Question about Hitachi 53FDX20B 53" Rear Projection Television
Hitachi Model 43FDX11D Will not Converge properly
A warranty technician replaced the Power Convergence Panel 2 years ago. The television is now experiencing the same focus / alignment problem. The TV is no longer under warranty. How hard is this to replace ...I am a network specialist who has experience working with the internals of computer equipment but no experience with television equipment.
  • 3 more comments
  • Tonemanyy Apr 03, 2008
    Thx for you prompt reply...can you send me the link to the IC's.
    I am pretty handy with the soldering iron.
    Hopefully they are cheaper than the Power Convergence Panel which is listed at $250.
  • Tonemanyy Apr 06, 2008
    I am having problems identifying the chips...there are many boards (6-8) in the device. Is there a way that you can assist me with the identification.
  • Anonymous Apr 18, 2008
    Can you tell me where the chip is?
  • Tonemanyy Apr 18, 2008
    Please tell me where the chip is?
  • Tonemanyy Apr 25, 2008
    I removed the chips without any problems.
    There are 2 Chips in my chasis...STK392-120 (D4E11) and STK392-120 (D4E12). Is there a difference between the 2 chips?
  • Hitachi Master
  • 8,617 Answers
Its the ICs that go out on them just minor soldering and takes about an hour from start to finish. If you would like I can post a link where you can order replacements and they include free step by step instructions so you can do the repair yourself.
Posted on Apr 02, 2008
  • 1 more comment
  • Sonny Berry
    Sonny Berry Apr 03, 2008
    They are about 20.00 each and you will need 2 or 3 depending on your chassis usually hitachis have two STK392-120 ICs and some have 3 STK4574. You will need to look inside your set to get the proper number off your ICs. They are attached to a large aluminum heat sink I will include a picture of what they look like . Here is the link for the replacement ICs just click on the convergence IC catagory and you will find your STK numbers listed there. http://servicemanuals.vstore.ca/
    and here is what they look like.
  • Sonny Berry
    Sonny Berry Apr 06, 2008
    can you post a picture of your chassis and I will circle the area where they are and repost it
  • Sonny Berry
    Sonny Berry Apr 21, 2008
    They should be attached to this heat sink.
Hitachi ultravision rear progection converge
If the convergence is so far out that you cannot adjust with your customer access menu then You will probably need the convergence ICs replaced & possibly a fuse or resistor or 2. Then a complete convergence will be necessary & I HIGHLY recommend having a professional technician perform this task.
May 23, 2014 | Hitachi 53UDX10B 53" Rear Projection...
How do you fix the color to a model 43fdx11b hitachi
Hello!you mean: colors out of convergence? nothing you can do about that, unless you replace 2 convergence amplifiers I.C. chips, plus all those burned 1 watt low ohms resistors with exact values, which only could be obtained via service manual or schematics. After resistor is burned, there is no way to read color code properly, due to partial evaporation of pigments. this is a "pro" job. If you try or tried, already to converge those "stubborn" crosses, there is more to do, even after you removed and replaced two 20 pin I.C. chips, soldered dead into sweep module, plus located and replaced resistors with precise values, you need to get your settings back to normal, by going into "factory service mode' or, at least into "convergence alignment" menu and fight with those crosses!Don't forget the white "****"! Otherwise, you will be re-servicing your set all over after 30 days of usage.good luck,Alex.
Feb 01, 2012 | Hitachi Televison & Video
How do i manully converge 50" Hitachi projection
You have to get into whats called DCAM mode to manually converge the set if you don't see a menu option for convergence. Goto the site www.tvrepairkits.com - they have a DCAM article on their tips page.
Aug 26, 2011 | Hitachi 50UX26B/27K 50" Rear Projection...
Convergence issue; red 3D effect. In grid convergence mode blue will converge w/green fixed lines and red horizontal will but the verticle red will not adjust far enough left to converge. has ajustment...
Convergence is dead.Must know how to solders?Must replaced ICS and all of it resistors.Tries Tv repair World.com,Tvrepairkits.com for a convergence kit.The shop will cost u $300 for parts and labors.
Jan 24, 2010 | Hitachi 43FDX01B TV
How do I aling colors: the red and blue colors are not align making the tv look distorted.
On my Hitachi there's a convergence button on the front panel. Press that button which will give you red & blue lines. You have to use your remote to converge (align) those lines to correct the picture. If the lines won't converge I've been told it could be a bad convergence IC & tech is needed to fix...could be approx $300 to fix.
Jan 02, 2010 | Hitachi 53UDX10B 53" Rear Projection...
Convergence problem
YOU HAVE TO REPLACE IC BECAUSE IT IS BAD THE ICS NUMBER HAS CHANGE FOR STK392-110 TO STK392-150 THEY WILL SYAN MORE HEAT
Oct 13, 2008 | Hitachi 43UWX10B 43" Rear Projection...
HITACHI PT-4271 CONVERGE
Take to a servicer and have them check the convergence Ic's and resistors then converg the set,auto convergence won't work if you have a defective parts,replace them first.
Dec 07, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Red and Green colors do no line up
It was most likely the convergence amplifiers. If you look up "convergence amplifier" on this site or google you will find lots of information. The part number(s) will be something like STK392-110.
I recently helped a friend repair this problem. If you are comfortable soldering it won't be too bad.
Nov 28, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi 53FDX20B 53" Rear Projection Television Logo
168 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
