Question about Kenmore 44102 Front Load Washer
Water still trickles in after the entire wash cycle is completed
My unit model is Kennmore 417 411 4200 , and looks idential to the photo for the 44102, I will assume it is almost the same unit. My wash cycle completes and then water still trickles in. If I wait too long, it fill the entile machine. If I tunr off the water, it is fine ? I will guess there is some type of faulty value ? Any ideas ?
Thanks Phil Barry, Dunedin, Florida
  • invecta18 Apr 02, 2008
    Is the a Pdf or similar with an exploded view ot the parts you mentioned in your solution. Or even better yet a repair manual available for this. I believe , being a Kennmore, it is most likely a Whirpool or other brand who makes it for Sears. Thanks
  • invecta18 Apr 03, 2008
    Is this the flow valve you are refering to. Rehttp://www.repairclinic.com/SmartSearch/...
    I assume if water it leaking in, it has to be going through this value, and if it is working properly, it should shut off ? Right ?
  • 3,037 Answers
Check the flow meter first. The flow meter has a reed switch on the side of it. Sometimes this switch fails and doesn't respond to the magnetic wheel inside the flow switch. It is suppose to provide a pulse action as the wheel turns. The CCU interprets these pulses to determine flow rate. Just because the wheel inside the meter turns, does not necessarily mean the reed switch is functioning.
Posted on Apr 02, 2008
  • 2 more comments
  • Benjamin Patri
    Benjamin Patri Apr 02, 2008
    I'm
    assuming your washer is over the one year mark so I would also
    recommend running a cleaning cycle to dissolve any accumulations in the
    washer that may have caused this problem (where air tubing connects to
    the lower drum). Use Cascade Complete dishwashing detergent (I use .5
    cup of powdered version) and run the machine on the Sanitary Cycle.
    Smaller machines than ours can use slightly lessor amounts of the
    detergent. After operating the washer a few minutes to completely
    dissolve the detergent, pause the washer, open the door and swab down
    the complete bellows assembly including the hidden folds and adjoining
    areas where the bellows attaches to the drum. Go around the entire
    perimeter of the bellows and adjoining drum, concentrating between the
    8 & 4 o'clock positions where lint and debris collect the heaviest.
    Then throw a couple more rags in the machine to aid in splashing the
    solution and let the cycle complete. The enzymes will dissolve any
    bio-film or other build up that may have accumulated over time. Don't
    add any chlorine bleach to this cycle otherwise the bleach will destroy
    the enzymes. Make sure to also wear hand protection while doing this
    because the solution is harsh.
    This cleaning cycle is more
    important if you use mostly cold or low temp wash temperatures and/or
    tend to be skimpy with detergent dosing. To be on the safe side I
    complete this cleaning routine about once a year. I use at least a few
    Sanitary Cycles per month and also use the Stain Treat cycle often.
    Owners that don't, should run this routine more often. After nearly
    five years of use, my HE3t still remains spotless and sanitary.
    One
    last remark on the diagnosing of the pressure switch and flow meter.
    The pressure switch will normally trip its first set of contacts within
    about a minute or less of filling at the beginning of a wash phase (not
    rinse phase). Then the water solenoids will start increasing the water
    level in increments (Catalyst function). You can tell if the pressure
    switch is malfunctioning if there are no on and off cycles of the water
    solenoid valves during the initial fill phase. If the water enters in a
    constant manner without pauses, the pressure switch has not tripped
    it's first set of contacts. This pausing only occurs during pre-wash,
    auto-soak and wash phases. This is considered the "Catalyst" portion of
    the fill where concentrated detergent is gradually applyed and
    dissolved into the laundry for improved cleaning performance.
    At
    this point (if no pauses are detected), the tubing connected to the
    pressure switch should be checked for air leaks, disconnection or
    obstructions. If the Catalyst function is operating fine (water pulses
    on and off), the culprit of an HF error is normally a malfunctioning
    flow meter. A good indicator is substantially higher water levels than
    normal, provided the flow switch has tripped its first set of contacts.
  • Benjamin Patri
    looking for one for you
  • Benjamin Patri
    try this website, let me know if it helps or not or whether you need something else
    http://www.repairclinic.com/0100_25.asp
  • Benjamin Patri
    Benjamin Patri Apr 03, 2008
    yes and yes to your last questions
Why does a kennmore washing machine work during the final spin and the water input does not stop?
does it only final spin? would say bad water inlet valve but should do the same in wash cycle also??
Mar 07, 2015 | Washing Machines
Washer does not completely spin out the water on the spin cycle.
Output hose might be plugged, water can't get pumped out if end of hose or internal in hose has crud in it. Does water pour out during spin or just trickle, if trickle it has a plugged section.
Feb 15, 2015 | Kenmore Washing Machines
My Kenmore 80 series model 110 hot water continues to trickle in even after cycle is complete.
The fill valve is not shutting off completely. Sometimes it is necessary to turn off the water supply between wash sessions to prevent this but then you have to remember to turn the water back on the next time you plan to wash
Feb 10, 2013 | Kenmore 24032\24036 Top Load Washer
Kenmore front loader washing machine very long wash cycle
You need to replace your cold water, inlet valve.
Unplug the machine from the power source. Disconnect cold water hose. remove the top cover of the machine. You will see the cold inlet valve/solenoide where the hose fits.
Take note of where the wiring goes. You can get the part from your appliance parts outlet.
Refit, and you should be right to go.
Good Luck.
Ash
Oct 22, 2009 | Kenmore Washing Machines
Cold water will only trickle into washing machine
Check your water pressure if thats good check the screens on your hoses, if thst good go to the water inlet valves that allow water into your tub
Jun 09, 2009 | Washing Machines
Dishwasher will not run after filled with water
The float switch in the tank is bad,also if water only trickles in your fill valve is going bad which will not let it fill all the way to start wash cycle. Fill tub with pot of water to raise float, if wash cycle starts,replace fill valve,if not,replace float switch.
Jan 21, 2009 | Dishwashers
Water runs after unit is shut off and door is open
It could be 1 of 2 things either your water valve is going bad or the screens on the back were the hoses connect are dirty.
Jan 10, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Cold water continues to run during entire wash cycle
Adrea, sounds like you need a new valve. When it's doing this leaking, unplug the washer. If it's still leaking you know for sure it's the valve. Part number for the model posted is 22002360. Catriver..post back.
Sep 30, 2006 | Maytag LAT3600A Top Load Washer
Kenmore 44102 Front Load Washer Logo
85 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
