Question about NetGear - WG311 - 54Mbps 802.11g/b Wireless PCI Adapter (TGN1001486P)
WG311 - Excellent Connection, No Internet
Last Saturday, I installed a Linksys WEFB11S4 router for my daughter, with WEP 64 Bit security. She has a Netgear WG311 USB wireless adapter.
After I installed router, I had to reboot her PC to get connected. Had excellent connection and connectivity to anything I wanted. Used Internet that night and next day, no problem.
Today she called and said she has 'Excellent Connection with limited connectivity'. Check SSID - she's on the router I installed. Had her go to the Network Wizard - it had no 'Find Network' button where it should have (I have a duplicate setup at home - 350 miles away).
Had her reboot her PC. No change. She can't get to the Internet.
I had her try to sign on to the Web Based Utility, it won't connect to that either. (If I had her connect an ethernet cable to her PC and router, should that connect?)
Any idea what the problem is?
  • 1 more comment
  • Anonymous Apr 06, 2008
    netgear wg311 v3 was not finding drivers for windows media center
  • darrinhunn18 Jun 05, 2008
    netgear wg311 v3 not keeping signal
  • Anonymous Jun 20, 2008
    I've had the same issue with ours. Connects fine while in the same room with the router, (have 2 computers on same network) but as soon as we reboot computer in the next room it says we are connected and wireless signal strength is at 100% but will NOT connect to the internet or the router. Have tried this several times and each time same result.
  • 36 Answers
Have her remove the wireless from the preferred network list and re enter wireless security key should fx the problem
Posted on Jul 25, 2009
  • 33 Answers
I do it for a living. In my experience with routers in general, they have a tendency to reset themselves with general poweroutages and power surges. I would suggest hard wiring to the router and going into the settings. It might surprise you to find the wep key changed itself during the week. Hope this helps.
Posted on May 20, 2009
How do i secure me connection?
Login in to your router setup page and make the configuration of your wireless.
usually, for linksys wireless g routers, there is a website...
192.168.1.1
both the p.w. and u.n. is admin....
if you can't find anything on there, go to control panel>network connections>local internet connection. right-click it, click status, and then support.
Nov 02, 2010 | Linksys Wireless-G Broadband Router
Tip
Enabling Wireless security on Linksys routers.....
Encrypting the network blocks any unauthorized computer from accessing the network and using its broadband connection. To enable WEP on the router,
1. Open your default browser and enter the following IP address into the address bar: <http://192.168.1.1>
2. When prompted for a username and password type “admin” on password, unless you have previously changed the password of the router, and hit OK. This will bring you to the Setup page of the router.
3. Depending on the firmware of the router. Click on the WEP Key Settings button. Or you can click the Wireless tab and select Wireless Security. Or you can click the Security Tab and select Wireless.
4. From the WEP/Security Settings window, you may enable 64 or 128 bit WEP then enter your Password on the Passphrase field and click on Generate. Make sure to copy the characters on Key 1-4 on a piece of paper before you hit APPLY. You will be needing this once you enable WEP on the wireless PC’s. Also take note that if you enable 64 or 128 bit on the router, this should be the same WEP level that you will enable on the wireless cards.
To put in the network key in your wireless adapter follow the steps below:
WEP Encryption XP's Wireless Zero Configuration ( Advisable for XP PC's )
1. Go to start>Control Panel>Network Connections>Right click on the Wireless connection then click on Properties>Click on the Wireless Networks Tab
2. From the Wireless Network Connection properties window, under the Preferred network click on Add then type your SSID on the SSID field and check the box for Data Encryption then then unchecked “The Key is provided for me Automatically”
3. Type your WEP Keys on both the Network Key and Confirm Network Key field. (This set of characters should be identical to the WEP Keys Settings on the router. For 64-bit WEP you should have 10 characters, for 128-bit you should type in 26 characters.) Then hit OK and then OK again.
4. After hitting OK a pop-up should appear on the lower right hand side saying “Connected”. Try pointing your mouse arrow on the lower double monitor icon.
5. Restart your PC
WEP Encryption using the Linksys WLAN Utility ( 98/Me/2000 )
Make sure that the WLAN utility of the Linksys adapter is already is installed. If not, you may follow follow the procedures below for "Installing the Linksys WLAN Utility"
1. Click on Start then Programs, then click on anything that says something about the Linksys Wireless Adapter. On the menu, select either WLAN Utility or Wireless Configuration Utility
2. On the lower right-hand side of your screen, double click on the Linksys Icon. This will bring up the WLAN Configuration Utility.
3. Click on the Profiles Tab. Make sure that the SSID that is set to default is your routers SSID. Highlight Default then hit Edit.
