Question about AT&T 8925 Tilt Smartphone
Tilt phone cuts off.
AT&T Tilt occasionally cuts off and I have to remove the battery and place it back to turn the phone on.
  • 1 more comment
  • irocal_2001 Apr 04, 2008
    It is not in sleep mode, it is powered off. You cannot push a button and turn it back on. To power the phone again, you must remove and re-install the battery.
  • lowellbentle Nov 13, 2008
    tilt will turn all the way off and wont turn back on again unless i plug it in
  • Anonymous Dec 12, 2008
    same exact problem.
This is easy! If your battery becomes totally dead or for any other reason you must hit the reset button right next to the usb input. Use your pointer and their is a small hole by the bottom of the phone. Thats all you have to do. You don't have to remove the battery.
Posted on Oct 01, 2008
    Problem Solver:
  • 5 Answers
Can u elaborate
i cant understand cuts off...
Posted on Apr 03, 2008
  • ageorge80 Apr 04, 2008
    oh okie;
    I understand;
    There can be two causes of that ;
    1) The registry settings of "sleep" are modified and doesnt return to normal ; That has been often reported on the new tilt
    2) You have installed a program which causes the phone to shut off
    I think the first one ismore probable;
    Try this site
    http://www.pocketables.net/2008/01/10-ti...
    there is a link for a file here called Kaiser Tweak;
    Run that on your phone and change the settings under sleep ;
    i guess that should solve your problem
How to remove lcd screen on kyrocera hydro
  • Remove the battery cover from the back side of the cell phone. Remove the battery from its compartment and set it aside.
  • Use the screwdriver to remove the Phillips-head screws from the back panel of the cell phone. You may also need to remove the antenna from its retaining slot and remove it from the cell phone if you can
  • Separate the back panel of the cell phone from the rest of the cell phone's body. Place the cell phone face up and then remove the cell phone's faceplate from the rest of the cell phone. This should leave the LCD screen, keypad and circuit board completely exposed.
  • Tilt the LCD screen downward and then disconnect the LCD screen's ribbon cable from the LCD screen and set the screen aside.
  • Repeat this procedure in reverse to replace the LCD screen and reassemble the cell phone.
Mar 17, 2014 | Boost Mobile Kyocera Hydro Smartphone
Tip
Nokia battery
<b>Remove the back cover</b><br /> Place the phone with the back of the phone facing you. Pull up the back cover from the finger grip at the top of the cover.<br /><br /><b>Note:</b> Always turn off the power, and disconnect the charger and any other device, before removing the cover. <a></a><span>Avoid touching electronic components while changing the cover.</span> Always store and use the device with the cover attached.<br /> <b>Remove the battery</b><br /> After you have removed the back cover, insert your finger into the finger grip, and lift the battery from its compartment.<br /> <b>Replace the battery</b><br /> <ol> <li>Insert the gold-colored contact end of the battery into the battery slot. </li> <li>Push down on the other end of the battery to snap it into place. </li></ol> <b>Replace the back cover</b><br /> Place the back cover on the phone bottom first so that the cover tabs align with the slots in the phone and press the cover moving from the bottom to top until the cover is securely in place.
on Mar 09, 2011 | Cell Phones
What is the procedure to changing an keyed ignition lock?
Removal
Disconnect the negative battery cable with the proper size wrench and place away from the battery.
Insert the key into the ignition lock cylinder and turn the key to the run position.
Remove the steering column cover on a tilt steering wheel model by pressing the upper and lower section of the cover together and pulling free from the mounting plate. Remove the steering column covers on a non tilt steering wheel model by using a Philips screwdriver and unscrewing the mounting screws.
Disconnect the electrical connector from the ignition switch by lifting up on the release tab and pulling.
Press the ignition switch actuator pin by pushing a small screw driver into the key lock cylinder, while doing this pull the ignition switch out of the ignition switch housing.
Installation
Insert the new key into the new ignition switch and turn the key to the run position. Insert the new ignition switch into the ignition switch housing. Wiggle the switch back and forth until the actuator pin mounting hole is aligned and falls into place.
Install the electrical connector back into the connector housing by pressing it in with your hands.
Place the steering column covers back onto the non tilt steering wheel and insert mounting screws. Tighten screws using a Philips screwdriver. Place the steering column covers over the tilt steering wheel and press the upper and lower portion together to snap covers back into the mounting plate.
Pull on the ignition key to ensure switch is locked into place. Turn key to the "off" position and remove the key. Insert the key and start the vehicle.
Hope these help.
Jan 28, 2011 | 1992 Ford Crown Victoria
How do you change the dash lights in a 2001 acura rl.3.5
in most cases this is a blowwen fuse if not:
  • These instructions are generic and should work with most cars.
    Disconnect the negative battery cable from the battery of your vehicle with an open-end wrench and move the cable out of the way so that it does not fall back onto the negative terminal.
  • 2
    Locate the bezel that holds the clear instrument cover in place. Remove the screws holding the bezel in place and remove it by pulling it straight up and away from the dashboard.
  • 3
    If possible, lower the steering wheel until it is completely tilted downward. Remove the screws holding the instrument cluster to the panel.
  • 4
    Holding the top of the instrument cluster, tilt the panel toward you until you have access to the light bulbs behind the instrumental panel.
