Hello, If its making a loud squeeking/scraping noise, in my maytag that i
repaired, the problem was the waterpump. If you turn the washer on it's
side, you will see that it has a belt with three pully's on the bottom.
One pulley is connected to the waterpump and right where the pulley
meets the metal plate it's connected to, there should be a gold
coupling. This coupling sometimes comes loose and scrapes the metal
plate on spin cycle (when the pulley is spinning) which causes the
scraping/squeeking sound. If this is the case, you will see where the
coupling has scraped a groove into the metal plate. The coupling will
eventually catch while spinning and break entirely. The cheapest new water pump is $80.
Thanks
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems Washer noise when spinning
heatman101
could u please supply more detailed info about this. also make, model
