Question about Toshiba TDP-T9U Multimedia Projector
Wil not turn on
Hi my tdp -t9 will not turn on, it turned on once and then worked fine then i turned it off and then i tried to turn it on again and now it dose not turn back on. all i get is the lamp barely turns on then it goes back off again or it does not turn back on. ive had it for a while
  • 22 Answers
Either your lamp is burned out or you had it unplugged for a while.
If you have had it unplugged for a while, plug it in, make sure the yellow power light is on, then wait for about an hour. Don't repeatly try to turn it on in the meantime. After about an hour or two plugged in,,,,, it should power up. Then reset your lamp timer through the menu.
Posted on Jan 09, 2009
Hey i have the same one my sat for 6 mths and went to fire it up and it didn't work i ended up leaving it plugged in for 30 min - 1 hr and it works fine now.
Posted on Oct 12, 2008
  • 563 Answers
Hi there
It will be one of two things - either the lamp that need replacement or the Ballast ( lamp's powersupply ) that is faulty and will need replacement or repair.
Posted on Apr 03, 2008
I have connected my toshiba TDP-T9 to my laptop but I'm getting a "No Signal" error on screen. Could my VGA cord cause this?
Depending on your laptop, the internal splitter may be turned of. Usually the keystroke to turn it on is Fn F8. However it may be different on your laptop. Look at the function buttons, and the one with a screen looking thing on it is the one you press with your "Fn" key.
Jan 27, 2011 | Toshiba TDP-T9 DLP Projector
Toshiba TDP-T9. the light won't change from yellow to green. we tried restarting the computer and the projector, but nothing seems to work.
Well first check the colour scheme of your monitor and of the projector.
If this doesn't work check the working hours of the lamp. Try cleaning the filters and if this doesn't solve your problem the best thing to do is to change the lamp of the device.
If you need further assistance please leave a comment. Cheers
Aug 25, 2010 | Toshiba TDP-T9U Multimedia Projector
Toshiba TDP-T90 projector - Won't turn on
the power supply capacitors are dried up. replace the power supply.
Jul 29, 2009 | Toshiba TDP-T90 Multimedia Projector
Toshiba Projector won't turn on!!!
I had the same. Try to press the "input" and "menue" buttons and plug in the power cable. No control light should be active after that. Press the "power" button and it should work.
Dec 19, 2008 | Toshiba TDP-S8 Multimedia Projector
Help i have a Samsung YP-T9 and it froze
hold down the menu and play button at the same time to reset, should turn it off, then just turn it back on again
Jun 11, 2008 | Samsung Yepp YP-T9 Digital Media Player
Trouble with output to the projector
Hi there
Check the following on your laptop.
Right click on your desktop , go to properties and settings - check if your resolution of the PC is the same as that of your Projector. i.e. 800x600 or 1024x768
Also check that your secondary monitor is attached / activated.
If the signal stil won't pick up - hold down the Fn ( function button) left of your spacebar and press in your F-row of buttons the one with 2 screens on it. ( differs from brand and model )
Hope this helps you and good luck with your class tomorrow !
Mar 31, 2008 | Toshiba TDP-T9U Multimedia Projector
Projector power problem
I HAVE THE EASY FIX!
I had this same problem & almost threw it away!
If you have had it unplugged for a while just plug it in & make sure the yellow power light is on, then leave it plugged in for about an hour or two. Do not try to turn on before at least an hour, then it can easily be turned on. Make sure you reset the lamp timer option. There & you thought it would be difficult & expensive!
Oct 11, 2007 | Toshiba TDP-T9U Multimedia Projector
Toshiba tdp-t9 (everyday t.v.) with no hdtv hookups
Yes you can hook up your Projector to ur cable box thru componet to RGB conversion Cable. that will work. i am also there on v_dhiman@hotmail.com
Apr 16, 2007 | Toshiba TDP-T9U Multimedia Projector
Toshiba TDP-T9U Multimedia Projector Logo
884 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
