Bosch SHU5315UC Dishwasher Logo
Posted on May 19, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have water in the bottom and the LED read 2H, It's about 10 years old, last year I replaced the sensor board. Should I invest more to fix or get a new dishwasher?
Ambari
Level 3:
  • Master 901 Answers
  • Posted on May 20, 2010
Ambari
Master
Level 3:
Answers
901
Questions
0
Helped
251407
Points
1858
Refer your user guide for the error message meaning. Take service center help if you find complicated.
However you check the water inlet for free flow into the machine!
From last 15 days, my TV screen become green, purple and pink after running of 10 - 20 mints and also horizontal lines in upper side. please give the solution
Horizontal lines are generally caused by panel issues, you can check the cables into and out of the tcon board and see if that helps, you could replace the board but I don't think it will fix it
How to fix leaking Everhot/cold water faucet (LVH500)?
there is normally an "O" ring seal around the shaft of the tap and it is replaceable as it is 10 years old the shaft will have corrosion on it so a fix may not last long
you can get replacement tap inserts from a plumbers supplies
2answers
Is it worth fixing a 10 year old KitchenAid Superba side by side?
Pull it out... - turn OFF the water inlet valve..
........... if it still keeps everything cold,,, keep it,,
TV went out, then came back on. Colors way off, no red .This is an LED tv. can it be repaired, or not?. What is the average years of use, with this type of Tv?
Yes,but it could be the incomming broadcasting cable itself,it the cause?Take another tv,test it out with that incomming broadcasting cable,see,if that tv also lost the red color?Yes,than the LED tv have a bad tv Tuner signal board,replaced this incomming tv Tuner signal board,will solved this problems.The average years are 9-10 years,with average of used like 10 hours a day.That how long the LED screen panel will last,but the electronic PCB boards circuitries are a difference story.Those parts on the PCB boards circuittries could last for a couple years are less.
pC
3helpful
2answers
Bosch SHU4312 won't finish cycle, won't drain.
The control board on these units is prone to a cold solder joint cracking. I have read that Bosch recommends replacement and will supply the board, not covering labor. I repaired mine prior and have done one for a friend as well. Has lasted several years and counting
The symptom is constant cycling without ticking down the last few minutes
11 year old amana bottom freezer icemaker drips water when filling tray
as long as the temp in the frz is normal. the i/m could have a bad thermostat that, could be causing it cycling too soon or the tray is leaking water. either way i/m needs to be replaced, sorry
I have a zanussi jetsystem washing machine which has stopped mid cycle and the error code it's displaying is 2h. What does this mean please? Thanks, Elaine Patchett
Dear friend,
ngfam at you service!
You can not fix this problem your self!!!
This sounds like it will only fixed by service then you will be happy again!!
Yes sounds like you need service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PS. PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
2helpful
2answers
Error code 2H.....or stops on last minute
I don't think you'll find it's the control board.
I think you'll find it's the heater box.
Not an easy job to do yourself unless of course you know what you are doing.
I would suggest you contact Bosch. One other possiblity is that the water inlet is blocked, although to be honest this is very rare.
Deep Diver
Top Bosch Dishwashers Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
