Question about Nokia N95 Cellular Phone
N93 "dies" while i use or not
I have this n93 purchased in september 2006. right now this unit not only responds so painstakingly slow whether i want to open my address book or to read a message or anything else for that matter. It also has this persistent and annoying shutdown problem.I had the unit reformatted twice and it's software upgraded twice too at a nokia center, but to no avail. I also tried to solve the problem by replacing the battery with a brand new one, but still the problem persists. Can someone please try to help me?
  • colyn May 09, 2008
    I have this n95 purchased ilast nov 2007. right now this unit not
    this persistent and annoying shutdown problem.Can
    Scholar:
  • 59 Answers
1) donot use huge capacity memory cards.
2) always shut down non wanted programs by keeping the menu button pressed and from the taskmanager delete the unwanted applications that might be eating into your ram.
3) always backup your data , and keep the messages less in inbox or move your messages to your memory card and also keep only required contacts delete others.
4) lastly if all the above doesnt help your problem, there is a strip connecting both the parts of your flips, if any damage to its strip or the memory ic , also slows down the mobile phone.
5) only solution now is sell it off on ebay or then get it tested for memory ic problems, but the cost of solving is more than the piece deserves, so just chuck it off.
Posted on Apr 07, 2008
Purchased september 2015 air is cold but fan is extremely LOUD
if it was purchase new then a warranty still applies so have the unit checked by a service agent under warranty
May 03, 2016 | Arctic King 10,000 BTU Slide Casement Air...
Apps not responding an running very slow
Everything is suddenly slow or is not responding. - Windows 8 Forums
www.eightforums.com > ... > Performance & Maintenance
Jun 24, 2014 - 10 posts - ‎2 authors
... year old and it started to load everything really slowly or is not responding for ... of memory to run Windows 8 efficiently so that isn't the problem. ... (It's not always showing, that the application is not responding, when it froze).
Solved: system is extremely slow and everything is "not responding ...
forums.techguy.org > Forums > Operating Systems > Windows 7
Sep 13, 2013 - Solved: system is extremely slow and everything is "not responding" ... Only after several minutes do the programs become responsive again, but once I try ... If using Vista or Win 7 - right click the icon - run as Administrator
iMac very slow, apps not responding, wheel turning ' Apple Support ...
discussions.apple.com > Support > Apple Support Communities
Apple Inc.Sep 28, 2012 - iMac very slow, apps not responding, wheel turning ... (Expect it to take longer to start this way because it runs a directory check first.). Mac runs super slow and apps not responding
Apr 23, 2015
running very slow and apps not responding
Sep 20, 2013
Macbook running slow and all applications stop responding - Apple ...
Jul 29, 2012
Running slow, Not responding
Oct 10, 2011
More results from discussions.apple.com
Jan 06, 2016 | Tablets & eReaders
How do i replace a headgasket of suzuki swift 2006 vvt
nice double post. and still no engine stated, nor country.
which engine,
5 engines world wide, this forum is USA forum
the enhanced 1.6L VVT? m16
you do know that many suzuki engines the covers and pan
are bolted on after a full RTV silicon gasket squirted on .
then cured, right? its it he FSM , ever seen a real FSM
a real suzuki factory service manual, sold at, "SUZUKI"???
is this what you have, now that you said VVT?
In October 2005, Suzuki launched the Sport version of the new Swift in Japan named SwiftRS, and in September 2006 the model was introduced in most European markets. Named "Swift Sport", it is powered by an enhanced M16A unit, a high-revving 1.6-litre, naturally aspirated DOHC VVT four-cylinder engine with an 11.1:1 compression ratio, high lift cams, forged pistons, and strengthened valve springs.
Jan 29, 2015 | 2006 Suzuki Swift
Is there a fuse inside the grinder to protect it from an electrical surge. I accidentally plugged it into a 220 volt outlet.
My MDF was built in September 1993. It has a fuse inside a black cylindrical fuse holder on the electronics board that sits aside the motor. If you have a right-angle flat blade screwdriver, you can get the fuse out without removing the motor unit from the case. I didn't have the right tool, so I ended up removing the motor/grinder unit from the case to replace the fuse. The fuse is a 2A/250V Slow Blow. I used a Buss CDC-2A to replace the factory "5TT 2A/250V" fuse.
May 09, 2011 | Gaggia MDF Electric Burr Grinder
Gateway GT4016 Media Center Computer will not power up?
Dear Lisa,
I think you need to start from SMPS.Check the supply for the voltages on all the jacks.2nd culprit can be *********** board. If you are not conversant with PC hardware, better to get it serviced with an qualified person.
Best of Luck.Please rank me appropriately. If you want any clarification, Please get back to me
Feb 22, 2009 | Gateway Computers & Internet
Carb
You are correct … partially. The ECM monitors the O2 sensors to keep the fuel/air ratio at around 14.7:1. This happens only at cruising speeds or light engine loads above idle. At wide-open throttle, the sensors are not being monitored. When you change the intake or exhaust tracts, you need to change the fuel mapping at wide-open throttle and possibly at idle. In between, the O2 sensors will keep the fuel/air ratio at the 14.7 range. This may or may not be the best for your engine package and riding requirements. Power Commander has what you need to make it right. You can use the O2 sensor eliminators and adjust the fuel/air throughout the rpm range or just tweak the top end at wide-open throttle.
Nov 20, 2008 | 2006 Harley Davidson FXDBI Street Bob
Where can i find the mouth piece of n93
what do you mean the mouth of the n93
Jul 25, 2008 | Nokia N93 Cellular Phone
Fan motor slow on a/c
If the fan motor has a capicator it could be bad. A bad cap will pull the motor down. If there is no cap then the motor beatings could be going bad. this can be checked by matching the motor amps with the rated amps on the unit information tag.
May 17, 2008 | Heating & Cooling
Nokia N95 Cellular Phone Logo
81 people viewed this question
Top Nokia Cell Phones Experts
IT Solution
IT Solution
Shehu Pro
Shehu Pro
