Question about Casio FX-250HC Calculator
Casio fx-250hc I can't get the rad grad or deg modes to go off.
  • Anonymous Dec 04, 2008
    resetting calculator to deg mode
  • s2s2 Dec 07, 2008
    how to i go from rad to degree mode
They can't go off, u hv to be in one of the three modes
Posted on Aug 24, 2008
6ya staff
SOURCE:
How do I clear "DEG" from display?
You can switch between Rads/Deg/Grads. Deg is the one you want to use. So, to answer your question, the "DEG" is suppose to be there so that you know what mode you are using. If you don't have the manual, here it is:
http://support.casio.com/pdf/004/fx82SOLAR_E.pdf
Nov 11, 2014 | Casio FX-260 Solar Scientific Calculator,...
The tangent and inverse tangent offer the incorrect sollution. whould i simply get a new calculator?
No, you don't need a new calculator. Yours simply has the angular mode set to grads. The inverse tangent of 1 is 50 grads, the inverse tangent of sqrt(3) is 66.6... grads.
To change the angular mode, press MODE one or more times until you get the display "Deg Rad Gra". Select the mode you want (from the results you're expecting, it's 1 for Deg).
Jan 26, 2012 | Casio FX-300MS Calculator
How do you change it to degree mode
Press the [MODE] button a certain number of times until display shows a rectangle inside which Deg Rad Gradappear on the top line and 1 2 3 on bottom line, with 1 under Deg, 2 under Rad, and 3 under Grad.
Press 1.
Let me know if this helps!
May 02, 2011 | Casio FX-300MS Calculator
Changing the mode in a casio
To change the default angle unit, you press the [MODE] button a certain number of times until display shows a rectangle inside which Deg Rad Grad appear on the top line and 1 2 3 on bottom line, with 1 under Deg, 2 under Rad, and 3 under Grad.
Press the number key corresponding to your case, 1. All angle values you feed the trigonometric functions will be considered to be in degrees. If you use the inverse trigonometric functions to find angles, the results will be in degrees.
Hope it helps.
Thank you for using FixYa and do not forget to rate this free solution.
Dec 06, 2009 | Casio FX-300MS Calculator
How do you put casio fx-300MS in degrees mode? please help
Hope it helps.
Nov 04, 2009 | Casio FX-300MS Calculator
I need to change to mode to degress
Under the screen you can see atable of values at the right of which is written MODE followed by a small arrow.
If you want to set the degree as angle unit, you press the MODE key followed by 4 (as seen in the table I was referring to).
Similarly, if you want to set RAD as the angle unit you press MODE then 5; and MODE then 6 for GRAD.
However if you just want to convert a number displayed on the screen in RADs or GRADs into DEGs , you press SHIFT then MODE then 4. your number should be converted from the unit it was expressed in into degrees.
Same thing if you want to convert into RADs: SHIFT then MODE then 5.
Hope it helps.
Aug 02, 2009 | Casio FX-115ES Scientific Calculator
FIX/Mode problem?
I do not think that the DEG and FIX indicators are preventing you from calculating any logarithm. DEG appears to remind you that the CURRENT angle unit is the degree. You can change it to RAD or GRAD if you have to use those units. However, DEG will disappear only if replaced with RAD or GRAD.
The indicator FIX reminds you that the display mode for the results is the FIXed mode, not the SCIentific mode. In the FIX mode you specify the number of decimal digits from 0 to 9 and all your results will show the set number of decimals. So if all your results have a lot of unnecessary 0, maybe you should set the FIX mode to fewer decimal digits.
If you still have a problem with the calculation of logarithms, maybe the syntax you use is incorrect.
Try number then log
If that does not work
try log then number.
Apr 03, 2009 | Casio FX-250HC Calculator
Problem with Casio FX 260 Calculator
Read the screen capture about the MODES of this calculators. DEG,RAD, and GRAD remind the user that the angle units in trigonometric function calculations and coordinate conversions are in degrees, radians or grads. They have nothing to do with the other calculations you are doing.
You can only remove DEG by changing the angle unit to RADians or GRADs. In so doing, the new unit indicator (RAD, GRAD) will be displayed instead. There is no point worrying about the angle unit indicator unless you are performing coordinate conversions or calculating trigonometric functions or the inverse trigonometric functions.
MODE 9 cancels the FIX display format: decimal are displayed with a fixed number of decimal places (set by the user). After this key sequence the decimal display format reverts to NORM(al).
Dec 03, 2008 | Casio FX-260 Calculator
Tan cos etc with casio fx-83ES
set it up in correct rig mode, mode button (several times) until you get a window showing deg - rad - grad, choose deg (degree mode)
Nov 19, 2008 | Casio fx-300ES Calculator
PROBLEM W/ CASIO fx-260 SOLAR
Sorry, but I think you misunderstood what the manual says. See the not on the screen capture.
True the sentence is not very clear, but what it means is the following:
All modes (except COMP) will have an indicator (with the appropriate labeling) displayed. When in COMP mode the COMP indicator is not displayed.
The truth of the matter is that computation- wise you have two MODES only : the general COMPutational mode and the Standard Deviation (SD Statistics) MODE. These two are incompatible because the key layout is different.
But to compute trig functions
  1. calculator must not be in SD mode, hence it is in COMP mode
  2. An angle unit must be shown on display.
Jun 04, 2008 | Casio FX-260 Calculator
Casio FX-250HC Calculator Logo
237 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Ekse
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
