAYBE TRYING TO SEND IT AS A LETTER SIZE INSTEAD OF DL SIZE. YOU CAN FIND THIS IN THE PRINTER PROPERTIES WHEN PRINTING THE DOCUMENT CHECK PAPER SIZE.
Mar 11, 2015 | HP Photosmart C7180 All-In-One InkJet...
How to change print size
Assuming you're referring to the print size of the fonts - letters ..... or the size of the printed page ...
If you're printing from your computer, you'll need to change the size of the font (to a larger font size) on your document before you print, or adjust the print Properties ... to fit to page, or magnify the size of a small document ...
If you're printing a pdf file, you can specify the size of the document using the enlarge (%) before you send it to the printer
Jan 15, 2014 | Epson WorkForce WF-2530 All-in-One...
Document size and page size when printing
Its not a setting for page size, that must always be set to the paper size. The best way is to remove the margins in the document by editing it in a PDF editor. Alternatives are a bit of a bodge. When you print try changing the size to 115% of original.
Dec 19, 2013 | HP - HP Photosmart 8250 printer
'check paper size' error has come up and nothing can now be printed. If turned off and on the last print which had caused the error prints out then the error message appears again. How can i clear this
This is usually caused by data within the print job. Microsoft Office sends paper size and job data with each job. Clear all print jobs in the computer sending the job.(Start/Printers/double click the canon printer and delete all jobs in the print que. Clear the Canon by off/on. Open a program and print a standard letter size document to test. This can be corrected by going to the page/document setup choices under "File" or the Ball in MS Office. Usually this is set to A4 or Bypass by mistake within the application.
Thanks
Jan 06, 2011 | Canon imageCLASS MF8180C All-In-One Laser...
WHEN I AM TRYING TO PRINT THE PDF FILE , I AM GETTING DIFFERENT MARGINS COMPARED TO ORIGINAL PDF FILE.SOME PRINTER IT IS ACTUAL AND SOME PRINTER IT IS DIFFERENT.HOW TO RECTIFY SUCH PROBLEM.KINDLY...
Acrobat reader scales pages on printing, depending on the printer and its driver. By default, Acrobat Reader will use one of the scaling options.
Before printing the PDF document be sure that you select the right kind of paper size such as A4, Letter and B5 which will be printed. Paper size is defined in the Document Setup dialog box for the document.
To print the document without different margin problem:
- Open the Acrobat Reader’s Print dialog box (Choose File > Print).
- Choose “None” from the “Page Scaling” drop-down list. (It will not change until you change it again).
- Then click “OK” to print the document.
This may solve your problem.
Mar 22, 2010 | Adobe Acrobat 6.0 Professional for PC
Printer wont print. It keeps saying PC Load Legal. The printer has paper in it.
Well the printer is telling you to load "Legal Size paper, which is 8.5" X 14" paper.
More than likely, the application you are using is telling the printer to print the page on legal sized paper.
If you want the document to print on "Letter sized paper (8.5" X 11") then in the application, go to the File drop down and select "Page Setup". From within page setup's window, change the paper size to letter and then re-print the job.
Don
Dec 16, 2009 | HP LaserJet 4 plus Printer
Margins and warning window
First i would try to narrow to problem to easier find the issue. Is this happening on all software or only with a particular one? Try with word, outlook, notepad etc. and see how it goes. Try also to set the printer to print only one format (like letter or legal) then setup the software to print only that same size of document... then setup the windows printer to do about the same. Do not forget to change the default print settings in there also. If everything is standard and all paper sizes and types are correct on computer/software printer setup and on the printer itself... then it could be a program/document error. You can aslo try to create a PDF with it and print the PDF to see if it's printing.
Jun 03, 2009 | Xerox Phaser 4500 Printer
Printer cant print excel files
Chjange the page size of the excel document, it at present is set to letter, ...file page set up in excel
Sep 23, 2008 | HP LaserJet 4 plus Printer
My hp laserjet 4 plus printer cannot print excel files
wherer are you printing this, A4 is european, north america would use letter, etc..
if you go to control panel, open the printers and faxes folder, right click the printer in question, a window will pop up, click on properties.. a new window should open. click on "Printing Defaults" or "Printing Preferences" then click on "Advanced" ( I believe it should be to the lower left) that will open another window, in paper size make it Letter if your in N America, A4 for Euro.. this will set the deafult print..
Click ok, then print a test page from the general tab..
The reason you getting this LOAD LETTER message. your excel page setup is set to print to letter, your machine is set to print top A4
If you open Excel then go to Print then a window should pop up where you select the printer you want to use, click on Properties, then Lay out, then Advanced, and input the correct paper size before you print.
does this happen with all excels files, or one particular?
Create a new Excel file, and try printing it.. possibly could be in that particular file. I have seen this happen alott particulary with PDF files.. Where the incorrect paper size is in the file..
Print problems
Its probally the way your configuring the way the print file is printing (IE: portrait or landscape) portrait is the top side being 8.5" or landscape being 11" wide on top! First make sure your printer has both landscape and portrait formats loaded into your printer. This will help the you by when you go to print you can try both trays to print to. If this is not your problem then its the way driver is configured and possibly try printing to a pdf file. If you cannot create a PDF from the application try finding some trial software that will enable you to create PDF files. If you can create a good PDF file and can then print that file to your printer you will have better results, because the software your using might not be configured to work with this printer. PDF files will work great and you can see the preview before you print. If you have more info like what exact software you are using and what platform(PC or mac) and repost this question i will get the update and i can answer this question better.
Aug 10, 2007 | Canon CLC 1150 Color Copier
Adobe Acrobat 7.0 for PC Logo
90 people viewed this question
Top Adobe Computers & Internet Experts
Alun Cox
Laxman Bisht
Laxman Bisht
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
