Question about Canon PIXMA MP780 All-In-One InkJet Printer
Cartridge Jam Error
I keep getting the (Cartridge Jam error) and therefore it wont print. I have check everywhere and I cant see where the problem is. Please help this has been so frustrating and now it wont clear at all to be able to print.
  • 1 more comment
  • twobuckets Apr 14, 2008
    This problem appeared after a series of other problems had already occurred. I had been getting poor quality printing in the blacks, apparently a clogged nozzle. I tried cleaning the nozzles, then swabbing the nozzle with an isopropyl-soaked cloth. Problem went away for a short while, then returned.
    After trying nozzle cleaning and head refreshing, I started getting the "cartridge jam" error showing up. I haven't been able to get the printer working since.
  • sem33 Apr 16, 2008
    After replacing empty ink cartridges my printer would no longer print. I can't see any physical reason for this. All cartridges are brand new. Tried head refreshing and nozzle cleaning to no avail.
  • Jack Mason May 03, 2008
    Also recently replaced catridges and getting "catridge jammed" errors.
    Have tried taking them out and replacing. Unit alos making a slight squeal.
    Genius:
  • 2,785 Answers
Your printer hardware is having problem please send it for servicing
Posted on Apr 03, 2008
4TH LIGHT FROM THE TOP KEEPS COMING ON LEXMARK E232
What this light sequence means that the printer has a paper jam.
When a paper jam occurs, the printer stops and the operator panel's Paper Jam light and Continue button lights come on. Press and release Continue twice quickly to display the specific secondary error paper jam light sequence.
How to clear Paper Jam
Press Continue button twice quickly to see the secondary error code.
To get the secondary error codes
When the Error light (!) and Continue button lights are both on, a secondary error has occurred.
When the Paper Jam light (4th light) and Continue button lights are both on, a paper jam secondary error has occurred.
Press and release Continue button twice quickly to display the secondary error code light sequence.
Press Continue button to resume printing once all the jammed pages are cleared from the paper path.
We recommend that you clear the entire paper path when a paper jam occurs.
To clear a paper jam:
1 If you are feeding paper from a tray, remove the tray, and then remove any jams.
2 Open the front cover and remove the print cartridge assembly.
NOTE: Do not leave the print cartridge assembly exposed to direct light for an Extended period of time. Extended light exposure can cause print quality problems.
3 Remove any jams in the area behind the print cartridge assembly.
4 Lift the flap at the front of the printer and remove any jams beneath the flap.
5 Open the rear exit and remove any jams.
6 After you have cleared the jams, reinstall the print cartridge assembly, make sure all printer covers and trays are closed, and then press Continue button to resume printing.
NOTE: The printer reprints the pages that caused the paper jam.
Jun 30, 2011 | Lexmark E232 Laser Printer
Before i can print a paper but now it cant be . and appear the " Error light". Show me how i can fix
Hi
For resolving the error first properly check the paper jam bcoz any small paper also make the error see the printer drum side therefore you find any paper then remove that one, second check your printer cartridge ink level if low level then change the cartridge third check the you have properly close the all door of printer....
Cheer
Jun 26, 2011 | Brother HL 2140 Laser Printer
I bought the printer a couple of weeks ago and have only printed a maximum of 20 pages. Now when I try to print, the "error" light keeps coming on but I've looked and it doesn't say what the...
Try opening the printer and checking for a paper jam.
It's also worth removing the toner cartridge and placing it back again, therefore forcing the printer to go through the diagnostic cycle again. Sometimes that solves the issue.
Hope that helps!
Mar 14, 2011 | Brother HL 2140 Laser Printer
Hi I had a paper jam in my MFC 8820d - I removed the cover and removed the paper but I still get a Paper Jam error msg. I powered down the machine and turned back on - still same error msg. I have removed...
This can sometimes be related to paper dust interfering with a sensor. A burst of canned air can fix the problem. Just pull out the toner, open all of the covers and spray air into all the little crevices. You might want to do this outside, in case toner is loose in ther, so as not to make a mess.
Sep 02, 2009 | Brother MFC 8820D All-In-One Laser Printer
I have a Kyocera FS-2000D printer that will not print
first turn off your pritner power.
check open the front door pull your ink cartridge then clean dust and blur from it then check there is not any paper jam then refix ink cartridge.then turn on the power.
Mar 21, 2009 | Kyocera FS-2000D Laser Printer
Paper Jam Issue with the HP Deskjet 5440
Clean the contacts on the HP Cartridge. I've had the same error before and i switched it to a fresh new cartridge.. works fine ever since. THen i decided to switch back to the old cartridge, same error as you but i cleaned the contacts on the cartridge, works for a while but done after a week. Problem is that the ribbon circuit is rusted and the printer doesnt recognize the ink anymore.
Also make sure you both have the ink cartridges in place. Make sure it is seated properly inside.
hope this helps!
-levibit-
Mar 20, 2009 | HP Deskjet 5440 InkJet Photo Printer
Paper jam 11
Step1
Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
Step
Turn off the printer.
Step
Remove any paper trays. Inspect them for wrinkled or damaged paper.
Step
Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
Step
5
If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
Step
6
If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly (see A). The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
Step
7
If the paper does tear, try rotating the roller gears manually to free the paper (see B). Don't force anything, though.
Step
8
Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
Step
9
If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
Nov 07, 2008 | Copystar CS-1815 Printer
Carriage Jam
Make sure you can move the print cartridge holder freely and that it isn't being blocked by anything inside the printer, also check if the cleaning station is in the right position, maybe it is locking the cartridges.
Apr 22, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
Hp psc 1219
dear szaszy
as per your information your printer paper jam sensor is having problem.Please get it serviced
Apr 04, 2008 | Office Equipment & Supplies
Canon PIXMA MP780 All-In-One InkJet Printer Logo
107 people viewed this question
old marine
old marine