4. Select Profile Wizard. Continue to click the Next button, until you get to the Security Settings Window.
OR select Expert Mode then Next. Then click on Security Settings
5. Set the same WEP level that you have enabled on the router. ( ex. 64 or 128 )
6. Type your WEP Keys. This set of characters should be identical to the WEP Keys Settings on the router. For 64-bit WEP you should have 10 characters, for 128-bit you should type in 26 characters.
7. Hit OK then Next. On Confirm New Settings click Yes. And then click “Activate New Settings Now”
If this is a Helpful tip Thumbs Up is appreciated. Thank you
on Jan 03, 2010 | Linksys Wireless-G WRT54G Router
Does not save wireless security settings
2. From the Wireless Network Connection properties window, under the Preferred network click on Add then type your SSID on the SSID field and check the box for Data Encryption then then uncheck “The Key is provided for me Automatically”
5. Restart your PC
Nov 15, 2009 | D-Link Vonage-enabled Wireless Router...
How do I get my WEP Key for my LINKSYS ROUTER
To access the web-based utility, launch the web browser on
your computer (INTERNET EXPLORER), and enter the Router’s default IP address, 192.168.1.1, in the Address field/bar. Then, press Enter. A password request screen will appear. Leave the User name field blank then default password admin. (You can set a new password from the Administration tab’s Management screen.) Click OK to continue.
The Internet Setup section configures the Router to your Internet connection. Most of this information can be obtained through your ISP/ your internet provider. Internet Connection Type Select the type of Internet connection your ISP provides from the drop-down menu. By default, the Router’s Internet Connection Type is set to Automatic Configuration - DHCP, which should be kept only if your ISP supports DHCP or you are connecting through a dynamic IP address. 68be046.jpg IMPORTANT: If you are using WEP encryption, always remember that each device in your wireless network MUST use the same WEP your wireless network will not function properly.
WEP Encryption Select a level of WEP encryption, 64 bits
10 hex digits or 128 bits 26 hex digits. The default is
64 bits 10 hex digits.
Passphrase Enter a Passphrase to automatically generate WEP keys. Then click Generate.
Key 1-4 If you did not enter a Passphrase, enter the WEP key(s) manually.
Click Save Settings to apply your chang
Nov 12, 2009 | Linksys Wireless-G WRT54G Router
How do I put an encryption on my linksys router?
Securing your wireless network is a simple process, which generally does not require a lot of time. This can be done by:
  • Enabling WEP or WPA on the Router
  • Enabling Wireless MAC filter on the Router
  • Disabling SSID Broadcast on the Router
NOTE: The wireless security modes available may vary depending on the model of the router and wireless adapter you are using.
Enabling WEP on the Router
Wired Equivalent Protocol (WEP) is a type of wirelesssecurity which does not change. It provides comparable confidentialityto a traditional wired network. There are two types of WEP you canchoose from:
a. WEP 64-bit: This type of WEP consists of 10-hexadecimal codes. To enable WEP 64-bit, click here.
b. WEP 128-bit:This type of WEP consists of 26-hexadecimal codes hence it is moresecured compared to WEP 64-bit. To enable WEP 128-bit, click here.
Enabling WPA on the Router
Wi-Fi Protected Access (WPA) is a type of wireless securitywhich is dynamic in nature. Meaning, it changes depending on the timerenewal you will specify. Hence, WPA is more secured compared to WEP.
  • Temporal Key Integrity Protocol (WPA-TKIP) – utilizes a stronger encryption method and incorporates Message Integrity Code (MIC) to provide protection against hackers.
  • Advanced Encryption System (WPA-AES) – utilizes a symmetric 128-bit block data encryption
To enable WPA, click here.
Enabling Wireless MAC Filter on the Router
Wireless access can be filtered using the MAC address of thewireless devices transmitting within your network’s radius. You caneither permit or prevent specific wireless computers access to yourwireless network.
To permit wireless computers to connect to your wireless network, click here.
To prevent wireless computers to connect to your wireless network, click here.
Disabling the SSID broadcast is one way of securing your wirelessnetwork. This procedure will prevent other users from detecting yourSSID, or your wireless network name, when they attempt to viewavailable wireless networks in your area. For instructions, click here.
Jul 11, 2009 | Linksys Wireless-G WRT54G Router
HP laptop not recognizing Linksys Wireless B Security Key..
The WEP encryption is consist of 10 characters for 64 bit hex, 128 bit hex is 24 characters and WPA is 8 to 63 characters. So it seems that you have a vista computer? The compatible encryption for vista is WPA, sometime using WEP it is not working properly. So I might advise you to access the configuration of your router (192.168.1.1) and change the wireless settings of your router to WPA-Personal.
