Question about Refrigerators
Hello, I have a fridge/freezer hoover
I have a fridge/freezer hoover model HCA36FTALU. Frost is forming on the back wall of the 2nd and 3rd shelf in the fridge compartment. The fridge is on a level floor and I don't know what can be causing the excess frosting. Could you please advised. Thank you in advance. - Eric
  • 109 Answers
You have a defrost issue, while not familiar with hoover, normally there is a defrost timer, a defrost heater and a defrost thermostat, one of these three things are not operating. (may be more than one )
Posted on Apr 03, 2008
SOURCE:
Frost free fridge freezer build up of ice
The defrost timer has quit.
They have a relatively short life.
Jul 25, 2015 | Hoover Refrigerators
Why is ice forming in freezer
Ice layer inside freezer box floor - Defrost drain line clogged.
Frost or ice on freezer box top - Room air leaking into the fridge from door seals.
Frost on the Freezer box back wall means unit is not defrosting properly.
Sep 04, 2014 | Whirlpool Refrigerators
Why do i have frost on the inside?
frost forms from either the door being left open,a ripped gasket,when warm and cold air meet frost forms,also if the back inside wall of the freezer is frosted up you could have a defrost problem,bad defrost thermostat,heater timer or board depending on the model number.if the warm air got in say overnight you could have a problem with the fridge not getting cold,usually the air ducts freeze up.if it's in the freezer look at the door,you might find ice on the door where the warm air was coming in and also you'll see frozen water droplets on the packages and walls
Sep 02, 2012 | Refrigerators
I have a kenmore model refrigerator freezer model #70982991. It has a top freezer and the mfg. date is 10-00. Right now the freezer part is working but the refrigerator is not. It is used in my unheated...
Lack of freon isn't an issue. Check the internal fan between the freezer and fridge. It is usually located behind the back panel in the freezer. If not there, check upper back of fridge. The internal fan blows the cold air from the freezer to the fridge. When it goes out, the freezer will freeze but the fridge won't cool.
Sep 04, 2011 | Refrigerators
My powerpoint fridge freezer model trf 285 ice and frost keeps forming on back wall of fridge even with temp turned up to highest
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost TimerProblem
Water Runningin refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jun 21, 2011 | Refrigerators
Build up of ice in bottom of freezer compartment
During the defrost cycle heaters in the wall of the freezer are turned on to melt the frost build up. This melted frost "water" is supposed to run out a drain in the bottom of the freezer and collect in a pan under the refrigerator/freezer where it will eventually evaporate. If this drain is blocked it will cause a lot of water to collect in the bottom of the freezer and that water will eventually turn back into ice. I recommend defrosting the freezer manually, removing all the ice/water buildup in the bottom, and trying to unplug the drain line to the pan underneath. Also check the seal on the freezer door. If it's not sealing well it could be letting a lot of moisture enter the freezer which would lead to more frost buildup and more water during the defrost cycle.
May 22, 2009 | Hoover HCA390FFK Bottom Freezer...
Freezer side cold, frige side warm
Defrost heater is open behind back wall. order new heater #wr55x10101 remove 4 screws 2 bottom, 2 top behind light shield, defrost freezer so ice is off of evap, replace heater with new one.
Nov 13, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
542 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
