Need to format my hard drive - Computers & Internet
  • Carolmoo Apr 03, 2008
    very helpful ...cheers
    Novelist:
  • 125 Answers
Firstly before you format the hard drive be aware that when you start the format process you will lose any data that is currently on that hard drive so make sure you backup all important files such as word and excel documents , pictures , music etc...
Formatting Primary HDD
1. Insert the Windows installation CD and restart the computer
2. Your computer should boot from the cd , or ask to press any key to boot from cd
3. at the next welcome screen press "enter"
4.Press F8 after reading the licence agreement
5.If an existing installation is detected it asks if you want to repair it , to bypass this and continue with the clean format press "esc"
6.Use the ARROW keys to select the partition or the unpartitioned space where you want to create a new partition. Press D to delete an existing partition, or press C to create a new partition. (if an existing partition exist press "D" then "C" to start from scratch")
7. If your not worried about partitions jsut press enter to create it the maximum size
8.Choose NTFS file system and press enter
9. After the install has completed follow any instructions it gives you.
10. you're all done now you will need to reinstall software , drivers etc...
Posted on Apr 02, 2008
SOURCE:
External hard drive format recovery
They are probably still there if you have not written any new files to the drive. read this link http://www.tomshardware.com/forum/285728-32-data-back-formatted-drive-recovery
Dec 22, 2014 | Western Digital Computers & Internet
My glyph harddrive dont show up on my mac why?
If the hard drive was formatted on a PC computer in NTFS file format then the MAC will not recognise this hard drive.
If you want to transfer data between the PC and MAC then you need to format the hard drive with a PC in FAT32 file format. The MAC can read and write to a FAT32 formatted hard drive
Aug 08, 2012 | Glyph GT 050Q Hard Drive
How to transfer 57 gigs from a mac to firelite xp.
The hard drive maybe formatted in Windows NTFS format and the MAC cannot see this formatted hard drive.
If you only wanr to use this hard drive on a MAN then you need to format this hard drive with your MAC.
If you want to exchange files between your MAC and a PC then you need to format the hard drive on a PC in FAT32. The MAC can read and write to a FAT32 formatted hard disk.
May 30, 2012 | SmartDisk FireLite 80 GB Hard Drive
External hard drive used on mac,how do i use it on pc?
You need to format this hard drive using your PC.
If the hard drive was formatted using the MAC then the PC won't see anything on the hard drive because the MAC uses a different file system that is not compatible with the PC.
BUT if you want to exchange files between the MAC and the PC then format the hard drive using the PC in FAT32 file system. The MAC can read and write to a FAT32 formatted hard drive.
Apr 10, 2012 | Hitachi Computers & Internet
My toshiba 1 tb hard drive all ofa suddn says that i need to format it and i have alot for stuff on it that i need how can i make it work again
Don't be panic. you can try some data recovery software. You can see
http://www.asoftech.com/adr/
It tells the steps how to perform data recovery.
If above does not work, you may have to format the hard drive (use quick format), and then use above mentioned software to scan again the hard drive and recover your files.
Aug 28, 2011 | Maxtor OneTouch 4 500GB External USB 2.0...
Hai i have transcand stor get 320GB hard disk. my propblem my computer detect the hard disk but when i try to open that it asks "do you want format it?" what shoud i do?.
If the computer is prompting that the drive needs to be formatted, this means either the drive has become currupt (not likely) or that the drive hasn't been formatted or is an unrecognised format
if the hard drive was formatted on a Mac or Linux machine without choose Fat32 format, the drive will be prompted to be formatted under a windows machine
if there is no information on that drive, i'd suggest just formatting it
remember formatting a hard drive removes all information off that hard drive.
May 12, 2011 | Transcend StoreJet 320 GB USB 20 Hard...
Cannot format hard drive message appears : hard disk cannot be formated" all 20 hard drives on different computers giving me same problem
lets get all of the details first you say you cant access the hard drive then the message cant be formatted how are you trying to format the hard drives what procedure??? will need more imformation a hard drive must be formatted from a ""third party disc""
Apr 09, 2011 | Seagate Barracuda 7200.7 40 GB Hard Drive
I bought a Dell Optiplex 745 with no hard drive. I bought a second hand WD800JD SATA hard drive with no CD's and installed it. The computer does not recognize it so I cannot load an OS. Can you help?
make sure that the leads are in there correct slots
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
hope this helps
Dec 04, 2010 | Western Digital Caviar SE WD800JD SATA...
How I can format muy new hard drive in Windows 7
Hi, you should not need to format your new hard drive, they arrive ready to use. If you require the format just plug you device in, go to hard drives where there is an option to format or repair
Jul 04, 2010 | Iomega 250GB Ego Portable HD Red 250 GB...
Western Digital 320GB USB 2 My Book External Hard Drive
ALL hard drives need to be formatted... The question is, why wasn't this hard drive already formatted when you bought it?
Jan 09, 2009 | Western Digital 320GB MyBook External USB...
Computers & Internet Logo
321 people viewed this question
Ekse
Marvin
Marvin
