Question about Zhone (6218-I2-200) Router
Wireless router help
I just got a new zhone router and when i try to sync up my sony psp to it nothing happens "when i try to search 4 connection" but when i go to command prompt and type in "ipconfig /all" it has all info on the connection just not the dns parts and also on the top of where it says ip routing enabled, and no is the answer beside it. how do i change that, and how do i turn on my routers wireless capability?? please help been trying for several hours....
  • Rick White
    Rick White May 11, 2010
    Do you have a computer successfully connected to the router via wireless? What does your "ipconfig" command show as the IP address? Chances are you aren't actually connected, and it's just giving you the default zero-connect IP address.
  • 41 Answers
Are you trying to connect the game console wirelessly? If you are, you have to make sure the wireless connection on your router is activated. Pull up the interface of the router by typing its default gateway on the address bar of a browser. Default gateway of the device(router) can be obtained by typing ipconfig in the command prompt.
Once the interface of the router is pullep up, check on its wireless settings. Make sure it is enabled. Enabling your wireless settings will enable you to name your wireless connection too. I suggest you secure your wireless connection so your connection will be solely used by you, and ofcourse, for your protection as well. There are a lot of security encyption types you can make use of. I suggest you make use of wep and make sure you are using 64 bit. 64 bit enables you to create 5 text or 10 hexadecimal digits as the wireless security password. 13 text and 26 hexadecimal digits for 128 bit, and 29 text and 58 hexadecimal digits for 256 bit wep key.
With regards to connecting the ps3 or any game console online wirelessly, follow these simple steps:
1. Select NETWORK SETTINGS under setting in the HOME MENU
2. select WIRELESS
3. select SCAN
4. select an access point
** An SSID is an identification name assigned to access points. This is the same wireless name you have configured on the router.
5. select the SSID or the wireless connection you have created
6. select the security method (WEP)
7. type the wep key you have created
8. select EASY on the menu
9. save your settings.
10. test your connection. The system will now attempt to connect you to the internet
11. Confirm the connection test results. If a successful connection has been established, information on the network will be displayed.
If you need assistance for the wired set-up, just tell me so I can provide you with the steps. Goodluck!
Posted on Jul 07, 2009
  • 441 Answers
Try to go to and search your router for opening ports on the router and possibly set your psp to use dynamic IP address
Posted on May 07, 2010
How to increase zhone 1518 internet speed
Many things/variables determine Internet Speed, some you can control, some not so much. Contact your ISP and have them verify the signal, have a ISP tech come out and analyze the signal. The issue may be outside equipment or the Internet site itself. No one thing will increase speed. Upgrade to a New N or AC Wireless Access point, but remember you must update ALL computers to N or AC to benefit fro the Wireless device upgrade. Check ALL cables and connections, reseat connections. Your Device is a 802.11 G, what are you connecting? Are the Computers G as well? You can connect via a Ethernet cable, that's the fastest/easiest/cheapest way to increase speed.
Mar 11, 2013 | Zhone Computers & Internet
Hello, I recently purchased a new laptop (Sony Vaio, E-Series, VPCEB36FA). Whenever I try to connect this laptop to my home wireless network provided by a 6200 ADSL2+ 4-Port Zhone Router, it never gets...
Seems you forgot everything.
1. You could try the default username : admin with password : admin or username : user with password : user
2. if those not working you can reset your ADSL modem to the factory reset by push the "reset to default button" in the back panel, this will bring your modem to the very first time condition. Use the method 1 to login.
Feb 10, 2011 | Zhone (6218-I2-200) Router
Can i connect a wrt54g wireless router to a zhone? to get wireless access on my laptop and wired connection to my computer?
s u can connect as u wish. connect a utp cable lan port of ur wireless router to ur pc. assign ip for ur pc with router's ip as gateway address. similarly search for wireless networks from ur laptop. u will find ur wireless router to in that range. click on it connect to the network. the ip gets automatically assigned for the laptop. Thats it u are done!!!
Jul 21, 2010 | Zhone (6218-I2-200) Router
Psp cannot connect wireless network
  • Make sure you turn on your wireless switch on your PSP.
  • Go to Settings\Network Settings.
  • Select Infrastructure Mode
  • Select New Connection
  • Select Scan
  • Choose the name of your wireless connection and enter the Security key if you have one.
May 29, 2010 | Sony PSP-3000 Black Console
How do I hook up my Westell wireless router to the zhone modem so I can use my laptop. I have to use a dedicated line with a zhone modem to get DSL service. I want to hook up my wireless router Westell...
Connect the Westell wireless to the Zhone as if the Westell is the PC that used to be connected to it. Then connect the PC (through any available port) only to the Westell. That's the WIRED connection. For the wireless to work, after connecting through the WIRED connection, there should be a CD that came with it that will help you configure the wireless.
Feb 18, 2010 | Zhone 6212-I3-200 Router
My sony psp wont connect to internet, keeps saying check security? i have wireless sky hub,
the way it worked on my psp is first i searched 4 my post office router wich is very similar 2 a sky 1. it says the security was wep key. i cliked next and it asked 4 a ssid code. on da bck of my router it says it there so i typed it in. then it asked 4 a wep key. i typed dat in aswell. den i cliked my connection. it says connecting and den obtaining ip adress. aftawards it works. if it still doesnt work send me a message of the way u do it and i mite b able 2 help. i hope dis helped =)
Aug 01, 2009 | Sony PlayStation Portable (PSP) Slim...
Network connection
go to network connections on your psp and search for wireless networks it should show your wireless router there.. and if asked for a key it depends on your router sometimes is on the router itself or sometimes you to set it up.. * dont forget to turn on your WLAN on your psp*
May 05, 2009 | Sony PlayStation Portable (PSP) Console
Zhone 6218
To restore the router to factory default settings, select Management ->
Settings -> Restore Default.
I take it that is what you have tryed?
try finding the correct firmware to install
Aug 12, 2008 | Zhone (6218-I2-200) Router
Internet connection problem Zhone 6211
After a while the net stops working then when i open the router page for the settings it starts back working
Aug 08, 2008 | Paradyne 6211 ADSL2+ Router (6211I1200)
Connecting internet on psp
What you will need.
1. network password to your wireless.
2. if you are doing it manually then you will need the ip address of the router.
Lets stick to the first one for now.
- there is a switch to turn on your wLan on the psp. Turn this on then navigate to internet on your psp, search for your wireless router and enter the appropriate encrpytion u are using eg. wep, wpa etc then enter the network key.
wait a few secs while it connects and you are online.
good luck
Jan 22, 2008 | Sony PlayStation Portable (PSP) Console
Zhone (6218-I2-200) Router Logo
369 people viewed this question
Top Zhone Computers & Internet Experts
Prashant M
Prashant M
Joe Goldman
Joe Goldman
Are you a Zhone Computer and Internet Expert? Answer questions, earn points and help others
