Question about Goodman CKL24AR24 Air Conditioner
Outside fan will not turn on
Outside unit gets hot but fan does not turn. Could this be a bad capacitor
  • 1 more comment
  • Anonymous Apr 09, 2008
    Changed the capacitor and it still want come on.
  • CHaf May 31, 2008
    My motor spins freely AND wont start with a screwdriver....Bad motor and/or cap.
  • carminei7 Jun 23, 2008
    I have a Robert Shaw model 9600 T-stat, when I move the switch to the
    cool position, the condensor never starts, the fuse (in T-stat) glows
    red and then blows. This indicates a short circuit in the cooling
    system (tested the heat side, no problem). Checked all the wires from
    T-stat to airhandler, seems fine. I think the problem is at the
    compressor. Would a bad capacitor cause a short? Any other suggestions?
    Thanks.
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
BINGO!
Posted on Jun 09, 2008
  • 30 Answers
If you can spin the fan blade with a screwdriver or something and get it to take off you probably have a bad capacitor. If it will not turn then you probably have a bad motor.
Posted on Apr 02, 2008
SOURCE:
How do I fix my A/C
can be a bad fan motor, defective capacitor or contactor issue. capacitor is cheapest fix if bad.
May 11, 2014 | Bryant Heating & Cooling
Fan condenser unit wont run
This is usually a bad capacitor or bad fan motor. The capacitor is located inside the electrical panel on the outside unit. You can check these by using a meter that measures Mfds (Microfarads), most of the time you can visually see the capacitor swollen or blown. The fan motor can be checked by a meter that measures ohms, really high ohms are usually bad. If you can't spin the fan blade easily, then it's locked up. What usually happens, the capacitor or motor windings go bad, doesn't spin the fan blade, overheats the compressor so it kicks out on thermal protection till it cools back down, and sometimes the motor will overheat and go into thermal protection also. Just make sure you are getting the 220v to the outside unit too, but shut all power off before doing any trouble-shooting. Hope this helps, feel free to ask any questions!
Jun 30, 2012 | Heating & Cooling
Hot air blowing and fan on unit outside not turning
Is the compressor running? Check the circuit breaker or disconnect that is close to the outside unit if it isn't. It may be tripped on high pressure since the fan isn't running. If the unit has power, use a screw driver or something that will reach the fan blades and spin the fan to make sure it turns freely. If it doesn't the fan is probably bad. Next, check the capacitor for the fan motor. If it looks swollen then it is bad, otherwise check it with a multimeter. Most heating and air suppliers will test it for you. If the capacitor is good, the problem may be you fan motor.
You can check the fan windings with an ohmmeter.
Sep 09, 2010 | Ruud Heating & Cooling
Outside unit fan runs briefltly compressor no go inside unit fan runs but no hot or cold air
Chances are you have a bad capacitor in outside unit. Take off cover to wiring. It is a oval silver cylinder. See if it is swollen or oily. If so replace, Also check for burnt wires on capacitor or contactor. Russ
Mar 23, 2010 | Heating & Cooling
Central air unit problem.......It starts out blowing cold then will only blow room temp air after some time. I don't see anything freezing up..Filter is clear. The unit outside is not clogged up. The...
Check your outside unit to see if fan is running. If it is running check to see if air is blowing out if not you have a bad capacitor. Some times if a capacitor shorts out the fan will run backwards and the line will get very hot same as if the fan is not running. Russ
Jul 20, 2009 | Heating & Cooling
Motor outside is humming like it on but the fan isn't turning
Sounds like the run capacitor is bad or the bearings or siezing up. Turn the power off to the unit, then spin the fan blade to see if it spins freely, if it does then it's probably the capacitor.
Jun 22, 2009 | Heating & Cooling
AC unit
if its a a window unit suspect a faulty fan capacitor or bad fan motor same with outside, if it ain't moving or turning on the fan is faulty or the capacitor is faulty
Apr 18, 2008 | Bryant 463AAC008BA Air Conditioner
Goodman split unit that heats instead of cools
Hi, Could be a run capacitor on the fan motor. They usually swell up and or leak when they go bad. If not, the only real way to test them it with a specific capacitor tester. A new capacitor would be cheaper. Make sure that the outside unit is disconnected from power before opening it up, try to spin the fan blade by hand. If it doesn't spin freely it may need oiled if possible. See above solution. Your problem is the fan motor though so if this don't do it, It will have to be replaced. If this helps, Please rate my solution. Thanks, kstfas
Aug 31, 2007 | Heating & Cooling
Goodman CKL24AR24 Air Conditioner Logo
242 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Paul
Paul
Tom Palicke
Level 1 Expert
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
