I just purcashed Print Workshop Business Solutions and can not get it to install. I press Run, Insert the Disk in Drive E (also tried D) and the screen just says to insert the disk. I haven't had this problem with other programs.
    Problem Solver:
  • 44 Answers
Try going to run and type the following d:/setup.exe, I apologize that I can't help more, so I hope this helps you out some.
Posted on Apr 02, 2008
SOURCE:
I have the business 2 pack ,when inserted in drive, i does not load, or install from either disc .
Insert the first disk and go to My Computer, right click your disk drive (probably D:\) and select Autorun if available, if not right click the disk drive and click Explore and then find the icon that either says Install.exe or Setup.exe and double click it then follow the prompts.
Mar 14, 2011 | Cosmi Computers & Internet
Bought Print Workshop 2007 LE online and down loaded it, but when I try to get clip art it tells me I need to insert disk. I don't have a disk!!! Am I going to have to spend more $ for a disk. It cost...
Try re-downloading the software (it should be free to re-download since you have already paid for it). Try to get clip art again. when it says insert disk, it should show a browse button where you can map to the file you just downloaded. if that doesn't work, run the installation file and do a custom install. You should be able to install the clip art through there.
Mar 12, 2011 | ValuSoft Computers & Internet
When I switch on my pc,it tells me disk boot failure insert system disk and press enter. I have XP proffessional sp3 but only have a xp home disk.
If your computer has just been formatted, your computer might require you to insert the boot CD
to be able to run it. You might hence get the error message Disk Boot Failure- Insert disk and
press enter displayed on the screen every time you will try to run it. This might be linked
to:
* 1. The boot options not correctly set in BIOS
* 2. A non bootable CD is found in your CD drive
* 3. You do not possess any bootable device
* 4. You have installed a new hard disk
* 5. The hard disk is not properly plugged
* 6. Your system files have been infected
Get more help and information for Disk Boot Failure. Hope this helps you....
Jan 29, 2011 | Microsoft Computers & Internet
How to add in Microsoft 2007 in my computer if add or remove program doesn't contain any Microsoft?
no need go to add/remove program..
insert DVD/CD in drive.. it will be auto run..
follow instruction from cd programme..
it will be install..
if not auto run your disk..
find .exe file on your disk
click on it..
follow instructions...
it will be install...
enjoy...
Nov 10, 2010 | Microsoft Office Computers & Internet
When I try to install the Print Workshop 2008 I am prompted to place a disc in the drive and the installation disc is already in the drive.
Here is the problem: the disk drive simply isn't reading the disc. Here are some suggestions:
  1. Make sure the side of the disk with the writing is on the TOP.
  2. Take computer to computer specialist. Sometimes disk readers go out for no reason at all.
Jul 03, 2008 | Computers & Internet
I am having problem trying to install print workshop something seems to be wrong with my dvd-rom
There may a disk problem please see the bottom of the disk if any scratches or any dust . You have clean the disk by disk cleaner solutions. After cleaning the disk put the disk in to the dvd-rom and try it . if not please inform to fixya.com
May 13, 2008 | Computers & Internet
I cannot install Print Workshop 2008. I have tried going to RUN, and installing device updates, but nothing works. Am I out $20. I had a problem with Print Workshop 2004 but at least I could install...
Usually you just put the CD in the drive and it automatically runs. Do you have more than one CD? Sure you're starting with the right one? Once you have the CD in the drive, double click on My Computer, then double click on the Compac Disk drive icons. If that doesn't start it, it will at least display the names of the files on the CD. Look for the Setup program and double click on that. Good luck.
Mar 23, 2008 | Computers & Internet
Disc will not run
dear ejcafe, if you can't install it you might like to contact your vendor. If you are unable to use it, maybe you would like to tell the error so that i can figure out what might be wrong.
If it isn't long, you may claim for a replacement or your money back. You can call customer support for this.
If that has helped you please press 'fixya'
Oct 30, 2007 | Computers & Internet
Disk boot failure
After making 100% sure you have no diskette or CD in any drives the conclusion may well be that the disk is ruined. You ay try to boot from a diskette or CD and see if you can access the disk then. (see www.ultimatebootcd.com for instructions to make a boot CD) "The ultimate boot CD" has a few tools that might help you out. Since you can't boot you must make it on a different computer, though. You may also try to insert the disk in a diffe rent computer to see if it can be booted there. Also make sure all cables are properly connected.
Apr 03, 2007 | Acer (91.AB033.041) 73 GB Hard Drive
Computers & Internet Logo
Ekse
Alun Cox
