Question about Dell Latitude D620 Notebook
AnyOne Know anything about batteries?
My battery needed to be charged since it had 40% charge left so i shut off the computer. I let it full charge. About an hour and a half later tried turning on the laptop and it would not turn on. I plugged the computer in and it turned on without a problem. It says the computer is running on ac power and it says there's no battery in the computer and the light indicating the battery is charging does not turn on . PLEASE ... help me.. I really need the computer for school any help would be appreciated!
  • 77 Answers
Try reinserting the battery. of nothing happens, then most likely you need to replace your battery as the circuit inside the battery might be fried already.
Posted on Apr 07, 2008
6ya staff
SOURCE:
I left a 1960 sears battery charger plugged into my boat battery, how long before it ruins the battery, when I forgot the battery was plugged in, it was fully charged.
Hey Mike, I can't find a Sears model #1960 charger, so I don't know the specs on it. If it is a typical old school 2 / 6 amp charger or any other that does not automatically shut off or switch to trickle charging, you may be in trouble in a day or two or longer - depending on the charge rate you picked and the percentage of full charge battery was before you connected it.
Dec 07, 2015 | Cell Phones
Tip
How To Extend Your Laptop's Battery Life
Hi... This is Vikas Sharma From M/s Computer Solutions, Patiala - Punjab, India
Im Going to give you one good advice that if you want to make your laptops battery life batter and want that your battery should run and give proper backup then use the battery as much as possible and when laptop shown the message that battry low or less than 5% then charge it back full. do it atleast once in a week.
Acctually the purpose is that when you charge and discharge the battery full all the cells used and charged and discharged. when you charge your battery when it is having i.e. 40% or 30% etc. charging to full and then you use the battery upto i.e. 40% and again you charge it then the remaining 40% cells are not charged and discharged then they become useless and again and again this process dead the cells that are not in charging and discharging position. This is the one big reason for battery problem.
so I suggest that charge and discharge the battery for better results.
Thanks Take Care
on Jun 28, 2010 | Computers & Internet
Gps shuts off regularly
From what I've experienced, repeated restarting, and frequent shut downs, can be traced back to a defective power cord, and/or a low battery state. Garmins operate best with a full battery charge, regardless their connection to external power.
If you can get it to connect to your computer, and can see it as a device with removable storage, right clicking on it's icon, and select "properties" to show you the battery-charge state detected.
Mine won't charge when connected to the computer for some reason, and won't boot even if left for a few hours, but if I connect it to a dedicated usb charger, (the kind that plugs into an A/C outlet with a USB port) it will begin to charge. After fully charging it returns to normal operational state. If it still can't charge it may need a new battery...
Apr 06, 2014 | Garmin nuvi 2455LMT
My Gateway laptop, NE56R1u, shuts down automatically when unplugged even though fully charged?
Dear Leslie,
I had the very same problem with a HP Pavillion DV4 laptop and the problem was inside the battery - one of its cells became defective and the charge did not last more than a few seconds - it also showed a 100% charged icon but the battery was depleted in seconds.
Before buying a brand new battery you could check with a friend that has a similar laptop if he/she can lend you his/her battery for a few minutes and check whether the laptop keeps on or not with that other battery. In the case it remains on, it is the battery for sure, and you will need to buy a replacement one. Check the link below, for one option.
Hope you may find this information useful!
Best regards,
Miguel L. Martins
6cell Laptop Battery for Gateway NE56R41u NE56R42u NE56R43u Nv50A02U...
Feb 19, 2014 | Gateway Ne56r31u Intel Celeron B830 X2...
Battery
This is the procedure for solving consider replacing your battery problem. Start by running the command prompt with administrator privileges. This will give the full control over the command prompt. There are those commands that can only be executed when you are using the command prompt with administrator privileges. Change the destination path showing on the command prompt to be set to C:\ then type the command POWER -ENERGY( to change destination path to C:\, type CD\ ). This command will make the computer scan the battery status and after 60 seconds, a report will be generated and saved in C:\. Simply open the energy report and scroll to check the battery information. Look for the design capacity and the last full charge, note the difference in this figures.
For my laptop, these were the details
Battery Information
Battery ID: Hewlett-PackardPrimary
Manufacturer: Hewlett-Packard
Chemistry: LION
Design Capacity: 88800
Last Full Charge: 36467
To remove the message consider replacing battery fully charge your laptop battery then unplug the charger to use the laptop on battery power. Use it until the laptop to automatically shut down. Still with the charger unplugged, power on the laptop again. Do this until the battery is totally empty. Now plug in your charger and charge the battery fully. Then perform the commands steps again by running the POWER -ENERGY command. Make sure you note the differences in the last full charge details. Continuously perform these steps until the figures in the last full charge are more than 40% of the design capacity.
May 19, 2013 | Acer Aspire Notebook
My laptop battery says Unknown Remaining but it's fully charged
open laptop back panel and unplug the bios battery , then with the help of any screwdriver try to short the bios pin. 100 % work
Apr 21, 2012 | Computers & Internet
A/c adapter will not charge battery. Got a new one, will not charge and shuts off laptop. Little battery life left on laptop,
you got new a/c adapter or new battery? If you got new a/c adapter then you need to replace the battery... thats what it sounds like:)
Batteries wear out over time and usage. To get the best use out of your battery try to always charge when little power is left:) Thnx
Jul 24, 2010 | Dell Inspiron mini 9 - Black , Intel® Atom...
My phone only works when it's plugged into the charger
New batteries are shipped partially charged. Before you start using your device, it is recommended that you charge the battery. Some batteries perform best after several full charge/discharge cycles. You can charge the battery in two ways: • Charging the device’s battery by connecting the power adapter. • Connecting your device to a PC via the provided Mini USB cable. Note: Only the AC adapter and USB cable provided with your device should be used to charge the device. Charging is indicated by a solid amber light on the left LED indicator. As the battery is being charged while the device’s power is on, a charging icon will be shown on the title bar of the Today screen. After the battery has been fully charged, the left LED becomes green and a full battery icon appears on the Today screen’s title bar. Warning! Do not remove the battery from the device while you are charging it using the AC or car adapter. As a safety precaution, the battery stops charging when it overheats. When the low-battery warning appears, do the following: • Immediately save your current data. • Synchronize with your PC or connect the power adapter to charge the battery. • Turn off your device.
Hope this helps, let me know if I can help you with anything else.
JimmyC
Jul 14, 2009 | UTStarcom Blitz Cell Phone
Left connected when shutdown
This happens to me every other time I connect to charge the battery. I remove the screws on the back and remove and reinstall the battery then back to normal but still without a full charge.
Apr 12, 2007 | SanDisk Sansa e260 MP3 Player
Help me please! My mp3 player shut off.
press the power button for 15 seconds and let go. leave it plugged in the battery should be charging.
Dec 27, 2006 | SanDisk Sansa e250 MP3 Player
Dell Latitude D620 Notebook Logo
93 people viewed this question
Ekse
Clive
Clive
Alun Cox
