DEAD FUSE IS OK. MODEL F 32668 CHASSIS CTC203
    Genius:
  • 1,665 Answers
Sound only on some channels on RCA CTC203 chassis
do a hard reset to this TV. Refer its user manual for details.
Oct 07, 2012 | RCA F20625 20" TV
I can't figure out how to connect my RCA Model#60752EB pip correctly also can you help me find where I can download the manual for this product
http://www.eserviceinfo.com/equipment_mfg/RCA_2.html
www.scribd.com/.../RCA-Chassis-CTC203-TV-Trainning-Manual
www.scribd.com/.../Philips-DPTV400-TV-Projection-Training-Manual
Hi please find above some manual which I hope will meet your requirements.
I couldn't find much to do with that model number you quoted? are you sure this is correct?
If not, then please Google your make and model service manual download This will give you links for what you require.
Jun 21, 2010 | Televison & Video
MY TV. TURN OFF AUTOMATIC 20 AFTER YOU TURN ON, WHAT WOULD BE?
images.thomann.de/pics/prod/113142_smanual.pdf
It could be one of many many things, please use these training and service manual, to try an isolate your issue and repair.
Jun 01, 2010 | RCA D52W19 52" Rear Projection Television
Tv turns itself on and off frequently
Check to see if this is an RCA CTC203 chassis (listed on back of set) if so there is common problem with bad solder connections in the horizontal drive section - Otherwise state the model for more help.
Be sure to vote/rate me if this helped Thanks!
Oct 05, 2009 | RCA Televison & Video
Have a 99 crv. turn key over and vehicle is totally dead. checked battery, it is ok. thought a fuse may have gone bad but the fuse cover has mysteriously disappeared. any thoughts?
Check if lights or other electric items on the vehicle are also not working.
If all power is missing, re-check battery terminals for corrosion/loosness, including the battery ground chassis connection - if battery and connections ok, look for a blown in line master power fuse or fusible link.
Ensure power is present on the main power bus at the fuse/relay control panel.
Jul 17, 2009 | 1999 Honda CR-V
Rca rear projection broke?
This may help with yours since it was built in 99
Product Safety Information Product Safety information is contained in the appropriate TCE Service Data covering models/chassis referenced herein. All specified Product Safety requirements and testing shall be complied with prior to returning equipment to the customer. Servicers who defeat safety features or fail to perform safety checks may be liable for any resulting damages and may expose themselves and others to possible injury. First Edition ¾ First Printing Copyright 2000 ¾ Thomson Consumer Electronics, Inc. Printed in U.S.A. ¾ Trademark(s) ® Registered ¾ Marca(s) Registrada(s) Symptom: Shutdown during channel change, shutdown during autoprogram, dead set or unexplained random shutdown. Cause: Incorrect F2PIP Power on Reset (POR) timing Cure: Product Support · Mail Stop INH 900 P.O. Box 1976 · Indianapolis, IN 46206 -1976 TV 00-003 Television TTI TV 00-003 MODELS: CTC195/197, MM10x, CTC203 Chassis with F2PIP DATE: July 14, 2000 TOPIC: F2PIP The following modifications are required to change FPIP POR timing for added reliability. NOTE: All chassis manufactured after 950XXXXXX have the modification installed. Follow these steps in order. All CTC195/7 – All CTC203 1. Insert a 2.2K ohm 0805 size SMD resistor from pin 21 of U18100 to ground (192096). Note: This may require “piggybacking” the resistor on top of C18114. MM101 Chassis 1. Insert a 2.2K ohm 0805 size SMD resistor from pin 21 of U18100 to ground (192096). Note: This may require “piggybacking” the resistor on top of C18119. The next steps are dependent upon the chassis under repair. CTC195F, F2, F3 chassis 2. Replace R18111 with a 100K resistor (192084) 3. Replace C18118 with a 330nf cap (220132) 4. This concludes the modifications for these chassis. CTC195/7 (except CTC195F,F2,F3) and all CTC203 2. Replace R18116 with a 100K resistor (192084). Both are off pin 23 of U18100 3. Replace C18121 with a 330 nanofarad cap (220132) 4. This concludes modifications for these chassis. MM101 Chassis No further modifications are necessary.
Apr 02, 2009 | RCA P52921 52" Rear Projection Television
RCA ctc203ca6 model f32649
the front panel assembly is rca part # 237420
I assume your chassis is a CTC203
Un plug the fpa and see if problem still acts up
you may not be able to find one
then try replacing the sticking buttons on it
Jul 26, 2008 | RCA F31317 31" TV
No Sound, No Picture
do you have chassis number example ctc195 or CTC203 find out an let me know email me
Mar 29, 2008 | Proscan PS27108 TV
TV is flickering
That unit is a ctc203 chassis and if it's never been in the shop before it's probably ring cracks in the HV or power supply circuit. Not an expensive fix at the shop and those chassis tend to be a bit of a bear dismantle (lots of smd). You might consider taking it in for a pro to look at it..
If not the chassis removes as a tray assembly and then dismantles from there. Good magnification, light, dmm and solder gun and you got it whipped..
Bill
Mar 02, 2008 | RCA F27442 27" TV
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
