Question about Haier HTE18WAA Top Freezer Refrigerator
Fridge not cold
My freezer is working (it does have some ice built up on the back wall) but the fridge is about 55 degs. The seal has always been a little off but never really an issue prior to this week. Fridge is less than 2 years old. Help!
  • 1 more comment
  • TessWalters Apr 02, 2008
    Forget to add that it is Haier HTQ21JAAWW
  • TessWalters Apr 03, 2008
    ok for lack of a better word I am an idiot when it comes to this. What do I need to do to check these things?
  • Anonymous May 15, 2008
    THE FAN IN THE FREEZER IS NOT WORKING
The fan in the freezer us not working what could be the problem?
Posted on Sep 09, 2008
  • 109 Answers
Ice build-up on the back wall indicates a defrost issue, check the defrost items. check the defrost timer, the defrost heater and the defrost thermostat, if you need more details let me know.
Posted on Apr 03, 2008
  • CHRIS KLINGER Apr 03, 2008
    you must be able to use a multimeter and be able to identify components, if you don;t have that capability, you are better off calling a repairman.
Freezer only gets down to around 18 degrees but fridge is fine. No frost on the freezer evaporator fan is running
Modern consumer refrigerators only have coils in the freezer. In the lower back of the freezer there is a small fan and possible a damper (flap that opens/closes) to push cold air from the freezer to the refrigerator. Given that the freezer is 18 deg, it's probably cold enough to keep the fridge area at typically 34 deg.
So the cooling system (compressor, coils, thermostat) are not working properly to keep the freezer at, typically 0 deg. Possible causes: partial loss of refrigerant gas, icing around evaporator coils (in freezer), compressor failing, dust clogging condenser coils (under fridge), condenser fan clogged or broken (under fridge), thermostat failure.
I'd start with condenser. Remove the slotted trim at the bottom front and look in with a flashlight. Are the coils clean? Pull out the fridge and remove the lower back cover (usually cardboard). You can now see the coils and fan. Clean and blow them out.
If it's icing, it probably means freezer door not closing tight. If auto-defrost not working properly it would probably get worse over the period of a few days so not likely.
Apr 21, 2016 | Frost Refrigerators
Why doesnt the refrigerator and freezer not get cold enough?
You need to check a few things -
1. settings for the temperature are not set too low. Not cold enough.
2 there is no leakage through the door seals.
3. there is not too much ice formed inside the freezer walls. Needs defrost.
4. the fridge is not overloaded with stuff - not enough capacity to cool things.
5. Not enough free space behind the fridge to allow air movement for coils to cool
Please provide more details of the problem if above not helping. For example model number, is the problem happening both in freezer and refrigerator settings. Get a fridge thermometer and monitor temperature in both sections. should be 4 deg C in fridge and -18 deg C in freezer after stable operation.
Apr 23, 2014 | GE Refrigerators
Drain clogged on MCBR415S
Unless that fridge has an automatic defrosting cycle, NO water should be collecting at the drain area under normal circumstances. The only time that drain is needed is during defrosting (manual or auto).
Does the unit ever turn the cool cycle off or is the fridge always running (does the fridge ever stop humming)? If the fridge is always running, ice will build up in the fridge and it is either because the thermostat is broken or the door is not sealing properly allowing the cold air to escape. This can be due to something inside the fridge is preventing the door from closing properly, the door itself being not properly aligned with the fridge compartment, a broken door seal or a bend door or a bend fridge frame.
Ice can build up fast when a fridge is installed in an area with high humidity (like in Florida) and the door is opened frequently (like every 5 minutes to get a beer out, like during a house party).
If the fridge door seems to seal properly and the fridge seems to keep things cool, it might be enough to defrost the fridge to get it back in proper operating condition.
When loading the fridge, allow enough space between items, to permit the air to circulate.
Good luck :)
Jan 06, 2014 | Magic Chef Refrigerators
Subzero 532 refrig fan(& compressor) doesn't shut off
the higher the number on a fridge the warmer it is so setting it to 1 is close to 0C
when working on a fridge or freezer always turn it off at the wall
if the fridge is keep cold but not cold enough set it back to say 3
if the compressor is running and the back fins / wall is hot then the fridge is working
use a piece of paper between the door seal and the fridge edge to ensure that it is sticking to the fridge and sealing off properly
Jul 16, 2017 | APW Wyott SubZero Refrigerator Freezer...
Refrigerator won't cool
seal on door must be letting moisture into compartment, need new door seal
Aug 20, 2012 | Kenmore Top Freezer Refrigerator
FRIDGE NOT VERY COLD - ABOUT 15 DEG C, FREEZER OK
relies on air flow between fridge and freezer but is regulated.
fault is probably ice build up on top of evaporator in freezer. remove back panel inside freezer and check. also check the air ducts are not iced up
Nov 19, 2008 | Bosch Refrigerators
Ice is building up on the back wall of fridge
Option 1 defrost fridge manually by switching off power for 24 hours, allowing built up ice & frost to melt.
Option 2 Switch off mains power and using a hair drier blow hot air into the freezer supply vents. This shuold shift the ice in a couple of hours
Nov 12, 2008 | Candy CPCA240FFK Bottom Freezer...
Fridge only cools to 55 deg F
check the bottom of Ref. see if it close right, sometimes the rubber near the bottom parts broken.
Jul 08, 2008 | KitchenAid KSRS25IL Side by Side...
Freezer okay, fridge warm
any time the compressor is running the fan in the freezer should be running now you need to empty the freezer do you see a lot of frost on the back wall of the freezer you either have a defrost problem and frost has built up so much its stalling the fan or the fan its self is bad pull the back cover off the freezer wall and tell me what you see please also give me your model number off the serial plate which should be in the fridge section put your freezer stuff in the fridge while we check it out
Jan 30, 2008 | Haier HTE18WAA Top Freezer Refrigerator
Haier HTE18WAA Top Freezer Refrigerator Logo
196 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
geob91
doggzzz
Level 1 Expert
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
