Question about Linksys BEFW11S4 Wireless-B Broadband Router (12503024)
ENET Port issue on BEFW11S4 Wireless Router
I have configured the router via wireless but when I try to connect a CAT 5 cable between the Laptop and the router, the connection toggles between connected ("acquiring network address") and not connected ("network cable unplugged"). Is the 4-port ethernet switch faulty or am I doing something wrong? Thanks in advance.
Travis
  • tjphife Apr 02, 2008
    The version of the router is Version 3. Also the lights (100 and full/col) on the front of the router toggle with the connection.
  • 77 Answers
Hi!
Try these steps:
1. Make sure the wireless is disabled when you're doing that. It might cause a confusion between the wired and wireless connection.
2. Try to plug it at other ports (1-4)
3. Try another known working ethernet or CAT-5 cable.
4. Set the laptop's LAN card's speed to 10-hald duplex.
Try these and hope it will help you ;-)
Posted on May 05, 2008
SOURCE:
The power light for the router keeps on flicking and cant even log in. have done all the necessary things. any other help?
Try resetting the Linksys back to the default settings - Press and hold the pinhole RESET button at the back of therouter with the power ON for 20 secs. then release the RESET button.
To connect to your wireless router, the router's wireless settings needs to beconfigured with the SSID, encryption etc. and also the wireless cards in allthe laptops/computers needs to be configured with these router's wirelesssettings. Then the laptops/desktop computers can communicate with your wirelessrouter.
Connect a LAN cable from the Linksys to the LAN port on your computer.
Open a browser and enter the Linksys configuration URL
http://192.168.1.1
The default login = admin
The default PW = admin
You can protect your router by changing the default PW (write it down and putit in a safe place)
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.
Apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Apr 27, 2011 | Linksys BEFW11S4 802.11b Wireless...
Got new modem and cant get router ti work
What exactly is the issue?
Do you want to connect it to laptop via wire cable or Wireless.
For wired it maynot need any configuration but for Wireless it will surely need one.
Mar 12, 2011 | Encore 802.11G WIRELESS LAN ROUTER...
I want to add a LINKSYS workgroup switch EZXS55W behind my wireless routher LINKSYS BEFW11S4 v2 via uplink cable connection. When hardwiring my anything to the switch port 1-4 does not get internet access
Are those 4 ports in different Vlan ?
If you connect your wireless access point to the 1st port are you able to access the internet through 2nd port or 3rd port ?
Are the ports 1-4 admin down ?
Dec 23, 2010 | Linksys Bundle: BEFW11S4 802.11b Wireless...
I have a 802.b I can brouse the enternet with a cable but not with a wireless laptop the laptop is a dell with a wireless card and the router see's the laptop and gives it an IP address and the laptop...
As your router and laptop can see each other it is not a connection issue and you’re your SSID is correct. More than likely that WEP/WPA or pass phrase are the same on both router and all wireless devices.
Jun 30, 2010 | Linksys BEFW11S4 802.11b Wireless...
Can't connect to 2WIRE
I had a similar issue. Here's what I did; Directly connect to the router via ethernet cable; I went to Start>Programs>Accessories>Run; then type in ipconfig, look at the number for the default gateway and type it into your browser's address bar (mine was 192.168.1.254). Now that your in the router, click on the Home Network or View Home Network. At some point it might prompt you for a password. Click Wireless Settings near the top of the screen. From this page I changed the channel to 6 (not quite sure if it did anything) and changed the Power Setting to 10.
After that I was able to connect wirelessly.
Sep 07, 2009 | 2wire HomePortal® 1800HW Router...
Cd won't load on computer
You may configure your router without using the cd.
Using an ethernet cable, connect the router and the laptop so that you can configure it for internet connection.
1. check physical connection. modem to internet port of router. laptop to numbered port of the router.
2. check lights.
3. on your laptop go to the command prompt. (type cmd on the run window)
4. type ipconfig/all on the black screen
5. look for ip address. IP address should be in this range 192.168.0.*
6. open your internet explorer browser then type http://192.168.0.1
7. type admin on the username then password or 1234 on the password box.
8. configure the router for dsl or cable connection. don't forget to save
9. check if you have internet connection. if not, power cycle the modem and router.
10. once you're online, go to wireless tab. set your ssid (any name you want). set your encryption (either wep or wpa) don't forget to save
11. unplug the ethernet cable from the laptop and the router.
12. if the wireless card of the laptop is configured, you may click the wireless connection icon at the system tray (near the clock). enter your ssid and encryption.
13. you should have internet connection.
Nov 02, 2008 | NetGear WGR614 Wireless Router
How do I secure my wireless
If its unsecured that means someone close to you can connect to your network..possibly slowing down your connection..,it took me a few times to get it running correctly...
Oct 27, 2008 | Linksys BEFW11S4 802.11b Wireless...
Connection issue
put the blue cable connection with the router and cable modem first.configure wireless setup.put the desktop rj45 connection to a free router rj45port.As u are getting internet on wireless check the desktop ip configuration.obtain auto ip configuration should be clicked.
Jun 28, 2008 | NetGear FS605 - 5-Port 10/100 Network...
Secure network
If you will connect your desktop to one of the ethernet ports, you will need an ethernet cable. and to customize the wireless settings you can visit this link to help you change the name of the wireless network. Setting-Up the Wireless Settings on a Linksys Router . And you can follow the steps here on this link on how to check or configure the wireless security settings.
May 06, 2008 | Linksys Bundle: BEFW11S4 802.11b Wireless...
Linksys BEFW11S4-RM 4 port wireless router
This is an old router. Look at the power light. You must have a STEADY power light. RESET the BEFW11s4 by pushing the reset button for 30seconds. Unplug the power of the BEFW11s4 for 30 seconds. Connect pc to port 2 or 3. pc should get an ip of 192.168.1.x. If you are getting this ip that means that the pc is already detecting the router.
Good Day
Mar 06, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Computers & Internet Logo
95 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
