Panasonic SC-AK640 Shelf System
Problem for Panasonic SC-AK640 Shelf System
F61 error code
By andrewspaddy on Apr 02, 2008
i have a ak640 hifi and get the error code f61 on power up,, what is the meaning of this code and how can i fix it
Same Problem
Apr 28, 2009
-   i have a panasonic stereo and when i try to power it up it gives me the f 6 error code can someone help me fix this problem???-   omarrntr
Oct 11, 2008
-   any solutions for the f61 error code anyone pls??-   Guest
Jul 18, 2008
-   Same problem, error code F61 appears on my panasonic stereo-   l1l1l1
Jul 02, 2008
-   ERROL F61-   Guest
May 19, 2008
-   I have the sa me problem when I conneted another speaker in parallel... the failure is related with the output signal... how much coulc cost to fix it?-   Guest
Best Solution
posted on Sep 04, 2008
Very Helpful)
kiom
Rank: Apprentice
Rating: 89%, 6 votes
nge!@ filacngunsrul
Was this helpful?
Yes
No
Solution #2
posted on Apr 02, 2008
Somewhat Helpful)
Abrsvcs
Rank: Guru  Panasonic Home Audio  Expert
Rating: 88%, 1825 votes
I'll have to look this up to be 100% sure, but I believe that this message occurs when the unit can not complete its startup sequence. Usually this is because the CD unit is stuck. If that is the case, the mechanism may need an upgrade. There was an engineering change to these mechanisms to prevent it from getting out of timing. Try unplugging this for a couple of hours and trying again. Update this with your results. In the meantime, I'll look up your specific model to see if it requires the modification.
Dan
Was this helpful?
Yes
No
Solution #3
posted on Feb 06, 2009
Not Rated)
tjelectronic
Rank: Apprentice  Home Audio  Expert
Rating: 88%, 2 votes
replace amplifier ic(rsn ic) plus 2-3 small leaky transisitors
Was this helpful?
Yes
No
Solution #4
posted on Nov 10, 2008
Not Rated)
chrispjsinky
Rating: 0%, 0 votes
i have an error code coming up on my panasonic sa-ak640 it's saying error code f61 can you help me please
Was this helpful?
Yes
No
Solution #5
posted on Aug 28, 2008
Not Rated)
Guest
Rating: 0%, 0 votes
http://www.stereo411.com/forum/viewtopic.php?f=19&t=1579diode multimeter
Solution #6
posted on Jul 02, 2008
Not Rated)
Guest
Rating: 0%, 0 votes
could it have something to do with hooking up different speakers?
Popular Solutions for Panasonic SC-AK640 Shelf
Questions and Unsolved Problems for Panasonic SC-AK640 Shelf
Do you recommend Panasonic SC-AK640 Shelf System?
Answer
Answer
i have a home threatre system that is showing f61. what is this
Answer
i have cds in but it keeps saying no disc!!!! what do you recommendI do????
Answer
I have a panasonic stereo (SA-AK640) i turn it on and it comes up with F61 then turns off by it... (More)
Answer
I have a panasonic RX-ST690 I am getting the code U02 does anyone know what this means
Answer
5 Cd Changer Panasonic SA AK600 What can I do to fix the unit?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Panasonic SC-AK640 Shelf...:
Top Audio Shelf System Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more Audio Shelf System Experts
Top Audio & Video Equ... Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
