Question about Lexmark X2470 All-In-One InkJet Printer
Lexmark x2470 printer
Recently i was given a lexmark x2470 printer without a manual . this is embarrassing but can you tell me where the power cord plugs in ?? i will very greatfull for your help
  • Anonymous Feb 21, 2009
    LOL I just got this lexmark yesterday, I want to use it today and for the past half hour I have been trying to figure out where the hell do you plug in the power???
    I feel like an uber noob right now but seriously, where the hell does it plug in?
  • Lexmark Master
  • 19,396 Answers
You can get the User's Guide and other related documents here .
If you did not get the printer software cd, you will also need to download and install the drivers/software from here. Just chose your windows version.
Regards
Posted on Apr 02, 2008
SOURCE:
Paper slipping Lexmark X2470
Leading cause of paper jams or misfeeds is debris / foreign objects that accidentally fell into the paper feed area. Please try this approach to fix the problem:
  1. Remove the sheets of paper from the feeder.
  2. Grab a flashlight and look inside the feeder for any debris or foreign objects.
  3. If you're willing and physically able, you may also carefully turn the printer over. Any debris should just freely roll out from the feeder.
  4. If feeder is clear, place the printer on the table. Open the printer cover and remove the cartridges.
  5. Check the cartridge area for any obstructions in the paper path.
  6. Close the printer cover.
  7. Re-brick your printer by pulling out the power supply - the black box where the power cord is plugged into. Re-plug after 30 seconds.
  8. When the printer turns on, reinsert the cartridges and load some paper. Try to print again to verify that the problem is fixed.
Apr 10, 2012 | Lexmark X2470 All-In-One InkJet Printer
No power. adaptor and cables working.
Follow this checklist:
  • Plug printer straight to power outlet in the wall. Bypass any surge devices or power strips as they can draw away power from the printer.
  • Properly secure the power cord.
  • Unplug the power adapter from the printer, replug after 30 seconds. The power adapter is the rectangular black box, behind the printer where the power cord is attached. Check if it's warm or cold. It can be a defective power adapter.
  • If you have access to a voltmeter, test power adapter(30V output).
If problem continues, contact Lexmark technical support.
Sep 20, 2010 | Lexmark X2470 All-In-One InkJet Printer
I have a lexmark x2470 printer.i would like to know whether it as one cartidge or two cartridges.please let me know if it is available in indaia
HI,
Please note that the #2 cartridge is the starter cartridge and the after market cartridge is the #1 cartridge.
The Lexmark X2470 printer uses the #1 cartridge which prints both color and black accordingly. While printing black it uses processed black. Hence, to print color images in "Black Only," please follow the steps given below:
1. Click on "Start," "All Programs," "Lexmark X2470 printer" group and then "Lexmark Photo Editor."
2. Click on "File" and then "Open" to select the color image file.
3. Click on "Image," "Mode" and then select "Grayscale."
4. Click on "Print."
This will print the image in gray.
Sep 15, 2010 | Lexmark X2470 All-In-One InkJet Printer
Want to download exmark X2470 install cd
In order for you to install the printer without the setup disc is to download the printer software from this link and use that. Just click HERE.
Sep 07, 2010 | Lexmark X2470 All-In-One InkJet Printer
I have a broken print cartridge holder on my X2470. The retaining clip broke a tab and I can't find the part. All that seems to be on the web are power cords.
That will affect the printer's performance. I doubt if that part can be purchased. Lexmark doesn't have field tech to repair that for you. I strongly advise you to contact Lexmark at 1-800-LEXMARK(1-800-539-6275). They might be able to send a replacement printer if your's is still within warranty. I'm sorry but I hope I can assist you more with that.
Apr 20, 2010 | Lexmark X2470 All-In-One InkJet Printer
Hi, replaced ink cartridge on Lexmark X2470. Now it goes as far as the "print alignment page" and freezes. Will not print the alignment page or any other page for that matter. Thanks.
Hello. The ink cartridge may not be seated properly in the carrier. Remove the cartridges from the printer. Close the cover. Clean the nozzles using a damp paper towel. Unplug the printer from the power source. Plug it back in after 10-15 seconds. When the printer asks for the cartridges, reinsert the cartridges. Also, make sure you're using the compatible ink cartridges for the printer. Let it print the alignment page all the way without cancelling it to align the cartridges properly. Hope this helps.
Mar 22, 2010 | Lexmark X2470 All-In-One InkJet Printer
Need help to install my lexmark x2470 printer
Install your cd for printer into your drive, plug power cord for printer in but do not connect usb cable to computer, run your software to install drivers for printer, software will tell you when to connect usb cable to cable, follow software instructions you should be able to use printer when done.
Feb 06, 2010 | Lexmark X2470 All-In-One InkJet Printer
My laptop have vista, how do I find a compatible driver for lexmark x2470 printer
Go to Lexmarks Support Page CLICK HERE type in your printers model number. It will show the support page for your product.Click on drivers, and select your operating system (windows xp, vista ect). You will then be given the latest driver for your printer free of charge.
Thank you for choosing Fixya!
Oct 11, 2009 | Lexmark X2470 All-In-One InkJet Printer
Need help to install lexmark x2470
Go to this web-site:
http://downloads.lexmark.com/cgi-perl/downloads.cgi?lxkprod=Lexmark+X2470
and click on the version of Vista you have, this will take you to a web-page you can download the drivers / software for the printer from.
Hope this helps.
Apr 23, 2008 | Lexmark X2470 All-In-One InkJet Printer
Lexmark X2470 All-In-One InkJet Printer Logo
129 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