  • 5
    Locate the burned out bulb and remove it by pushing in and turning counter-clockwise to release the bulb from the socket. If the panel has multiple bulbs, consider replacing them all at once; if one is burned out, the others are likely to follow soon.
  • 6
    Place a new bulb in the socket and then tilt the intrument cluster back into position, securing it with the screws.
  • 7
    Tilt the steering wheel back into its normal position and place the bezel cover back in place, securing it with screws.
  • 8
    Reattach the negative battery cable to the battery and then turn on the dashboard lights to verify the new bulb is working.
  • Dec 24, 2010 | 2001 Acura 3.5RL
    I can't get the rod that connects the key lock and door latch in the right position to work correctly.
  • Disconnect the negative battery cable with the proper size wrench and place away from the battery.
  • 2 Remove the steering column cover on a tilt steering wheel model by pressing the upper and lower section of the cover together and pulling free from the mounting plate. Remove the steering column covers on a non tilt steering wheel model by using a Philips screwdriver and unscrewing the mounting screws.
  • 3 Disconnect the electrical connector from the ignition switch by lifting up on the release tab and pulling.
  • Installation
  • 1 Insert the new key into the new ignition switch and turn the key to the run position. Insert the new ignition switch into the ignition switch housing. Wiggle the switch back and forth until the actuator pin mounting hole is aligned and falls into place.
  • 2 Install the electrical connector back into the connector housing by pressing it in with your hands.
  • 3 Place the steering column covers back onto the non tilt steering wheel and insert mounting screws. Tighten screws using a Philips screwdriver. Place the steering column covers over the tilt steering wheel and press the upper and lower portion together to snap covers back into the mounting plate.
  • 4 Pull on the ignition key to ensure switch is locked into place. Turn key to the "off" position and remove the key. Insert the key and start the vehicle.
  • hope this helps you
    Dec 21, 2010 | Ford F-350 Cars & Trucks
    How do i replace the key and tumbler on a 91 chevy 1500?
    You need to go to the part store and buy a special tool that compresses the spring inside the steering column. Don't cut corners, Disconnect the truck's battery. Without the tool you will not get the column back together. With the tool you will compress the spring, remove the clip above that dust shield. and then start to pull it apart. Remember to put everything back together how it was. That dust-cover looking thing must go back exactly how you found it or you will damage the plastic pieces to the horn circuit. When you pull the cover off for the horn be careful with the wire. Push and turn counterclockwise to remove. And you will pull out the directional lever and unscrew the little Phillips head screw from the hazard button so the turn signal Assembly can be moved so you can access the screw that locks the key cylinder in place.
    May 21, 2010 | 1991 Chevrolet C1500
    How do i get the back off my samsung jet s8000 so i can insert the sim card and battery
    Hello,first turn off your phone,then turn it over and pull that cut up so you will remove the back cover.Insert or remove the battery and insert the sim card with the gold contacts facing down.Insert the battery and put the back cover first from up(where is camera) and then the down part with the cut and you are done:)
    Feb 05, 2010 | Samsung Jet S8000 Cell Phone
    Removing ignition switch
    Grand Am 3.1 liters REMOVE Negative battery cable. Air bag fuse. Lower left insulator panel (3) screws. Disconnect 2-way yellow SIR connectors (2). Tilt lever. Upper and lower steering column trim cover. Turn lock cylinder to run position. Push against locking button on back side of bearing and housing assembly and remove lock cylinder. INSTALL Lock cylinder to housing assembly. CAUTION : Rotate the lock cylinder to the "RUN" position. Depress the lock cylinder button. Gently push the lock cylinder into place while rotating the key approximately 5°in the counter-clockwise direction. Upper and lower column cover (3) Torx(R) screws. Tilt lever. Connect 2-way yellow SIR connections (2). Lower left insulator panel (3) screws. Air bag fuse. Negative battery cable.
    Jun 11, 2009 | 1998 Pontiac Grand Am
    How to insert a sim card in nokia7100 .tere is no slot .what can i do? I pushed the sim in, but it was really hard. the cut off corner was in the right place. Still does not say that there is a sim there...
    Extract from nokia 7100 user guide:
    Always switch the device off and disconnect the charger
    before removing the battery.
    The SIM card and its contacts can be easily damaged by
    scratches or bending, so be careful when handling,
    inserting, or removing the card.
    1. Slide the release button (1), and remove the back cover
    (2).
    2. Remove the battery (3), and insert the SIM card (4).
    3. Insert the battery (5), and replace the back cover (6).
    May 29, 2009 | Nokia 7100 Cellular Phone
    How to retrieve battery
    Turn the phone over so that you read Sony Ericsson properly on the back cover. Place your thumb on it and slide left. Now press on the bottom corner of the battery nearest the camera. This should cause the battery to tilt up and you can easily pull it out, otherwise there is something wrong with your phone.
    Dec 16, 2007 | Sony Ericsson S710a
    Open Questions:
    AT&T 8925 Tilt Smartphone Logo
    218 people viewed this question
    Top AT&T Computers & Internet Experts
    Computer Repairing
    Computer Repairing
    Prashant M
    Prashant M
    Are you an AT&T Computer and Internet Expert? Answer questions, earn points and help others
