61sbxo-1ba hitachi 3d/shadows/ghost images on letters and mainly when there is a closeup of a persons face. tv looks great when my son plays his gamecube. i have tried switching cables to tv and it made it worst. is this a tuner issue. if so how had is it to replace. thanks bill
  • 8,617 Answers
Its your convergence ICs needing to be repalced. If you would like the link where to get new ones let me know its an easy inexpensive repair and they send free instructions with pictures so you can do the repair yourself and save quite a bit of money
Posted on Apr 02, 2008
Picture has ghost shadows in the faces of people mainly news anchors. Light colors like whites and oranges also have shadows. What could be causing this?
If it does not really display this when a DVD etc is played via a rear audio/video input it is not the set.
Modern cable or sat signals often are compressed and sets cannot on close up views keep up with the signal--when signal is compressed it causes this kind of issue--no way around it.
Jun 16, 2012 | HP Pavilion MD5020N 50" DLP HDTV
Ghost image in red and alot of red color. This occurs all the time. I have tried magic focus and manuel focus. No change
The tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?This tv have a dead convergence board.The tv convergence board must require replacing 2 STK convergence ICS and some or all of it resistors too.Fixing the tv convergence board,will solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Feb 09, 2011 | Hitachi 51F500 51" Rear Projection...
Hitachi 50v500, we just put in a new lamp, now the picture on the screen is slightly doubled, what do I do?
Here is what I suggest----look at lettering and or put the mode to 4X3 which is smaller left and right.
Look at the edges of that picture or lettering on screen---this model sometimes has a ghosting where images have a slight shadow, like with rabbit ears.
If this is the case there is a way with the remote to CORRECT IT.
I have the information--confirm if slight ghosting around letters--it can be white or any color.
I have seen this before.
Sep 10, 2010 | Hitachi 50V500 50 in. HD-Ready LCD...
Shadows/ghosting is present on screen at all times
What kind of shadowing are you seeing? Doe the picture look like a 3D movire (colors separated)? What is the make and model?
Please update this with the above info and I'll provide possible solutions.
Mar 20, 2009 | Televison & Video
Tv duplicate image
your guns are off and need to be adjusted. your 3 guns (red, green and blue) are off and that would explain the funny colors and shadows. Have a tv tech come out and have a look, they can fix it for a reasonable price.
Oct 20, 2008 | Televison & Video
50V500 ONLY
GHOST: May be described as "Out of Convergence" but ghost is still attached to main image.
A "ghost image" appearing to the left or right of images in the picture. Can be varying shades of a primary color (red, green, or blue) as well as gray. Can easily be seen in the 4 x 3 mode, at the edges of the picture.
To correct the problem, please do as follows:
  1. Access I2C Menu. (See page 57 of the Service Manual).
  1. To enter the I2C Service Menu, with power off, (on the front control panel) press and hold the INPUT button. Then press the POWER button for two seconds. The following Service Menu will appear.
03b_ghost_image01.gif Figure 1
  • Be sure to press SELECT after each change to SAVE the new Data.
  1. Using the Remote Control joy stick, scroll down to next page (see Figure 2) until LCD ADJUST is highlighted.
03b_ghost_image02.gif Figure 2
  1. Move the joy stick to the right to cursor right once. The next page will appear with the word GHOST highlighted.
  2. Cursor right again, and a white screen will appear with a BLACK SQUARE in the center, as in Figure 3. You will see LCD ADJUST, followed by “SHP” and a number (value).
Figure 3
  1. If the unit is out of adjustment, you will see a gray ghost on either side of the black square. Move the joystick to the right or to the left until the ghost disappears. The number values will change up or down.
    • If the ghost adjustment is off with a lower value, there will be a ghost to the left of the square.
    • If the ghost adjustment is off with a higher value, there will be a ghost to the right of the square.
  2. Once you get the square to look good without ghosts, press "SELECT" to save any data values that have been changed.
  3. Press the "EXIT" button three times to return to normal picture.
  4. Adjustment is completed
Jul 26, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Ghosts or shadows around images
I always start my Hitachi research at their website.........
Nov 28, 2007 | Hitachi 50V500 50 in. HD-Ready LCD...
Covergence problems . Could be loose contacts on the output IC's or bad IC's . If they are bad they generally also have bad resistors or fuses that open up as well .
Nov 13, 2007 | Hitachi 46W500 46 in. TV/DVD Combo
Blue shadow or ghosting on screen
  1. First try Magic Focus
  2. if this will not fix problem
  3. then you have a convergence problem
  4. You will need the Converg. Kit
  5. X480295 part number
Nov 12, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi 50V500
Turn off your set. ( wait for the light and the fan to shut down) push and hold the Input button on the panel, power it on with the power button on the tv, as soon as you see the service menu appear, let go of the input button. Scroll down to : LCD adjust, toggle blue button to the right, another screen will appear. Adjust the squares on the screen until the ghosts are gone. hit Exit twice::Ghosts are Busted!
Aug 02, 2006 | Hitachi 50V500 50 in. HD-Ready LCD...
Televison & Video Logo
50 people viewed this question
Top Televison & Video Experts