Mar 09, 2009 | Linksys BEFW11S4 Wireless-B Broadband...
Laptop says excellent connection - not able to access internet
connect laptop to router using lan cable.
check internet connection. Should be ok.
Only then enable wireless using same WLAN protocol you use on Router: WEP or WPA with same encryption key TKIP or AES.
Be sure no access list enabled on Router or add Laptop MAC address to access list.
Dec 28, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
How do I find out my wep key
Looks like you will have to login to the router from the other computer to find the key.
Usually, the address to the router admin screens is one of the following:
192.168.0.1 Linksys
192.168.1.1 NetGear
192.168.10.100 Motorola
Generally 192.168.1.1 will work for most.
Default Login:
Login = admin
Password = password (default - if this doesn't work, then you will need to find it or initialize the router)
Go to the WEP security Screen
NetGear EXAMPLE:
Security Encryption (WEP)
Authentication Type *Automatic*
Encryption Strength *64bit* (64 bit is sufficient - the network overhead is less than 128 bit)
Security Encryption (WEP) Key (The active key below is marked with *)
Passphrase *Blank*
Key 1 abcdabcdab (64 bit examples = 10 hex digits 128 bit will be longer string)
Key 2 dcbadcbadc
Key 3 123456789a
Key 4 *Blank*
Click logout when finished
LinkSys Example:
Wireless Network Menu
Wireless Network Mode Mixed
Wireless Network Name (SSID) MyWireless
Wireless Channel 7 - 2.442 GHZ
Wireless SSID Broadcast Enable
Wireless Security
Security Mode WEP
Default Transmit Key 1 (This is the active key)
WEP Encryption 64 bits (or 128 bits)
Passphrase
Key 1 abcdabcdab
Key 2 dcbadcbadc
Key 3 123456789a
Key 4
There is no logout for the LinkSys. Just disconnect
Oct 27, 2008 | Computers & Internet
Securing wireless router
Click here for a link to the instruction manual. All this was retrieved from p.48
First off make sure your wireless connection is working
1. On the Setup tab of the Router’s web-based utility, click the Enable radio button next to WEP. Then click the Edit WEP Settings button.
2. You will see the 2.4GHz, 54g, Wireless-G (WEP) screen (Figure C-1). Next to Default Transmit Key, select which WEP key (1-4) will be used when the
Router sends data. Make sure the receiving device is using the same key.
3. For the WEP Encryption drop-down box, select the level of WEP encryption you wish to use, 64-bit 10 hex digits or 128-bit 26 hex digits. Higher encryption levels offer higher levels of security, but due to the complexity
of the encryption, they may decrease network performance.
4. Instead of manually entering WEP keys, you can enter a Passphrase in the Passphrase field. This Passphrase is used to generate one or more WEP keys. It is case-sensitive and should not be longer than 16 alphanumeric characters. (This Passphrase function is compatible with Linksys wireless
products only. If you want to communicate with non-Linksys wireless products, enter the WEP key manually on the non-Linksys wireless products.)
After you enter the Passphrase, click the Generate button to create WEP keys.
Note: All Wireless-G and 802.11b devices in your network must use the same Passphrase or WEP key.
5. WEP keys enable you to create an encryption scheme for wireless LAN transmissions. If you are not using a Passphrase, then manually enter a set of values in each Key field. (Do not leave a key field blank, and do not enter all zeroes. These are not valid key values.) If you are using 64-bit WEP encryption, then the key must be exactly 10 hexadecimal characters in length. If you are using 128-bit WEP encryption, then the key must be exactly 26 hexadecimal characters in length. Valid hexadecimal characters are “0”-“9” and “A”-“F”.
6. Check all the values, and click theApply button to save your WEP settings and return to the Setup screen. To cancel any changes you’ve entered on this page, click the Cancel button. To get more information about the features, click the Help button.
Jun 15, 2008 | Linksys Wireless-G WRT54G Router
Wirless Network keeps failing
It is possible that you need to further fine tune your WEP configuration. To verify if it's the security lock, try running the laptop and the router without the WEP security (disabled) and determine if you still get the "Limited connection or no connectivity".
If yes, you have just eliminated that area and could consider other possibilities, otherwise you then have to concentrate on the WEP security.
Hope this be of initial help/idea. Pls post back on any developments (or lack thereof) or should you need additional information.
Good luck and kind regards.
Feb 10, 2008 | Belkin (F5D7050) 802.11a/g/b Wireless...
Computers & Internet Logo
294 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Brian Sullivan
Brian Sullivan
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
