Question about Compaq iPAQ H3955 Pocket PC
Can't reset; tried on/off and button 2 plus soft reset; nothing works
  • ipaq4 Apr 04, 2008
    Yes
  • Compaq Master
  • 13,434 Answers
Try a hard reset.
instructions are here
http://pocketpccentral.net/help/ipaq38xxreset.htm
Posted on May 19, 2008
SOURCE:
I tried the reset button but it cant reset. it turns off at the welcome screen
Hi, there are two types of reset mode:
The soft rest,
And the hard reset.
soft reset by pressing the power button and volume up (+) button together. if It didn't work. you can do the hard reset.
hard reset by pressing the reset button (its a small hole next to usb connection socket) with a safety pin. It worked. Thankfully it does not delete any of the content on the device .
Have a nice day...
Feb 25, 2011 | Philips GOGEAR SA6045 MP3 Player
Tip
How to reset forgotten password Apple Ipod Touch.
Try a soft reset and hard reset your iPod Touch if it’s frozen or not responding.
Try a soft reset first:
1. Press and hold theSleep/Wake button on the top of the unit until a red slider appears
2. Drag the slider.
3. Press and hold theSleep/Wake button until the Apple logo appears.
If a soft reset doesn’t work, try a hard reset:
Press and hold both the Sleep/Wake button and the Home button for about ten seconds, until the Apple logo appears.
on Feb 11, 2010 | Apple iPod touch
I have a Dell axim x5 and it is stuck on a blue screen with the Dell logo. I have tried a maste reset like hold the power botton and the reset for 2 sec but after that i get a screen with the option clear...
Perform a Reset
Soft Reset
When you perform a soft reset, the device deletes any data that has not
been saved but saves any data that has been stored in memory. Try
performing a soft reset if the device does not respond when you tap the
display or press a button.
To perform a soft reset, use the stylus to press the reset button.
Hard Reset
NOTICE: When you perform a hard reset, you lose all the data stored on
your device.
Perform a hard reset if:
• You want to delete all the data stored on your device.
• You forget your password and need to clear it.
• Your device is experiencing severe operational problems and you have
already attempted a soft reset.
NOTICE: It is strongly recommended that you back up your data before you
perform a hard reset. See ActiveSync Help on your computer for more
information.
To perform a hard reset:
1 Press and hold the power button.
2 With the stylus, hold the reset button for about 2 seconds.
3 Follow the instructions on the screen.
Feb 12, 2011 | Computers & Internet
My garmin 305 (for running) will not shut off..soft reset just turns it back on ..the other buttons are frozen
Try hard reset, if not working, your device probably needs to go to support
Hard reset : device must be off (short press on mode plus lap/reset)
then hold mode and start buttons for 10 seconds, then pulse on lap/reset button
You'll loose all data, and go back to factory settings.
Before trying such solution you may try reinstalling last software from PC and USB cable
Aug 25, 2010 | Garmin Edge 305 GPS Receiver
My ipod is disableb because my little brother kept putting in the wrong pass code and i dont know how to fix it
2. Drag the slider.
I have the Merriam-Webster® Speaking Dictionary & Thesaurus (MWS-1840) The screen is erratic. I tried to push clear at the same time as the on/off button, but nothing happened. So I...
If the screen performs eratically, then the only way is resetting the bookman, here is the exact procedure for resetting the Bookman,
Follow these exact steps for performing the soft reset:
1)First Press the clear button and press the ON/OFF button twice..
If this soft reset procedure doesnt work, then try hard reset..
Warning: Doing a hard reset will delete all the setting saved by you..
Here is the procedure for performing hard reset..
1)Hold CLEAR and ON/OFF button for 5-10 seconds, this should perform a hard reset, if you still have issue, follow the next step
2)Use paperclip and gently press the RESET button,
Reset button is present in a pin hole sized block present at the backside of the bookman
Any of the following procedure should solve your issue
Please leave me comment, if you need further assistance
Rnj VinodKumar
Jan 31, 2010 | Franklin Office Equipment & Supplies
Nokia 7610 problem
okay okay its easy just follow me:
1/try this code "soft reset code"
* #7370# then yes then 12345
if this is not working try this
2/u might be infected with a virus comwarrior usual
hard reset : formating the phone so make backup
* plus 3 plus call plus on/off
rate me this is the solution for sure!!!
Aug 16, 2008 | Nokia 7610
Nothing happens on my dash
First make sure your phone is fully charged. Then check...
It may be the storage card - if you take the storage card out it will boot up and you can put it back in. - pain in the a## but it may work. Or Try taking the SIM card out, boot it up, turn it off, replace the card, and turn it on again.
Last resort is a hard reboot. If you did a hard reboot and nothing happened then you did not do it successfully. To do a hard reboot.
- with the phone powered off
- press the two soft keys, yes the left and right soft keys which are the two dash keys labeled - -
- while keeping it pressed, press the power button down
- keep the power button pressed down for 1 - 2 seconds and then release the power button while still holding down the two soft keys. Keep holding down the soft keys until a black screen appears and prompts appear
- now release the soft keys and follow prompts
- if you dont see the black screen with the reset option, pull the battery out, reinsert it and repeat the above steps
- when you see the black screen with the reset option, press the Send button to confirm the reset.
Apr 03, 2008 | T-Mobile Dash Smartphone
Camera problems
you can do a software reset.......to do this the phone needs to be off. press the soft keys (buttons with the lines on them above the back arrow and home button) and press the power button and keep you fingers on the soft keys until a black screen with white writing pops up....by pressing the green call button here, it will reset the phone.....good luck!
Dec 31, 2007 | T-Mobile Dash Smartphone
Contacts
First try a soft reset - insert stylus into hole at bottom of unit.
Sep 11, 2005 | HP iPAQ RX3715 Pocket PC
Open Questions:
See all Compaq iPAQ H3955 Pocket PC Questions
Compaq iPAQ H3955 Pocket PC Logo
63 people viewed this question
Top Compaq Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
